My Mitsubishi Tv has a green haze on the screen now.. picture is good minus that
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Need to know model number to even make a suggestion here.
Posted on Dec 22, 2012
Luvlee
  • 59 Answers
SOURCE: Yellow Haze Center Screen
The blue filter is burnt out. A very common problem in Zenith DLPs. There are 3 color filters, 1 blue (a pinkish color), 1 green (a grayish brown) and 1 red (it is red) they give you your colors for you picture. This is a simple fix.
Posted on Mar 24, 2008
  • 927 Answers
SOURCE: green haze not sharp
Good Day;
Sounds like your TV has a convergence problem. If you order KIT 10 from B&D ENTERPRISES at 1-800-458-6053 The KIT will include all parts neede and layout of part value & locations on simple paper lay out diagram. Or call FACTORY SERVICE;
1-800-448-2244.
Good Luck, big IRISH. PS or get from HIT Part X480293: kit.
Posted on Sep 06, 2008
SOURCE: Green Haze
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Posted on Oct 27, 2008
SOURCE: Tv brightness
I just bought an e 62525 on craigslist for $300 dollars. The guy had it in his garage because of a degraded picture... white out haze and virtually no black ... I surfed for similar issues most referring to the light engine. However; going back to basics. I removed the front panel assembly (approximately 16 screws including the center panel surrounding the card/rca ports in the front). The main mirror was spotless (in itself missleading) but the projection lense and the smaller mirror were frosted over with 3+ years of fine dust. I cleaned them with a simple cloth. I also noted that the foam insert surrounding the lense had gaps due to age which allowed excessive light sepage (the white out problem). I repositioned the foam as best I could. Then simply stuffed a black cloth over the foam but firmly arround the lense (keeping the foam intact as well). This blocked "all" light sepage. Bottom line is that I now have a picture quality that is flat out incredible! This is one bad mutha (shut yo mouth) tv. P.S. I'm just an average guy with an electric screw driver.
Posted on Nov 27, 2008
  • 184 Answers
SOURCE: Green Haze in middle of TV, Words not sharp
The coolant in the chambers that are part of the CRTs(picture tubes) has been contaminated by foreign matter and the high temps created by the CRTs. The coolant can be replaced but its an expensive and time consuming operation. Some of the parts needed for this repair may also be no longer available. I'd start shopping.
michtech
Posted on Feb 17, 2009
Green haze across the screen
you have a bad light engine.
Aug 19, 2009 | Toshiba 46HM95 46" HDTV
Mitsubishi 57" DLP. Replaced bulb, now picture is hazy.
Cleaning th mirror and lense will remove the haze. This oldel is much older that 2 years though.
Jan 24, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi XL30U Green Haze
This projector has three LCD screens followed by a prism to converge the screens and project the light. Lack of maintenance is the usual cause.
If the lamp is old, it will produce more and more UV light that will burn, usually the first colour, the blue LCD panel giving a greenish hue starting from the centre of the screen and working outwards.
If the filters are blocked, this will damage the LCD screens.
The screens are available from Mitsubishi but maybe cheaper to replace the projector as they are very expensive and fitting is a specialised job.
Jun 15, 2017 | Mitsubishi ColorView XL30U Multimedia...
Green haze not sharp
Good Day;
1-800-448-2244.
Aug 04, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Problems with my Phillips Rear Projection TV!!
have the coolant (glycol) in the CRT's....not as expensive as buying a new set...and sounds like it should be good as new if thats the only problem you have with it.
Jul 16, 2007 | Philips Magnavox 51MP392H Rear Projection...
Screen has a Green Haze to it........
1. CHECK FOR LEAKY Q6R1 (RED CRT PCB), Q6G1 (GREEN CRT PCB) AND/OR Q6B1 (BLUE CRT PCB). PART # 260P627020
Apr 20, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Green dot in middile of my screen
The green dot in the center sounds like a burn mark on one or more of the picture tubes inside the set, and the curved lines are telling me that you have a problem in the convergence circuits. The blue haze around everything white tells me you either have a lot of dust build up on the lens over the CRTs, or your picture tube(s) are very weak. If this set is over about 12 years old, I would replace it. I doubt if you will be able to get the green dot out of the picture without changing the tubes which would be VERY expensive.
Jan 05, 2007 | Philips 60PP9401 60" Rear Projection...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
