Need manual for gateway mother board E 4100 CONNECTOR
I HAVE AN E MACHINE DESKTOP WITH 3 WIRING ON THE FRONT PANEL BUT THE THING IS I HAVE A MOTHER BOARD MY POWER SWITCH WAS ACTING UP LATELY WHEN TURING IT ON, I HAD TO UNPLUG THE WIRING IT GOT POWER LED HDD LED POWER S/W AND TRYING TO RECONNET THEM I NEED THE MANUAL TO DO SO
  • 3,606 Answers
Hello download the user guide here:
http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=2647
Unzip the file and you need adobe reader to read content.
If i am wrong by the model select it here:
http://support.gateway.com/product/?cmpid=topnav
Good luck
Posted on Nov 27, 2012
  • 3 Answers
SOURCE: T2958 motherboard connections
Concerning the pin locations and polarity they are printed on the motherboard close to the pins. Also, your power supply is failing. I have a customer with the same problem, the power supply needed to be replaced and also the motherboard because it would not even boot to post.
Posted on Aug 20, 2006
Mark_Webber
  • 472 Answers
SOURCE: My ASUS P4T533-C Manual is
This is the bit your after I believe...
Posted on Apr 18, 2008
SOURCE: emachine W3400/ front panel connections
they have to be plugged in horizontally although it is possible to plug them in vertically because the pins are evenly spaced either way. they are color coded just not like you would expect for example one plug has a green wire and a white wire the green side goes to the green pin and the white side goes to a green pin with a white cross you have to look close because there are several green pins which is what threw me off do this with all three plugs
Posted on Apr 19, 2008
cinek79
  • 320 Answers
SOURCE: NEED POWER SWITCH WIRING FOR A EMACHINE T-3095
check on the motherboard there should be a small prints on it near control panel.
Posted on Mar 07, 2009
SOURCE: connecting front panel leads of generic case to 4600 motherboard
-MrSlickShoes
Posted on Mar 20, 2009
How to connect power switch to mother board
http://www.intel.com/support/motherboards/desktop/dg41rq/sb/CS-029925.htm
Click on -
Intel Desktop Board DG41RQ Product Guide - English (PDF)
Bookmarks menu to the left -
1) Click on the + sign to the left of -
1 Desktop Board Features
Click right on - Desktop Board Components
Or go to Page 11. (Adobe Reader page number box at top)
Front Panel header location marked by P, in the figure.
2) Click on the + sign to the left of -
Connecting to the Internal Headers and Connectors,
in the Bookmarks menu.
Click on - Front Panel header
Motherboard mounted in computer case, the Front Panel header is in the bottom/right corner, above the top black SATA connector.
Two rows of contact pins.
The Top row is numbered EVEN.
Starting at the Left side going across to the Right, Top row;
Pins 2, 4, 6, and 8. There is NO pin 10.
The Bottom row is numbered ODD.
Starting at the Left side going across to the Right, Bottom row;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
Pin 1 is for the Positive wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. Probably 5 Volts DC for factory testing.
D) Pins 2 and 4 are for the Power On LED. (Light)
This IS for a -> 2 wire LED. (Light)
Pin 2 is for the Positive wire.
If the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
To the left of the Front Panel header is a 3-pin header.
This is the Alternate Front Panel LED header.
If you have a -> 3-wire LED, it connects here.
Also wanted you to have the motherboard manual.
Regards,
joecoolvette
Nov 04, 2012 | Intel DG41RQ Motherboard & Core 2 Duo...
Need wiring diagram for client pro 365
What was your original MOBO? It should help you identify the connections to your chassis/front panel.
Typically you will have USB, audio, ground, power supply and switching/reset lines.
Often the connectors are not compatible and you need to improvise.
A manual appears to be here for Intel 915GRV uATX Motherboard (ClientPro 365) (MBD001246-00):
http://www.mpcdrivers.com/apps/compdeteb4e.html
Use at your own risk. MPC died some years back and this is the official MPC/Gateway support site per Wikipedia http://en.wikipedia.org/wiki/MPC_Corporation
Oct 15, 2012 | MPC Computers ClientPro 365 PC Desktop
I need a wire diagram for a Gateway Mother board MCP61PM-GM
Carole,
The front of the computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
Would this be what you require, or more extensive?
From a fellow FixYa expert,
http://www.fixya.com/support/t614458-hp_mcp61pm_hm_motherboard_diagram
I know it states MCP61PM-HM
The 10-pin ( actually) Front Panel header, is the same across the board, for ECS motherboards.
For additional questions please post in a Comment.
Regards,
joecoolvette
http://www.playtool.com/pages/psuconnectors/connectors.html
Oct 09, 2012 | Computers & Internet
Gateway 500GR Mother board Connector S Wiring
You are correct so far.
This is a perfect example of using deductive reasoning based on intelligent thought.
'Armed' with that I can see you will go far in life.
Gateway Support > Gateway 500GR Desktop PC > Main Support page,
http://support.gateway.com/s/PC/R/3724/3724nv.shtml
Click on Components in the list.
Scroll down. Under the bold black heading - Motherboards - click on
102007 - Intel (Augsburg) No CPU Motherboard R0
Click on Specifications.
Chipset: Intel 915G Chipset
http://www.ascendtech.us/gateway-augsburg-intel-915g-motherboard_i_mb4gwaugsburg.aspx
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the wires from the Front Panel go to, is the Front Panel header.
In the photo the Front Panel header is marked by the letter S.
Let's go to Intel Support, and download the Product Guide for an Intel D915GAV motherboard,
http://www.intel.com/support/motherboards/desktop/sb/CS-012048.htm
Click on the blue -
Intel Desktop Board D915GAV Product Guide - (English) PDF
Scroll your mouse cursor to the bottom/middle of the page, to bring the 'ghosted out' navigation guide into view.
Click on the Adobe PDF icon to the far right.
(When you hover your mouse cursor over it, "Show Adobe Reader toolbar" is briefly shown)
Different design motherboard in the layout of certain headers, and connectors, but same Ol' Front Panel header pinout, Intel uses for 10 pin Front Panel header's.
Whether it is an Intel O.E.M. motherboard, or one they made for a pre-built computer manufacturer.
Front Panel header for Gateway 500GR, is next to the bottom edge of the motherboard, and all the way towards the right.
5 pins across the Top row, 4 pins across the bottom row.
Pins on the Top row are numbered ODD.
Pins on the Bottom row are numbered EVEN.
TOP row; Starting on the RIGHT side going towards the Left;
BOTTOM row; Starting on the Right side going towards the Left;
Pins 2, 4, 6, and 8. There is NO Pin 10.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light Emitting Diode)
Pin 1 is for the Positive ( + ) wire. If the HDD LED is dim when the Harddrive is active, switch the wires around.
C) Pin 9 is N/C. No Connection. Pin reserved for the factory.
(5 Volts DC)
Pin 2 is for the Positive ( + ) wire.
If the PWR ON LED is dim when the computer is on, switch the wires around.
F) Again, there is No pin 10.
Regards,
joecoolvette
Aug 21, 2012 | Gateway Computers & Internet
NO POWER TO THE MOTHER BOARD OF MY EMACHINE
The Wires goes on the motherboard, check your motherboard manual for reference
Mar 17, 2009 | E-Machines eMachines T3830 PC Desktop
I unhooked the 3 wires from the bezel, led light,power and hdd i can't figure out hoe to hook them up again.
see on the mother board you will find the labels there near the righthandside bottom corner there is front panel configuration
connect the pins to the exact pins
Dec 28, 2008 | Gateway GT5220 PC Desktop
MY Intel mother board D845WN can't boot
Try swapping those three connector plugs around from the front panel led lights to the other pins on the 9 pins connector, 5 in a row and 4 pins at the bottom. The bigger plug with 3 holes but only two wire will definitely go on the 5 pins row.
sirjohn
Dec 26, 2008 | Intel Desktop Board D845WN Motherboard
Installed an Upgrated Mother Brd,in my Hp Desktop Tower,but the power Switch receptacle in the New Mother Brd has 16 pns
You need to track the wires from the case front panel to thier locations: one will be your power switch, one your reset, one hard drive activity light, and one your power light. You want to note and label which light or switch they go to then go to the new motherboards manual and plan which wires need to go where.
the front panel switches : reset and power switch- these are momentary switches so it doesnt matter which way they go.
hard drive activity and power light- these should have a colored wire and a black or white. the colored wire will be your + side.
Nov 08, 2008 | Computers & Internet
Front pannel connection on the mother board d815eea2 motherboard
Hi Billy, please use the manual to help guide you. Turn to page 33. If you no longer have the user manual please download it from this link: http://download.intel.com/support/motherboards/desktop/d865gvhz/sb/c70845001.pdf
You will need adobe reader to view the manual. You can down load adobe for free at this link:
http://www.download.com/Adobe-Reader/3000-2378_4-10000062.html?hhTest=1
Or directly from Adobe. http://www.adobe.com/products/acrobat/readstep2.html
On pg. 3 is a picture of the motherboard's front panel pin connections. Item "C". (Front Panel pin to case LED's).
Armed with this information (Pictures), you can plainly see the pin numbers.
Page 4 shows you which is positive + & which is negative - pins.
Do not be fooled by the manual name. Intel often groups like motherboards into one manual. This manual does cover Intel's D865GV & D865GVHV motherboard. The second toughest thing to do is find which case wires or positive & which are negative.
This changes from case to case. Look at all your front panel wires. Most common ground is white in color. Positive wires are colored except internal case's speaker 2 wire. Black is negative.
Good luck Billy!
Hope you find this helpful.
Mike
Aug 08, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
NEED TO KNOW WIRING
i have been to fic's web site, i cannot find any mb labeled au31.
do you have anymore information about the board, how old, which processor, what socket, which north bridge, south bridge, which model system, etc?
however the pins are usually marked "pwr sw" or "pwr" and are usually with all the other front panel connector pins.
Oct 17, 2007 | E-Machines eMachines Desktop PC
Computers & Internet Logo
279 people viewed this question
David Payne
David Payne
