Question about Thermador SC302T Electric Double Oven
Thermador c302zs error f34 - Thermador SC302T Electric Double Oven
4 Suggested Answers
  • 3 Answers
SOURCE: troubleshooting thermador
call thermador service center 800 735 4328
Posted on Mar 10, 2008
taran_2005
  • 10515 Answers
SOURCE: code f34 for my thermador
According to a Thermador error code book for a single Thermador oven. It says its a air flow problem. This means it could be the fan motor sensor telling the control board that it is not spinning fast or not at all. or it could be a micro paddle switch that is activated by air flow. Recap : if your fan blower motor has 4 wires going to it, it has a sensor reading the rotation of the motor.... if yours does not have this then you should look for a paddle switch.This could also be a result of fan may be too dirty to operate correctly. Try to clean the oven. If you had this error after electrical surge or outage recently, then turn off the dedicated circuit @ circuit breaker box for about 1 Hour and hopefully it would resolve the problem.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 24, 2010
e-Guru
  • 3917 Answers
SOURCE: C302ZS DOUBLE OVEN Thermador: oven was
Hi
The F34 means Upper oven cooling fan over-speed or under-speed detected. the corrective action needed in the case is to clean the cooling fan of any debris or dust, if this does not solve the problem replace the cooling fan.
Dim or faint display is a function of the drive voltages to it. A transformer creates these - and the DC voltage is stabilized by capacitors. The capacitors are only rated to 105 C - which means over time the heat will reduce the capacitors capacitance...lowering the drive voltage and diming the display.
Turn off the power - remove the keyboard panel and metal plate it attaches to. Remove the board attached to the metal plate (not the keyboard/board). Replace 3 capacitors (2 x 470 uf 35V, and one 68 uf 35v....highest temp you can get is 125 C.
Please check this link for a more detailed article:-
http://www.ehow.com/how_6887916_repair-dim-oven-display.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 21, 2011
F34 error
coolingfan/air flow issue on the upper oven
Feb 14, 2014 | Thermador SECD302BPSS Electric Double Oven
Thermador cm302 f34 error
upper oven fan airflow switch not activated. It may be stuck or the fan isn't running at all.
Mar 07, 2013 | Thermador CM302U Electric Double Oven
How to install air flow switch on thermadore c302zs
remove lower trim UNDER lower oven door. It's right there.
Dec 10, 2012 | Thermador C302U Electric Double Oven
CM302US Thermador Double Oven F34/64 Problems need schematic diagrams
air flow/fan issue. either bad fan motor, air flow switch or relay board.
Nov 29, 2012 | Thermador C302U Electric Double Oven
What does F34 mean as an error message?
Hello, welcome to FixYa.
The "F34" code on your model of Thermador double oven indicates the control has detected an error with the airflow for the upper oven ( all lower codes start with "6", upper start with "3" )
This could indicate a faulty blower motor, not coming on at all, or if it does come on and still initiates an F34 error, it is likely the sail switch is sticking. It can be removed and cleaned as they do become contaminated with dirt, grease and dust over time.
The sail switch is located at the very bottom of the ovens where the grill is, under the lower door.
example:
( F34 can also be initiated by a failed "K6" relay on the control board, but that is less likely )
It can be accessed by way of removing the grill, however it is something usually best left to an authorized B/S/H/ service provider as it can be quiet involved and is better to pull the unit from the wall.
**Turn off the 40 amp breaker to the oven before attempting any service...safety first**
B/S/H/ is the parent company for Bosch, Thermador, Gaggenau, Siemens.
Thank you for choosing FixYa today and good luck, please take a moment to rate the info provided here for you.
Regards,
Macmarkus :)
Sep 15, 2011 | Thermador SC302T Electric Double Oven
What is error code F34 on the thermadore built in double oven
If your Thermador was manufactured between 2004 and 2007, this may be due to a recall issue. I kept getting this error on my Thermador wall oven when I would run the self-cleaning feature, and when heating it over 375 degrees. After doing some research, I discovered that my oven was recalled. Apparently there are gaps in the insulation which could cause a fire. You can find out more on the Thermador website: http://www.thermador.com/safety-notices/7_oven-safety-recall-notice-expanded
Oct 15, 2010 | Ovens
F 34
My Name is Don from Mr Fix it Applaince in baytown texas. I have seen this F34 error as well and may have a solution for some of you... According to a Thermador error code book for a C301bs/03 single Thermador oven. It says its a air flow problem. This means it could be the fan motor sensor telling the controlboard that it is not spinning fast or not at all. or it could be a micro paddle switch that is activated by air flow, I found Two of them on the bottome of a double oven thermador a few moths ago.. Recap : if your fan blower motor has 4 wires going to it, it has a sensor reading the rotation of the motor.... if yours does not have this then you should look for a paddle switch.
Mar 10, 2008 | Thermador C301U Electric Single Oven
Open Questions:
See all Thermador SC302T Electric Double Oven Questions
Thermador SC302T Electric Double Oven Logo
42 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Thermador Oven Expert? Answer questions, earn points and help others
