Question about LG Washing Machines
How to replace the drain motor on my WM 2277HB
Can I do this WITHOUT taking the top or front panels off of the machine ?
    Top Expert:
  • LG Master
  • 9,472 Answers
Can't be done.
Posted on Nov 27, 2012
MNTECH
  • 1543 Answers
SOURCE: LG WM-2277HB washer does not drain and make rattling noise.
You will need to replace the drain pump motor. The pump impeller has separated from the motor shaft. You can push it back on, but it will just come off again. I have not tried adding adhesive because I didn't want a call back. That may work if you want to try it. To replace pump motor:
Take the rectangular recess out by using a putty knife on the left or right side, Remove phillips screws mounting pump. Pull machine forward about two feet to allow you to tilt the machine back to lean it against the wall. Reach under to access the pump. It is held in place by a plastic tab you can depress to remove, but if you break the tab, don't worry, as the mounting screws will hold your pump in place just fine when reinstalled. Remove pump by disconnecting hoses and electrical plug. Change out pump motor (three phillips head screws)
Posted on Nov 16, 2008
MNTECH
  • 1543 Answers
I would guess that the impeller has come off the pump motor shaft. You can disassemble and push it back on, but it will come off again. I don't know if some type of adhesive would work, but I just replace the pump motor.
Drain water from small drain hose (or by removing filter) Remove the screw in the plastic recess by the filter, then use a putty knife on the left or right side to pop out the recess. Remove two more screws holding pump body to front frame of washer. Pull washer about 18 inches away from wall and tilt it back to lean against wall to allow access to the pump through the large rectangular hole in the base of the washer. There is a plastic locking tab holding the pump body to the plastic washer base, but don't worry if you break that, as the screws (removed earlier) will hold the pump back on just fine. Pump motor is held onto pump body with three more screws. Replace pump motor with a new one and reassemble. On a difficulty scale of 1 -10, this one might rate a 4.5 or a 5. Not too bad.
Leaking is rarely, if ever, caused by the drain pump. Small leaks can come from using too much soap, which backs up in the dispenser area and leaks down inside the machine, or larger leaks from a cut in the door gasket.
Posted on Apr 04, 2009
SOURCE: LG wash machine # wm 2277 hb front loader display flashes LE wont
We had the OE message come up and did the above procedures...that didn't fix it. I removed the dual pump modules (they come off in one piece...one is the recirculating pump, the other is the drain pump). Turns out, the drain pump impeller design sucks. Even though it turned when I put power to the pump, that doesn't mean your pump isn't bad. Once it is under load pumping water, the impeller can slip where the pin connects to it from the motor. We replaced the motor for $60 and that fixed the problem. Our unit is at least three years old and we have a family of four, so it does get used quite often. Nobody told us about the filter at the bottom of the unit and I figure if we knew this ahead of time, we probably could have avoided the impeller issue...but it is still a sub-par designed motor/impeller. The new one I ordered looks like an updated design so I don't see this happening again. It is quite easy to remove and replace the pump, btw.
Posted on Feb 21, 2010
  • 35 Answers
SOURCE: I have am lg wm-1832c front loader. Rinse cycle fill problem
the pc board is bad must replace.
Posted on Apr 10, 2010
SOURCE: I neet o replace drain pump on a LG wm1832cw model
its not easy, but you'll have to lay the washer on its back and take off the crate like bottom panel. Discontect all the hoses. Disconnect the electrical line going to the pump. If you can, try and seperate the pump motor from the housing by unscrewing two screws on the housing, which will seperate the motor from the housing, If you cant get to it, I actually broke the screws on the drain filter housing to get it loose. I secured it back with the other front loading screw and some gorilla glue, shouldnt be a problem. I should at least get another 6 years out of this pump. Good luck.
Posted on Jul 10, 2010
My LG WM-2277HB is leaking water
in what cycle is it leaking?
and from what area?
Dec 20, 2012 | LG WM2277HBW XL Front Load Stackable...
2277HB washing machine blew switch for second time have replaced the hall sensor and the motherboard. motor smells hot
The motors might be freezing they do get jammed with **** after time pull the motor to see if it's spinning if not look at the shaft clean it to wear it will spin still nothing the motor has froze time to rebuild it or get a new one
Sep 11, 2012 | LG WM-2277HW Front Load Washer
My lg wm 2277hb washer stopped and had a le code on the displat i un plugged it then plugged it back in it worked for a day then stop working agaAIN NOW THE display wont light up
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Apr 16, 2011 | Washing Machines
My LG is a few years old, Model WM1832CW and seems to work in all modes except rinse. It just started this morning and sounds like its slipping and grinding and won't pump the water out. any suggestions....
Replace the pump motor. On your model, it can be done without removing the front panel. Open access door at bottom left of front panel. drain water out small hose. remove screw from plastic recess and use putty knife at side of recess to remove plastic recess. remove screw holding pump. pull machine out 2 feet from wall and tilt it back to rest back edge against wall. depress plastic tab in base to release pump. remove hoses and unplug electrical connection to pump. remove 3 screws holding pump motor to pump housing. install new pump motor and re-assemble.
Nov 27, 2010 | LG WM-1832C Front Load Washer
May 31, 2010 | LG WM-1832C Front Load Washer
If the drain pump is clogged how do you clear it. I cleared the panel on the bottom and also blew out the water line, what am i missing?
If you cleaned out the filter behind the access panel on the lower left and still get no pump out, you have either a bad pump motor or the impeller came off the pump motor. In either case, the pump motor needs to be replaced. If your machine is not on a pedistal it can be changed by tipping the machine back against the wall and working on it from underneath, otherwise, the top and front panel have to come off to get at it.
Sep 23, 2009 | LG WM-2277HW Front Load Washer
Apr 04, 2009 | LG WM2277HBW XL Front Load Stackable...
Nov 16, 2008 | LG WM-2277HW Front Load Washer
Lg washer serial # 308kw00211
That OE is really DE (drain error). Open the access door at the lower left on the front of the washer. Drain remaining water using the small hose. (at least if it is not plugged) Unscrew and remove the large knob. Clean out filter. If filter was clean, you may need a new pump motor, or something may have made it past the filter and is jamming the pump impeller. You can remove the pump without taking the front off the machine. Do an "Ask Me" if you need to do that, and I'll give you further advise.
Oct 05, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
18 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
