Question about Zodiac Pool Systems Polaris 480 Pro Vinyl Pool Cleaner Less Pump
480 cleaner stops wheels seem loose - Zodiac Pool Systems Polaris 480 Pro Vinyl Pool Cleaner Less Pump
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 22 Answers
The axels are held on by a retainer attached with screws. I had a similiar problem with my polaris. Had to open up and locate the loose screws and re attach. Also the wheels are held on to the shaft with a c-clip. May be missing and the wheel fixin to come off
Posted on Dec 01, 2012
How to repair the front left wheel and height adjustment assembly on a Kirby G10 vacuum cleaner
The wheels are held on by a screw behind the wheel guard, i suspect your height adjuster has come loose off the spline, this can be simply tapped back onto the axle
Jul 21, 2017 | Kirby G10 Sentria Vacuum Cleaner...
Robot is in the pool and seems to be on (water is moving above it) however the wheels are not turning
If the wheels stop working on these pool cleaners, it is usually something lodged in the drive train. Check the wheels and axles for leaves, cloth, or other debris and remove if necessary.
Sep 04, 2010 | Smartpool Dolphin Robo - Kleen Above...
My Polaris 380 just stop moving the pump was run and had good pressure turn one wheel they all turn freely also tail dose not move
Check several things if these pool cleaners stop moving. Check the filter screen in the in-line filter and clean, if necessary. Clean the skimmer basket, pump basket, and pool filter. Check all of the hoses,
connections, and swivels for leaks that could cause loss of water pressure. Make sure that your wheel RPM is between 28 and 32. Adjust your thrust if necessary to get RPM to that level.
Aug 03, 2010 | Polaris 380 In Ground Pool Cleaner
Ticking noise in rear of 650 V star
lift rear end ensure wheel is straight, chain will tick if not running true. next step remove chain and turn wheel by hand, listen for noise, wheel should spin freely when spun, like once or twice around before it stops. sometimes also ticking sound from drum brake is just a loose lever from the brake pedal to drum. pads will not tick. to be really safe, remove wheel and take apart.
Aug 28, 2009 | 2003 Yamaha V Star Custom
Polaris 380 wont run when vertical
The drive belts are loose. Replace the drive belts are at least take the cover off inspect and tighten. The adjustments are the axle blocks. Tighten to where there is about an 1/8" tension while lightly pushing on the belt.
Aug 27, 2009 | Polaris 380 In Ground Pool Cleaner
Wheels on polaris don't turn. Is there a way to tighten belts
Replace the belts.($30) Tighten with an 1/8" play. Also check the wheel bearings. If the wheels wobble they also need to be replaced
Jul 23, 2009 | Polaris 380 In Ground Pool Cleaner
2000 intrigue, seems like right front wheel jerks, 3.5, 153k mi
The "jerking" can be normal because that is the wheel that the power is going to..
If the jerking is "too much" it could be out of allingment or could be a warn out bushing or a bad ball joint in the front end.. Jack up the front of the car (be safe) leaving the front wheel hanging free.. **** the wheel left to right.. You should be able to see if anything is loose or not moving properly..
Jul 08, 2009 | 2000 Oldsmobile Intrigue
Zodiac Pool Systems Polaris 480 Pro Vinyl Pool Cleaner Less Pump Logo
76 people viewed this question
Top Zodiac Pool Systems Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Zodiac Pool Systems Pool and Spa Expert? Answer questions, earn points and help others
