Question about John Deere Garden
John Deere x540 pto will not engage - John Deere Garden
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
nova2nv
  • 197 Answers
SOURCE: Engine dies when engaging PTO switch on a John
Check and adjust your RIO switch{reverse implement option}near the trans if so equipped.What happens when you press forward pedal then engage blades?Would also check the lower bearing on your pto clutch to see if its seized up.
Posted on Nov 14, 2009
nova2nv
  • 197 Answers
SOURCE: My 870 john deere clutch will not disengage. The
This is common for the 70 series.Clutch dics are stuck together,just short of splitting tractor you have to hit a pile of dirt with loader bucket to see if you can break it loose.
mickey813
  • 472 Answers
SOURCE: John Deere L120. Engine dies when PTO switch is pulled.
sounds like the seat switch is bad
Posted on Mar 02, 2010
Blades won't engage on John Deere x540.
I would remove the PTO switch and have a Deere dealer test it. Also on the 500 series the PTO operates through the ignition control module which is under the dash, you can see it when you raise the hood. It is black and about 2" wide x 3" long and 1" thick.
Jul 29, 2017 | John Deere Garden
John deere x495 tractor pto problem.
dami ko po pinag hirapan dito tapos mahahack lang pala Sana namn ma ibalik niyo plsssssssss mahawa na kayo sayng lang pera ko ito user:chageword12345 Pass:09464290212Angelica Inbox x
Jul 18, 2016 | John Deere Garden
8130 John Deere pto code 1883.01
Rear PTO Underspeed. Make sure correct shaft is installed. Restart vehicle and select proper PTO engagement rate in the CommandCenter. If code returns, have your John Deere dealer repair as soon as possible.
OMAR259982 8130 8230 8330 8430 and 8530 Tractors Block File OURX935...
Last website shows to me what appears to be a sensor just to the right of the icon A pointer, identifying the snap ring, in the top right photo. http://manuals.deere.com/omview/OMAR259982_19/gif/RW55322A.gif
Best of luck.
Dec 16, 2015 | John Deere Garden
John deere stx 30 pto wont engage
Check your fuse or for a broken wire( or shorted)
Jul 19, 2014 | John Deere Pto Clutch For Stx38 And Stx46...
PTO Issues
replace the pto solenoid as it has an internal short causing the fuses to blow.
Jun 02, 2013 | John Deere Garden
X595 john deere pto wont kick in
These John Deere Garden Tractors have a RIO (Reverse Implement Option) on the PTO. If your PTO is engaged and you back up, the PTO will automatically stop. To reset it, depress your PTO engagement switch to the OFF position. Take your foot off the reverse pedal. Pull up on the PTO engagement switch. The PTO should restart. To use the RIO feature, pull up on the PTO switch for a second or two just before you step on the reverse hydrostatic pedal. The yellow RIO indicator light should come on your dashboard and you can now back up with the PTO still running. Works great for snow blowing when I don't want to keep resetting my electric PTO clutch to keep restarting my snow blower.
If your PTO will not restart, you may have a PTO switch starting to fail, or a likely logic problem in your electric PTO control module, or one of your forward/reverse indicator switches, which is linked to your PTO control module along with the overtemp circuit, is stuck/faulty.
Feb 20, 2013 | John Deere 26HP Hydrostatic 54" Riding...
John Deere LX173 pto will not engage. Wet recently
Probably the pto switch. Find the 2 wire 'T' plug from the PTO clutch and disconnect. With a voltmeter across the the 2 spades on the tractor side of the plug you should get 12 volts DC with the PTO switch on ( you may need to sit in the seat ). If you get 12 volts at the plug its probably the PTO clutch. If no power then its a fuse or the PTO switch
Oct 24, 2012 | John Deere Garden
John deere 2010 tractor. pto grinds and wont engage
Mar 11, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
511 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
