Question about Sony DVP-NC665P/S Multi-disc DVD Player
My Sony CD/DVD player will not turn on, I checked fuse it is OK , also I have power to the unit.
It had not been used for a while and when the wife attempted to turn it on to play a cd it would not come on. I pulled the cover and checked the fuse and it was OK, also made sure I had 110 volts to the unit through the power cord.
  • 537 Answers
SOURCE: dvd player frequently pauses or freezes while trying to play audio cd's
You tried cleaning the lens right?  That's the first thing I would do. You may have to actually open up the unit and use some windex on a cotton swap to clean the lens. Be very careful not to overwet the cotton swab. Use the other end of the swab to dry the lens.
The red wavelength of light from the laser might not be getting through the lens properly, which is used for the Audio CDs, where the higher frequency laser is used for the DVD material.
Mike
Posted on Oct 31, 2007
ThaMp3Doctor
  • 8596 Answers
SOURCE: Blue ray disc broke my dvd player
Unplug/replug the player - try again.
Also, get a firmware upgrade disc from Sony's website to try and reload the firmware.
Posted on Sep 04, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Sony CD/DVD Player DVP-NS50P not playing my avi files DVD+RW
You need to convert avi files to dvd format before burning, otherwise the player won't recognize them. Google "avi to dvd" and you'll find a number of free or pay programs that will do the conversion for you.
Posted on Nov 19, 2008
SOURCE: Suddenly "cannot play this disk" on Sony DVD/CD..every DVD...CD's work!
I have the same problem. I have a 5 year warranty from the company I purchased the unit from. I am not sure if they will replace it or not. I am reluctant to buy another one with this known issue. We have enjoyed the unit for nearly 3 years with no issues.
Posted on Nov 23, 2008
Nomodo4u
  • 863 Answers
SOURCE: My sony DVP-NS725P will not play discs
Run a DVD disc cleaner through it and see if that helps. If not then open it up and manually clean the laser pickup lens. Then give it a go. If that didn't help, then open it back up and replace the optical drive.
Posted on Feb 18, 2010
Testimonial: "Thanks for that had tried cleaning disc before but stripping and cleaning worked a treet"
No power
check ground, power and switched power connections to be sure they are hooked up properly. Also check radio fuse in main fuse box.
Jan 25, 2014 | Sony CDX-R30M CD Player
Sony DVD not responding to power
open the top cover and chech the fuse in the power supply board,if ok then check on the diodes and probably the ic for power
Dec 15, 2011 | Sony Televison & Video
I have dvd player by sony. when i try to turn on there is no power on the unit.i check already the power cord,fuse puffing cap every thing is ok.do you have any idea what other parts should icheck.
Hello
Its poser SMPS bard inside is not working properly. This board supplie low tension voltages to the other circuit boards of the device. It is a Switch Mode Power Supply [SMPS]. Normally repairing is not effective to this board. Replace the board as card basis is good. you can bought it from most of the elelctronic spare part shops at your town. There is a number printed on the printed circuit board and it is its identification. Note that number, and buy the same type. OK.
Jun 21, 2011 | Sony DVP-NS51P DVD Player
No power to the dvd player.
And you check the dvd fuse or the remote wire who comes from the stereo
Jul 18, 2010 | Sony MV-900SDS Car DVD Player
I tried to install my cd player and the ground hit another wire i think and now i have know power to the radio and i checked the fuse and did not blow
check the fuse on your auto, to see if that is ok, the one that powers your audio system, and also check the fuse/fuses for the radio unit itself.Alternatively, the unit has died
Oct 21, 2009 | Sony CDX-GT300 CD Player
No power to Insignia dvd player.
Pop the top of the DVD player and check the fuse. It's located right next to the AC power plug on the inside. If the fuse is OK, replace the DVD player. Repairs cost more than a new unit. Sony has DVD players from $ 40. Any repair on any device would cost more than that. If your lucky, the unit just took a surge and blew the fuse. Hope this helps
Oct 14, 2009 | Audio Players & Recorders
Kenwood KDV-412 In-Dash AM-FM-CD-DVD Player.. Will not turn on
I found a switch in the trailer which my wife had switched to the off position that controlled the unit. Turned it back on, and power was supplied to the player. Dumb me... I'll not forget this 'fix' Thanks for your service and reply.
Frank
Mar 27, 2008 | Kenwood Audio Players & Recorders
Problem
If the AC power source (outlet) is ok and the line cord and fuse are ok but the unit is completely dead, you may have a problem with the internal switching power supply.
Locate the switching power supply and see if there is a fuse on its circuit board.
Completely dead units are typically caused by a failure in the power supply section.
Please let me know if I can be of further assistance to you.
- Jim
Mar 06, 2008 | Sony SLV-D360P DVD Player/VCR
Sony DVP-NS55P DVD player will not power on. No LEDs light and no display message appears when the on/off button is depressed (dead). Fuse on power supply board is ok, no components look fried,...
If it is the power supply then the whole unit should be replaced. Or it indeed may be the power on button its self. Only technician with the appropriate knowledge of the particular machine will be able to tell and have the means to check it out.
Jul 31, 2007 | Sony DVP-NS55P DVD Player
Sony DVP-NC665P/S Multi-disc DVD Player Logo
81 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
