Question about Mitsubishi VS-7085 70" Rear Projection Television
Mitsubishi Model # VS-7085 was working then the picture went out but the sound and channels are still there
Can switch channels and the sound is still working , the lights do not turn on
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Retire it and replace it is the best advice I can give.
Posted on Dec 22, 2012
techman
  • 3130 Answers
SOURCE: Mitsubishi VS-5041 (TV turns on but no pic or sound)
Your problem is one and or 2 differant problems. The power regulator could have went bad because of the convergence IC have shorted. Seen this a thousand(easy that!)Times. All parts in this set are soldered in and are not user serviceable. look in your owners manual or call 800-332-2119 to get an authorized servicer to come and look at your problem . I wish i could tell you what to replace but theres the Extreme Hi voltage inside these sets even when they are not plugged in .. Good Luck
Posted on Jun 16, 2006
SOURCE: Mitsubishi VS-60609 50in. Rear Projection
Hi did you find a solution my 60 " tv has a similar issue.. the green light stays on but nothing.. please help
Posted on Oct 09, 2007
SOURCE: mitsubishi model vs-5043
I just had this same exact problem. I looked for an answer on here and could not find one. So I took the back off, vacuumed and cleaned everything out with the hose on my house vacuum, cleaned the bulbs and wiggled them around some. Voila !!!! lights on and all is working fine and better then ever. I hope this helps someone fix their problem. Just saved me tons of money and a morning of hassle.
Posted on May 06, 2008
  • 109 Answers
SOURCE: 52" mitsubishi rear projection tv model vs6051 sound no picture
Not exactly familiar with this model but sounds like the projector lamp is burned out. Hopefully it's a replaceable type. Try calling these people - http://www.purelandsupply.com
Posted on Mar 29, 2009
MNfisherman
  • 11896 Answers
SOURCE: Mitsubishi VS-50603 Wont Turn on
The power supply will need to be changed. The capacitors inside the power supply are not sending the correct amount of power to tv and will need to be changed.
Posted on May 13, 2009
I have a Mitsubishi VS-7085 TV 3 Bulb projection, the tv was on working fine then the picture went out but we could still hear the sound and change channels what can I do?
look to see if the three tubes are lit or not, also see if picture on any input or just retire the set as somewhat old.
Nov 27, 2012 | Televison & Video
I HAVE A MITSUBISHI VS 7085 TV NOT POWERING UP AND WHERN PLUG ON HAERING A CLICK SOUND
if ya ever found out the cause of this please email me as i am going through the same thing with the exact same model my email is peoriaguy73@yahoo.com
Feb 19, 2010 | Mitsubishi VS-7085 70" Rear Projection...
I have a Mitsubishi vs-4543 tv that when powered
check the power supply section.. probably the electronic component got problem.
Jun 04, 2009 | Mitsubishi VS-4544 45" TV
I HAVE SOUND BUT NO PICTURE
Is it a rear projection tv? plasma? or LCD?
Feb 15, 2009 | Mitsubishi VS-5075 50" Rear Projection...
Need the location to the reset button on the mitsubishi vs 7085
The reset button should be a tiny hole in the front near the power button. You'll need to insert a small pointed object such as a toothpick in to press it. You'll see the familiar blinking light then it will turn off and you should be all set.
Nov 20, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Trouble!!
sounds like a loose video cable. Check your connections
Mar 03, 2008 | Mitsubishi VS-60601 60" Rear Projection...
I have a Mitsubishi MDT4025 it goes on but i'm not getting a picture
What can I do to get this fix without taking it to the repaire shop?
Dec 01, 2007 | Mitsubishi VS-7085 70" Rear Projection...
It sounds like vertical jitters:INSTALL VERTICAL JITTER KIT, PART # KIT-V14VJ . If it gets bright and shutdown then:. CHECK THE VALUE OF R9A45 (180 OHM 1/2W RES.),IF OPEN OR INCREASED IN VALUE CHECK FOR A LEAKY OR SHORTED C9A57 (1UF 350V).AT THE CATHODE OF D9A07,ON THE MAIN-PCB.
Sep 05, 2007 | Mitsubishi VS-7085 70" Rear Projection...
Televison & Video Logo
73 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
