Question about LG 4775er2002a Door Hinges for Wm2277hb Tromm Front Load Washer
How do I replace the drain motor on a MW2277HB washer without removing the top and front panels?
    Top Expert:
  • LG Master
  • 9,472 Answers
It can't be done. You would need to remove the front panel.
Posted on Nov 27, 2012
5 Suggested Answers
SOURCE: How do i remove panel from front load washer
You can download a basic but somewhat helpful service manual here http://136.166.4.200/contents/Laundry/WM2277.htm that has some disassembly instructions and exploded view diagrams, explains the troubleshooting mode.
Posted on Jan 04, 2008
  • 1531 Answers
SOURCE: My tromm frontload washer is not draining. I
in order to check the main drai hose the whole front panel needs to come come off.This is done by removing the lid.
then remove the screws that hold the main control board, then you need to remove the rubber boot from the front panel.then remove the screws that hold the front panel on the machine.
Posted on Feb 22, 2010
  • 57 Answers
SOURCE: Washing Machine not draining at all
either the pump is not working, when switched to drain do you hear a noise if not the pump not working if so then likely a blockage check filter, outlet hose and stanpipe
Posted on Mar 30, 2010
  • 3 Answers
SOURCE: Need to remove front panel of washer
if you have manufacturers manual should tell how if not there's alot of videos on you tube....
Posted on Aug 17, 2012
How to install samsung Part Number DC31-00054A (AP4202690)
1. Unplug the washer. 2. Unscrew the 2 screws at the top back of the washer that secures the top of washer pane, slide it back and lift off, remove and set aside. 3. Pull out the dispenser tray and depress the tab at the back to full remove. 4. Remove the dispenser mounting screws, slide the dispenser back. 5. Carefully pull the control panel off from the top, disconnect the two wire harnesses and set the control panel aside. 6. Use needle nose pliers to remove the retaining wire and spring from the door boot seal, pull the seal away from the lip of the front panel. 7. Remove the 3 door mounting screws to release door latch assembly from the front panel. 8. Open and detach the filter access door and release the drain tube from the retaining tab. 9. Remove the screws inside the filter housing securing the front panel. 10. Carefully lift the front of the washer up and support it. 11. You can now remove the screws at the bottom securing the front panel(if your has these, mine were missing). 12. Now is also a good time to detach the pump assembly wire retainer from the base(small white plastic tab sticking downward). 13. Remove the support and gently lower the washer back down. 14. Remove the mounting screws on top of the front panel. 15. Now, use a flat head screw driver to depress the locking tabs to release the front panel from the frame. 16. Detach the recirculation hose from the retaining brackets on the inside of the front panel and set the panel aside. 17. Uncap the drain tube, and drain the excess water, then recap the tube. 18. Release the retaining clamps securing the hoses to the pump assembly and slide the hoses off.(be prepared for some water to spill). 19. Remove the two screws securing the pump assembly to the mounting bracket. 20. Now, push the assembly back to release it from the base. 21. Next, detach the drain pump cover(top white plastic cover) and disconnect the wires, now remove the 3 mounting screws and pull off the old pump. 21. Install the new drain pump by properly aligning it on the assembly. 22. Replace the mounting screws to secure. 23. Connect the wires to the new pump and snap on the cover. 24. Position the pump assembly into the cabinet base by inserting the mounting tab into the slots in the base, then push forward. 25. Replace the screws to secure the assembly to the mounting bracket. 26. Snap the wire retainer into the base. 27. Reattach all of the hoses to the appropriate ports on the assembly and position the retaining clamps to secure. 28. Replace the front panel, by aligning the slots in the panel with the tabs on the base. 29. Secure the recirculation hose in the retaining brackets, making sure the door latch is inside the cabinet and snap the top half the panel into position. 30. Replace the screws on top. 31. Lift and support the washer, then replace the screws on bottom. 32. Remove the support and lower the washer. 33. Replace the 2 screws in the filter housing. 34. Secure the drain tube under the retaining tab. 35. Reattach the filter access door and snap it closed. 36. Now, realign the door latch assembly in the front panel, and replace the mounting screws. 37. Align the boot seal on the front lip of the panel. 38. Replace the retaining wire and spring to secure. 39. Replace the control panel, by first reconnecting the wire harnesses. 40. Now, insert the control panel tabs into the slots into the trim and snap the top half of the panel into place. 41. Reposition the dispenser and replace the mounting screws. 42. Slide the tray into place. 43. Reposition the top panel by aligning the edge of the panel with tabs on the support bracket, then push forward.
44. Replace the screws at the back. 45. Plug the power cord back in. Your done!
Your washer should be ready to use now!!! Good Job!
You should find this video useful, even if it is for a different model washer, it is what I used as a reference. Drain Pump Replacement part DC31 00054D Samsung Washer Repair
Sep 06, 2014 | Samsung WF448AAP Front Load Washer
How do I check the electric connection to Kenmore Elite drain pump
First, UNPLUG the washer before servicing. Remove the lower access panel directly below the washer door by locating and loosening the torx (7mm) screws under the bottom front of the panel. With the screws removed, the panel will drop down and come off.
NOTE: For better access the the screws, place a 2x4 or under the front two feet of the washer. This will raise the front slightly, so you can access under the lower panel.
With the panel removed, the drain pump motor is located directly in front. The motor electrical connection, consists of a small electrical plug. Remove the plug and check the pins at the MOTOR with a multimeter on the lowest resistance scale. A good motor winding reading is about 12.3 ohms. Anything higher, usually means the motor is shot and needs to be replaced. If the motor windings read normal, you need to trace your wiring from the motor to the Central Control Unit (CCU). This is the main computer of the washer (located directly behind the drum at the top of the washer. This can be accessed by locating and removing the screws in that hold the top panel in place in the rear of the washer. With the screws removed, the panel will slide back, then lift off.
Check to make sure the wires are not broken or loose anywhere. Disconnect and reseat any connections to make sure you have good contact.
Generally, the pump motors fail on these washers and cause error codes. In the majority of the cases, the pump is either clogged, or the motor needs to be replaced. Remove the access cover on the pump housing to check for debris, or anything that could be caught in the pump impeller, preventing it from turning. Make sure you remove any residual water in the washer if you want to avoid a messy clean up. An easy way to do this is to remove the drain hose at the standpipe and pull a vacuum on the line with a wet/dry shop vac. This removes all the residual water in the tub and drain lines.
If replacement parts are required, I have had great luck with the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites also include helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need.
HELPFUL HINT:
You can save money by only purchasing the pump motor instead of the entire pump assembly. The motor comes off the pump housing by removing three screws. Make sure you install the rubber o-ring gasket to maintain a good seal. Apply a thin film of petroleum jelly on the o-ring as an added measure to get a good seal. The appliance websites generally only sell the pump as an ENTIRE assembly. However, I have found reputable sellers on Ebay, that sell just the motor. Do not buy anything USED as you cannot guarantee how long the motor will last.
If you need further assistance, please let me know. I hope this helps you.
Oct 30, 2011 | Kenmore Elite 45986 Front Load Washer
My code is E21 how do i fix this without paying for a service call. My warrenty ran out 3 weeks ago imagine that
E21 indicates a drain pump error or slow draining. If it is a clogged filter, you fix this yourself. (Standing water is usually still in the washer with this error.) Unfortunately, if it is something else, a service call may be needed.
Unplug the washer before starting the following procedure.
The first step is to check if your washer has a lower access panel. If it does, then remove the panel. Find the drain motor and the two hoses (drain and washer sump) that connect to it. Have a bucket ready to catch the water from the hoses. Since the hoses are connected by hose clamps you will need a set of pliers to loosen. Remove the hoses and let the water in them drain out. Check for any clogs and check the coin catcher filter (it's inside the main hose) for foreign objects. Remove the blockages. Then check for around and inside the pump (and the impellers) for any object and remove anything that doesn't belong.
If your washer doesn't have an access panel, you can get to the drain motor from the back, bottom or front of the washer. Pull off the panel (usually screws hold it in place) if you are accessing the unit from the front or back. If you go from the bottom, remove the storage drawer and pedestal if you have installed those. Then remove the bolts that hold the drain motor to the washer frame. Remove the wiring harness and the drain and sump hoses. The pump can then be removed and cleaned. Follow the directions above to check for clogs or foreign objects.
Then reassemble the washer (pump, drain motor, hoses, wiring). Replace the panel. Plug the unit back in and see if the unit will drain without the error. (Just try the drain/spin cycle and see if the unit spins rapidly. There is not reason to do a full wash.)
If you add a comment with your Frigidaire washer model number, I'll be glad to give more specific information for additional repair options.
Aug 22, 2011 | Frigidaire ATF6000ES Front Load Washer
Hi, I can't find my manuel and the one on line does not have troubleshooting. My washer will agitate but will not drain or spin. I can't figure out how to access the motor or belts without a schematic of...
If you can hear nothing in spin cycle, you likely have a faulty lid switch. This washer will not spin or drain if it thinks the lid is open. The front panel will come off if you remove the two screws near the bottom of the front panel. Once removed, the panel will pull down about 2" then pull off. I have included a link to the breakdown pictures to help in disassembling it.
Breakdown
Kelly
Mar 23, 2011 | Frigidaire FEX831CS Top Load Stacked...
How do you change a pump on a Samsung WF448AAP washer? Need to get in from the back?
Dec 07, 2010 | Samsung WF448AAP Front Load Washer
Yesterday made a grinding noise and leaked water out on the floor from under unit.it still works
The noise would be indeed coming from the water pump.
To clean the pump on this top-loader you have to unplug it, pop the top open, and remove the front face of the cabinet to expose the motor and pump.
Slip off the two metal clips hugging the pump to the motor. Place a towel under the motor before detaching the hoses - there's a plastic drip pan between the pump and motor to guide the water away from the motor.
Unclamp the two hoses from the pump by squeezing their spring-clamps with pliers and sliding them further down the hose. Pull the hoses off by lifting the pump off its axle and pulling it out while wiggling the hoses loose. Check if anything jammed in the pump - it must have fallen to the outside of the basket but inside the drum during the last spin cycle, and went down the drain hose. Check the pump for damage and replace if necessary.
For future troubleshooting, remember that a clogged pump causes squealing, diminished spin speed, and slow drainage.
The first thing I would do is to inspect the inner tub. Empty your washer and carefully check all holes inside the inner tub and under the agitator for any foreign objects and remove if any.
If it's nothing there then you have to remove the front panel. Tape the lid to the top panel. Using a putty knife push in to release top panel clips on both sides. Lift up the top panel toward the back.
Remove the screws on top of the front panel on each side. Pull out the top of the front panel toward yourself for about 30 degrees and release it from the bottom clips. Now you have an access to inside the washer. Run the washer without the front panel and try to locate the sound. Let me know your findings.
Feb 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I think a overloaded the washer and it wouldnt spin.
Frigidaire washer will not take a overloaded tub without causing belt problems.
Unplug the washer.
Remove the 2 screws on the very bottom of the front washer panel.
Slide the front panel down slightly and remove it from the cabinet.
Inspect the belt around the motor pulley and transmission.
If it is worn at all it needs replacing.
You could plug the washer back in and set it to Spin cycle and watch for the motor to turn and the belt slipping to verify a bad belt.
Keep your hands,fingers and tools away from all moving parts.
Jan 24, 2010 | Frigidaire FGX831F Top Load Stacked Washer...
Water does not empty from tub
Unplug the washer.
Remove the front panel. putty knife needed.
Remove the drain pump and clean it out as well as the drain hose from the tub to the pump.
If they are not blocked replace the pump motor.
Feb 21, 2009 | GE WBSE2090A Top Load Washer
Maytag washer
sounds like you're suffering from the pump belt either stretched due to overload and overheating the belt, or the belt is off the pulley.
You can remove the front cover by removing two screws near the bottom of the front panel. Tip the bottom of the front panel outward and then disengage the upper clips as you pull forward. This exposes the pump, motor and you can reach underneath to the pulley and the belt. The motor spring holds the tension on the belt. If the belt is damaged, replace. Check the pump to make sure nothing got sucked inside... Maytag's pump are opaque plastic so you can see inside without removing the hoses... This is usually the reason for a tub that won't spin or drain... Good luck let me know.
Jan 19, 2009 | Frigidaire FWS833A Top Load Washer
Clogged washer pump
you have to take out the little motor that drains the water and clean it up , first you open the front panel or back panel depending of the model , second follow the DRAIN HOSE to where its attached to the DRAIN MOTOR , remove the motor for cleaning , its probably clogged.
Apr 05, 2008 | GE WBSR3140DW Top Load Washer
Open Questions:
LG 4775er2002a Door Hinges for Wm2277hb Tromm Front Load Washer Logo
87 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
