Question about ASUS A8N-VM Motherboard
No display after installing 9500 gt 1gb graphic card on a8n-vm
    Brigadier General:
  • 5,158 Answers
Install the driver... then install the card. you may have to manual set which video source the computer is using.... ideally you want it to boot to pci first
Posted on Jan 10, 2009
Need abetter graphic card for acer aspire 5251
in Acer Aspire Series is using Intergrated Graphic Card.
that mean if you wanna Upgrade your Graphic Resolution,
you have to set to a bigger shared memory/RAM for Display Graphic Card/VGA memory from BIOS Setup.
for example if you using RAM 2Gb, and you can make your VGA(Video Graphic Adapter) to 1Gb.
But in My Computer Properties the RAM will Show only 1Gb.
Because another 1Gb of RAM you've use for VGA.
you can check it from dxdiag.
(for opening dxdiag > Click Start > click RUN... > type dxdiag > and Oke/Enter)
Jan 07, 2012 | Acer Computers & Internet
Is the ASUS A8N-VM PCI Express 2.0 compliant?
not that I know. It may support newer pci-express graphic cards, but surely they won't run at full-power with pci express 1.0 lower specs. if you're not satisfied with your motherboard, you should buying a new one that supports pci-express 2.0
Feb 06, 2010 | ASUS A8N-VM Motherboard
Muy Mother Board A8N-VM CSM Driver Lan
follow the link below to download any driver you need
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=A8N-VM%20CSM
You have a Gigbit Lan on the motherboard
you can enable or disable this in bios setup.
If it is enabled and not working you'll need to purchase an eithernet card they run about $10-20.
Mar 23, 2009 | ASUS A8N-VM Motherboard
Video Card
It is likely to be your old graphics drivers conflicting with the new card - Put the old card back in and be sure to remove them
1. Start
2. Right Click My Computer
3. Properties
4. Hardware Tab
5. Device Manager
6. Display Adapter
7. Uninstall
Turn your PC off and place the new card in then reboot
Install the new drivers after booting.
If this helped dont forget to rate me ;)
Blazamane
Jan 08, 2009 | Dell Dimension 4700 PC Desktop
Does My A8N-VM Motherboard support 500GB SATA or SATA II ?
Yes, your motherboard features 2x SATA II ports so you can add any sata II hardrive
Dec 16, 2008 | ASUS A8N-VM Motherboard
Version of PCI Express
my motherboard has a PCI-E 1.0 it's an Asus Commando graphics is 9600GT which is PCI-E 2.0 and it runs fine till now no prob about that mate PCI-E 1.0 and 2.0 is backwards compatible so it should work fine make sure your graphics card is working @ x16 coz when I first plug my graphics it runs only @ x2 then I reset the bios and re-seat the graphics now fully functional x16 of PCI-E lanes.
May 15, 2008 | ASUS A8N-VM CSM (00610839133826)...
Asus p5rd1-vm motherboard problem of graphics card
Hi shuter. Your Asus P5RD1-VM has an integrated video adapter ATI® Radeon 9600 GPU. You need to enter your bios & change the video start up order. Pg.2-22 in your manual.
Configuration options: [IGD] [PEG/IGD] [PCI/IGD]
Boot Graphics Adapter Priority [PEG/IGD]
Save & exit. Check system at boot up for correct memory count.
Thanks for using FixYa & if you need more help just re-post here. Have a good one!
please vote...
Feb 29, 2008 | ASUS P5RD1-VM Motherboard
Installing NVidia 8500GT XFX 256MB graphics to A8N-VM Motherboard
The chances are that you have an old motherboard which is not compatable with the new graphic card. Or you may be running windows 98 and are downloading the driver for xp or visa versa. The probable solution, will be to sell the new card on ebay and buy the best old card you can off ebay. Or just make do with the card you already had in your computer. If you are determined to have a better graphics card. A motherboard upgrade with better graphic card may be the best answer or buy a better spec pc second hand if you don't have much money. You'll probably waiste a lot of time trying to get the new card to work and it probably never will.
Jan 28, 2008 | ASUS A8N-VM Motherboard
ASUS A8N-VM Motherboard Logo
99 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
