Question about Sony DVP-NC665P/S Multi-disc DVD Player
My Sony DVP-NC665P will not turn on. I checked the fuse and it is OK, Also checked to make sure I had 110 volts in unit through power cord. Help
This is a great player and I hate to lose it, is there wsomewhere I can have it repaired
4 Suggested Answers
bluegreenash
  • 661 Answers
SOURCE: Sony DVP-FX810 Portable DVD Player, region code 4 to mutiregion code.
1. Switch on the player
2; open the CD compartment
3. Enter the following code (using the remote): 2812
4. Highlight the region
5. Change to 9 (for Multi-region) using the 'Enter' button
6. Hit 'Clear' to exit
check with different region DVD
Posted on Oct 03, 2008
  • 4234 Answers
SOURCE: sony player dvp-cx850d won't read cd or dvds. need to reset
This is not a problem that a reset will resolve. If you can gain access to the lens, try cleaning the lens using a cotton swab and alcohol. If that does not resolve the problem, the spindle motor may be defective. This is the motor that turns the disc. Once a disc is recognized as being loaded, the disc is spun up. If it does not get to speed fast enough, it will fail to read.
The bottom line is that without seeing the unit, I can not state exactly which scenerio you have here.
If the cleaning does not resolve the problem, I would suggest you request a detailed estimate from an authorized Sony service center.
Dan
Posted on Mar 10, 2009
  • 308 Answers
SOURCE: How to make Sony portable DVD player DVP-FX810 region free
Do a google search for 'region hack and your model #' Not all players can be hacked and don'y pay anyone for the info. Usually a scam.
Posted on Apr 14, 2010
Standby mode
When the STANDBY indicator
flashes
Immediately unplug the power cord
and check the following items.
• If your unit have a voltage selector,
is the voltage selector set to the
correct voltage?
Check the voltage for your region,
then make sure the voltage selector
is set correctly.
• Are the + and - speaker cords shortcircuited?
• Are you using the supplied
speakers?
• Is anything blocking the ventilation
holes on the rear of the unit?
After checking the above items and
fixing any problems, plug in the power
cord again and turn on the unit. If the
STANDBY indicator still flashes, or if
the cause of the problem cannot be
found even after checking all the
above items, consult your dealer.
Dec 20, 2012 | Sony Mhc-gn1300d 3 Dvd/vcd/cd Changer...
I have dvd player by sony. when i try to turn on there is no power on the unit.i check already the power cord,fuse puffing cap every thing is ok.do you have any idea what other parts should icheck.
Hello
Its poser SMPS bard inside is not working properly. This board supplie low tension voltages to the other circuit boards of the device. It is a Switch Mode Power Supply [SMPS]. Normally repairing is not effective to this board. Replace the board as card basis is good. you can bought it from most of the elelctronic spare part shops at your town. There is a number printed on the printed circuit board and it is its identification. Note that number, and buy the same type. OK.
Jun 21, 2011 | Sony DVP-NS51P DVD Player
Sony nc665p dvd player only plays in Black and White, how do I fix this?
How is it connected up ?
Is the machine a NTSC version and your tv a PAL ?
Feb 05, 2011 | Sony DVP-NC665P/S Multi-disc DVD Player
My aprilaire 700 isn't coming on (no water flow). The front part of the unit has fallen off the furnace twice (held on by plastic nubs/slots...) and blew the furnace fuse/ and circuit breaker probably...
Check for voltaged at the solenoid valve. This will either be a 24 volt or 110 volt solenoid valve. Confirm power into the unit 110 volts. If you have power into the unit and no voltaged at the solenoid valve on a call for humidification at the humidistat than the circuit board or the step down transfgormer has failed.. If you do have voltage at the solenid valve than the valve has failed.
Jan 26, 2011 | Aprilaire 700 Humidifier
No power for Sony ICFCD855V Dream Machine.
Power supply seems to be 12 volts. I have ICFCD855V's and the power cords on both broke just past the strain relief on the power supply. That shorted the supply and blew the fuse (1.6 amp). I soldered in a new fuse and the supply (with no load) puts out 12VDC. Since it happened to 2 in my house I can't believe Sony doesn't have a recall on these things
May 10, 2008 | Toshiba Sony ICFCD855V Clock Radio
Cannot Close Sony DVP-NC665P 5 disk tray
There is a possiblity that he may have shifted the unit while discs were in it causing the discs to slip off the tray and into the unit. You have to open the unit to check if there are loose discs.
Nov 12, 2007 | Sony DVP-NC665P/S Multi-disc DVD Player
DVP-NC665P power surge.
I would first check to see if it had a blown fuse..
even if sony doesnt have the parts electronic companys sell common electronic parts like mcm electronics.
Sep 16, 2007 | Sony DVP-NC665P/S Multi-disc DVD Player
Black & white picture
Check input type on what ever you are viewing the DVD on. Sometimes there are menu settings on the TV ~ monitors.
Jul 04, 2007 | Sony DVP-NC665P/S Multi-disc DVD Player
Sony DVP-NC665P/S Multi-disc DVD Player Logo
222 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
