Question about Zanussi Washing Machines
Zanussi zwh7120p water not stopping
Bought and installed this for the first time this evening, and set it up exactly as i would have done my old zanussi, which had no problems at all. As soon as i turned on the water inlet, it started filling up with water. which was interesting, as the machine was switched to "off". if i leave it for an extended period it just seems to fill up the drum, draining does work fine though. has anyone else had this problem, how can i fix it, or is it normal?
  • 1,606 Answers
It is not normal. It's a warranty problem. At best, the timer may not have been installed properly. At worst, it's defective. The dealer owes you a replacement or repair, unless it's a used as-is unit.
Posted on Jul 02, 2017
  • 1462 Answers
SOURCE: Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Posted on Apr 01, 2007
jsrock516
  • 5911 Answers
SOURCE: Will not advance from fill cycle
Check your drain hose to make sure you have not sealed the top of the standpipe (drain line), or shoved your drain hose too far down in the pipe. If you do not allow for an air gap, your washer will fill and begin to siphon through the drain line. It is common for folks to seal the standpipe or shove the drain hose down in the line too far in the belief that it will prevent overflows, or get rid of that nasty drain smell. This can be bad because it does not allow for the proper air gap to keep the water from being siphoned right out of the machine. You may have a tight fitting that doesn't siphon every time which may explain why the problem doesn't occur all the time. Double check to make sure. Hope this helps.
Posted on Jun 15, 2007
  • 1294 Answers
SOURCE: Washing machine fills with water when not in use.
Click on washing machines above, (below FIXYA) on this site, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site. You have to replace your inlet water valves. Its simple.
Posted on Feb 11, 2008
dauphine
  • 207 Answers
SOURCE: Washing machine filling with water when switched off
Electric inlet valve doesn't close properly. You should get it replaced ASAP. It is a cheap part and quite easily replaceable. Turn off water to your machine until you fix this and keep it unplugged.
Posted on Apr 24, 2008
SOURCE: Indesit wd125 drum wont turn
check your pump it may not be working
Posted on Dec 18, 2008
Zanussi 1400 6kg yrs old humming can you help?
Humming may be from the inlet valve. I know it sounds daft, but check water is turned on and water pressure is ok
Jul 26, 2014 | Zanussi Washing Machines
I have a Zanussi Washer/Dryer Model ZWD 1270W. When I set the machine to wash (any cycle), it fills with water, the water jet starts, it takes the soap powder then it immediately skips to the 'drain'...
http://laundry.manualsonline.com/manuals/mfg/zanussi/zwd_1270_w_zwd_1270_s_zwd_1470_w.html
If you go to this website, they have manuals and you can ask questions also.
Just one thought. Have you unplugged the washer for a few seconds then plugged it back in? It's possible the "brain" needs to be reset.
Nov 02, 2013 | Zanussi Washing Machines
Need a manual or instructions for mt watch please!!!
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to resume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
Have fun :)
May 04, 2017 | Watches
Old house with old water cylinder, water pouring out of the spout and larger than normal electricity bill?
Hello grant.... You must stop that water flow immediately or your bill will be even larger next time it arrives. If the water is pouring out of the spout attached to the pressure relief valve you may simply need to replace that valve. To do so, turn off the power to the tank and use a wrench to remove the pressure relief valve. GO to any hardware store and get an exact replacement valve and a small tube of plumbers pipe dope. Dope up the threads and install the new valve. Joe
Thanks for choosing Fixya!
Jan 05, 2011 | Heating & Cooling
Zanussi oven timer buzzes at 20.00 then resets to 12.00
Gave up and bought a new timer module for £66 from espares. Timer board has microscopic components so even if you knew what was wrong it wouldn't be fixable.
Sep 22, 2009 | Zanussi ZBF360 Electric Single Oven
Help my washer
Dont put loads of clothes in, the zanussi has a sensor which, if the weight in the drum is not dispersed evenly it will not reach the final speed. best to take some clothes out it should work ok then
Apr 16, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi ZWF1437W Washing Machine Problem
My Zanussi is 5 years old it onn th whole works well not making over the odd noise but is often marking my clothes with splashes of light brown after washing, which dosn't come off even with stain remover .
What could this problem be.
RR
Dec 11, 2007 | Zanussi Washing Machines
No spin
Your problem is that the carbon brushes on the motor have worn out and need replacing.. eaisly done
Dec 10, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
54 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
