Question about Intermatic & Self-Adjusting Wall Switch Timer
Installing the battery can't get the door opened to insert battery
The door below the off on switch wont open
  • Intermatic Master
  • 5,245 Answers
Drawer pulls straight out. Use small screwdriver or metal nail file.
Copy following link for illustration and CR2 battery, and ez-to-follow programming, and wiring options.
http://waterheatertimer.org/images/ST01C-program.html#battery
Remember the drawer is also 'plugged' into the timer, so do not bend small metal prongs on drawer.
This timer comes with 1 year limited warranty against defects in workmanship.
The battery operates timer functions, so once battery is installed, the timer can be programmed before timer is installed in wall.
Be sure to reset timer before programming to eliminate stray code on the memory chip.
Once timer is programmed, the programs remain inside memory chip forever, even with power loss and no battery, until timer is reset of re-programmed.
Reset this timer: Hold down on-off button and momentarily push round reset button with paper clip. Keep holding down on-off until display changes, then release on-off button and begin setting current time and programs.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Nov 28, 2012
2013 Toyota Highlander. Key fob remote doesn't work after installing new battery. It is not a smart key remote.
PROCEDURE. Make SURE the battery you installed is good.
  • Driver's door open, key removed from ignition switch
  • Within 5 seconds: Insert and remove the key from the ignition switch twice
  • Within 40 seconds: Close and open driver's door twice
  • Insert and remove the key from the ignition switch. Close and open driver's door twice
  • Insert the key into the ignition switch and close the driver's door
  • Within 40 seconds: Switch ignition ON and OFF once to program a remote transmitter code whilst retaining the original codes or twice to program and remote transmitter code whilst erasing the original codes. Three times to check how many remote transmitter are currently registered or five times to erase all registered codes
  • Remove key from ignition switch. System should now lock and unlock vehicle once, twice or five times depending which mode has been selected. One to four times, slowly, to indicate number of remote transmitters registered
  • Within 40 seconds: Press and hold LOCK and UNLOCK buttons simultaneously for 1.5 seconds
  • Within 3 seconds: Press LOCK button
  • SYstem should now lock and unlock vehicle once to confirm registration, twice to indicate registration has failed
  • Within 40 seconds: Repeat button procedure to program remaining remote transmitters.
  • NOTE: To exit programming mode: Open driver's dorr
  • NOTE: A maximum of 4 remote transmitters can be programmed
If the above programming procedures do not work, then you should contact your locksmith.
Goood Luck!
Dec 13, 2017 | Toyota Highlander Cars & Trucks
How do I open the battery door
Open the battery door of what make and model camera?
Jun 07, 2013 | Computers & Internet
Battery is DEAD on 2003 Ford Escape! Door key (using an actual key) unlock is also motorized, which needs battery juice. I can't get into this car! I thought about putting jumper cables on the sta
Open the door manually with the key!
Many Ford Escapes have power door locks as standard equipment. This system consists of a lock switch, lock actuator and wiring harness. When you depress the lock switch, it sends an electronic signal through the harness to the actuator. The actuator moves an internal piston that either pulls the actuator hook down or pushes it up. The actuator hook connects to the lock rod, which either locks or unlocks the door, depending on which way you push the lock button. While this system won't work with a dead battery, the mechanical lock system remains unaffected by electrical power loss.
Insert the door lock key into the driver's door lock.
Turn the key counterclockwise one quarter turn.
Pull the door handle up until the Escape's door opens. Once the driver door is open, simply open the remaining doors by pulling the interior door handles until the doors open.
Aug 13, 2017 | 2003 Ford Escape
Disk drive door wont open. LED light comes on an hums, but tray wont eject to open. Where is manual eject hole located?
Below the drive tray there is a tiny hole, straighten a paper clip and gently insert the paper clip into this hole. Push the paper clip and the tray will release and pop out, then pull the tray out to the fully open position.
Mar 02, 2012 | Computers & Internet
Wont keep charge
I don't know if your Jimmy uses a separate voltage regulator or if it is integrated into the alternator; if it isn't it may be faulty.
About this:
> if I put a fuse in the int lights will not shut off, so i dont use it,
Check the door switches at all doors and the hatch with the fuse installed and the lights on.One at a time, open a door, look for a button somewhere on the stationary frame, depress it and wait for the timer to shut them off each time; this may take a few minutes on each door.
These lousy switches are not very durable and the little plunger may not be pushing them in far enough to open the switch, alloowing the lights to turn off when not needed.
Our Jeep GC had this problem and I have put the small rubber bumpers used on cabinet doors on the contact point of the door to securely depress the switch buttons and the problem is now gone.
Nov 25, 2011 | 1995 GMC Jimmy
How do you program a replacement key for a lexus es 330 2004
Here are the instructions from the factory manual. They must be followed exactly.
2004 ES330
1. Driver's door open, all other doors closed, key removed from ignition switch.
Within 5 seconds:
Insert and remove the key from the ignition switch twice.
2. Within 40 seconds:
Close and open driver's door twice.
3. Within 40 seconds:
Insert the key into the ignition switch and close the driver's door.
4. Switch ignition ON and OFF:
A. Once to program a key remote transmitter code whilst retaining the original codes.
B. Twice to program a key remote transmitter code whilst erasing the original codes.
C. Three times to check how many key remote transmitters are currently registered.
D. Five times to erase all registered codes.
5. Remove key from ignition switch. System should now lock and unlock vehicle
times, slowly, to indicate number of key remote transmitters registered.
6. Within 40 seconds:
Press and hold LOCK and UNLOCK buttons simultaneously for 1.5 seconds.
Within 3 seconds: Press any key remote transmitter button.
System should now lock and unlock vehicle once to confirm registration or twice
to indicate registration has failed.
7. Within 40 seconds:
To program additional remotes repeat step 60 now on each additional
remote you want programmed.
8. To exit programming mode open driver's door or insert key into ignition.
9. Step out of car with remote(s) in hand and test remote(s).
Nov 01, 2011 | 2004 Lexus ES 330
I have a burned CD in the CD drawer and I can't retreive it, I can't find the button to open the door. Somewhere there is a button" OPEN DOOR" but I can't locate it.
There are two ways to open the CD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you continue having problem openning with the Eject button, then the CD drive may be faulty and needs replacing.
May 19, 2011 | Gateway Computers & Internet
Where do I insert the batteries on the star wars millenium falcon toy?
Locate the turrent on the top center. Just behind it is the On/Off switch. Behind it are 6 black, round engine-looking pods. That is the top cover. There are two tabs right behind the On/Off switch you push back on to remove the cover. Grab your screwdriver and remove the battery door. Uses 3 "AA" batteries.
Feb 20, 2011 | Hasbro Star Wars E3 Otc Millennium Falcon
Intermatic & Self-Adjusting Wall Switch Timer  Logo
124 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
