Question about Panasonic KX TGA641 Cordless Phone
Can't synch Panasonic KX-TGA641 to base
I bought a replacement phone to add to my 3 other handsets, but are unable to synch the new phone. I have unplugged the base unit and taken batteries out of phone then plugged them both back in with no success.
Noggin
  • 944 Answers
SOURCE: Hard reset of KX-TCD580 Base
Go to this link; http://panasonic.co.uk/customer-Support/download-centre.asp and input "KXTCD580" in the search box - after a few disclaimer screens you get to the manual for your phone. page 29 details reset for the handset Page 32 details base unit reset Page 48/49 details cancelling handsets to the base Hope this helps, please post again if you are still having problems with your phone :)
Posted on Apr 01, 2007
SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
Posted on Jan 16, 2008
SOURCE: Panasonic KX-TGA101S base not charging.
PyroPC Man is right! Thanks!
Posted on Mar 18, 2008
  • 3 Answers
SOURCE: Handset voice very low and LCD display is blank
My 1740 handset volume was also low. As a shot in the dark I changed the speaker and it fixed the problem. I got a new speaker from www.panasonic.com .
Posted on Aug 13, 2008
SOURCE: adding handset to Panasonic KX-TGA542M phone. ? how to ?
I ordered a new kx-tg560m handset for my kx-tg5632 base unit, but the enclosed instructions for registering it with the base unit were wrong. Fortunately, I found the old quick setup guide in my files.
If you do not have the same base unit and handset, go to the URL:
http://www.panaxonic.com/RegisterYourHandset.
1. On the handset, press [MENU], then press [0][0]. The handset displays "Refer to manual to prepare base. Then press OK->"
2. On the base unit, press [SELECT] until the desired extension number [H1, H2, H3, or H4] is displayed on the base unit, then press and hold [CALL] until the CHARGE indicator flashes.
3. On the handset, press the [OK] softkey.
When the handset is off and sitting in the charger, the handset's extension is displayed in the upper right corner.
Posted on Nov 22, 2008
Can I get replacement phones (3) for Panasonic KX-TG6843B 6.0 3-Handset Cordless Telephone? This phone blocks up to 250 calls. If I keep the base, will I keep my blocked numbers.
The stored block numbers should be saved. The database is in the base's memory. Since the KX-TG6843 base can support a total of 6 KX-TGA680S handsets, you can purchase and register 3 new handsets. If needed, you can de-register the old ones from any working handset and then add even more. See page 35 of the manual, ftp://ftp.panasonic.com/telephone/om/kx-tg6841_mul_om.pdf . Additional handsets are available from Panasonic, http://shop.panasonic.com/support-only/KX-TG6843B.html , Scroll down to the Accessories section and expand it. Amazon.com also has the handsets: https://www.amazon.com/Panasonic-KX-TGA680S-DECT-Accessory-Handset/dp/B00BS4D2CU .
I hope this helps.
May 30, 2017 | Panasonic Lands Phones
I need to add that the base model number is TG-6431 that is with the Panasonic Model TGA641 I previously asked about changing message. Didn't even think about them having different model numb
Go to support at Panasonic.com and download the manual. It's likely to be the same for various numbers of handsets (last model digit 1-5), and same year families that use interchangeable handsets, with minor feature differences. Search using the model number for the system, on the bottom of the main base.
Jan 21, 2015 | Panasonic Lands Phones
How to reset my recording on the answering machine KX TGA641
The KX-TGA641 is the handset. You need to refer to the documentation for whatever answering machine you have connected to your phone line. Failing that, please repost your question identifying the answering machine.
Feb 18, 2013 | Panasonic KX TGA641 Cordless Phone
Record new message
Assuming your KX-TGA641 handset is mated to either a KX-TG6431 or a KX-TG6441 base, follow the instructions on page 32 of the manual.
Apr 30, 2012 | Panasonic Lands Phones
It said base no power
Remove then replace the batteries from the hand set. You should now get dial tojo.
Oct 25, 2010 | Panasonic KX-TGA101S Cordless Handset
Panasonic KX-TGA641 handset - the line cuts off as soon as I press the speaker button
After following the instructions in the operating instructions manual multiple times, I called Panasonic at 800-211-7262. I spent at least 10 minutes with support and what it came down to was unplugging the original base unit and taking the batteries out of the new handset. Then we followed the same directions and it finally worked. Should have known to unplug to reset, seems to be the case on every piece of equipment these days. Good luck!
Aug 24, 2010 | Panasonic KXTGA641T Phone
Kx-tga641 where iiiii8you plug in the phone cord
Let me guess. The rest of the story is you got it at a really good price and it didn' t come with a manual. Is that close?
Here's the manual http://service.us.panasonic.com/OPERMANPDF/KXTGA641.PDF
You get to find your own TG6411.
Carl
Jul 07, 2009 | Panasonic Lands Phones
Need to clear out a used kx-tga270s handset
press function, initial setting, registration, deregistration, enter 335(deL) and then press Ok (right button on screen).
Once that is done press mute on the base unit and Ok on the hanset (right button on sreen)
Mar 28, 2009 | Panasonic KX TGA270S Cordless Expansion...
Got instruction to unregister KX-TG6074B
If this error message displays on your handset, please follow the instructions below to deregister your old handset before registering a new handset.
1) On the base unit:
Press: FUNCTION or PROGRAM
Button name varies by phone model.
2) Press: MUTE
3) Enter the numbers 3, 3, 5, #
4) Enter the handset number (1 to 8)
Mar 14, 2008 | Panasonic KX-TG2740 Cordless Phone
Panasonic KX TGA641 Cordless Phone Logo
60 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
