Question about Dryers
CLOTHS IN DRYER NOT DRYING RAN FOR 4HRS - Dryers
    Sergeant:
    Champion:
  • 262 Answers
First is your heating element coming on if so check the out side vent and see if it is blowing hard or just a little if it barely blowing then your vent is stopped up let me know what you find out...... bill
Posted on Jan 10, 2009
Tumbles but does not dry
When you put your wet cloths in the dryer close the door. You should then turn on the dry cycle you wish, not the fluff option as there will be only air and gas dryer will not heat the cloths. Wait 30 ~ seconds after the dryer is turned on and listen for the gas to ignite and begin warming and drying the cloths. If you hear no bump sound like the ignition of the gas, then you have an ignition issue. It will require replacing the ignitor. All the best and good luck. Hope this helped.
Oct 02, 2012 | Maytag Neptune MDG5500AW Gas Dryer
Thumping sound when drying?
change your belt or replace the spring that tensions the belt
Jul 13, 2017 | General Electric GE DBVH520EJWW Electric...
Does not dry cloths. dryer gets hot,top and sides during drying cycle. it takes 2-3hrs to get cloths dry.
most probable cause of heating yet not drying in a crushed or restricted vent (imagine only inhaling while breathing yet not never exhaling)
Jul 22, 2011 | Kenmore Washing Machines
How do I clean the lint out of the system? My cloths aren't drying. It takes 2 cycles to get the cloths dry. I cleaned out the lint trap, but it is still doing it. Is there a web page or instructions...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Oct 13, 2010 | Frigidaire GLER642A Electric Dryer
Dryers is not drying the cloths
The problem is the ignitor...
Check out this tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Apr 08, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer end cycly without cloths drying. Doesn't
IF DOESNT HEAT UP ANYTING CHECK THE THERMAL FUSE AND REPLACE IT IF NECESSARY!!!
IF IT DOES HEAT UP A LITTLE IS NOT THE FUSE!! IT COULD BE THE EXHAUST PIPE (DUCT) CHECK THAT IS NOT BLOCKED OR CLOGGED!!!!
Oct 05, 2009 | Kenmore Elite HE4 Electric Dryer
My Maytag gas dryer is not heating correctly. It gets warm, but takes several cycles to dry even small loads.
If you have'nt done it yet, my first suggestion would be to have the vent on the dryer (inside the dryer all the way to the fan chamber) and the dryer vent pipe to the outside thoroughly cleaned.
That is leading cause for dryers not drying completely.
Also, has the dryer always been a bit slow to dry cloths? If so, try leaving a window open the next time and see if it makes a difference. Some houses are sealed so tight, the dryer can't get enough air. A typical dryer will use up to 200 cu/ft of air per minute when drying. If there is not sufficient air, the cloths take longer to dry.
Good luck, let me know.
Regards,
May 12, 2009 | Maytag PYG2300A Gas Dryer
Gas dryer not drying clothes
Hi, Dryers are simple machines to fix yourself so the main reasons dryers do not dry cloths is listed below.
1. Make sure the vent is clear from obstruction of lint built up by taking off vent and make sure the vent flap is opening when dryer is on, beware most house fires are caused by neglect of dryer vent!
2. People allot of times overload machine which causes cloths not to dry.
3. Electrical Repair Needed: one of the thermostats in the dryer are defective
May 02, 2009 | Dryers
Dryer not drying cloths
http://www.pcappliancerepair.com/model-display.php This shows the screws (#2) that hold the front on. Use a putty knife to push on spring catches (#20) to release the top.
Jan 24, 2009 | Roper RGX4634KQ Gas Dryer
Dark grease stains on the cloths after drying
Most likely a bearing failure, a seal that retains grease has given up and is spewing into the drum through a shaft opening of some kind.
If you are positive there is no grease in some of the clothes, or someone is putting it in the drum, then a seal has failed, and now that the grease is coming out, the bearing it is was supposed to lubricate is now low, and will fail prematurely, you need a service call and soon.
Will
Nov 17, 2008 | Dryers
Dryers Logo
71 people viewed this question
Top Dryers Experts
