Hotpoint ultima wma61
Can you help? Keyhole symbol is flasghing indicating the door is open but i have checked and the door is locked. The machine wont start and the symbol wont go away. when i press the start button the machinhe beeps several times. Any suggestions please?
  • 15,935 Answers
Replace the door latch switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Key symbol is on cannot open door
If there is water left in machine door stays locked but if you remove the plug after about 3 mins the door may open be careful if there is water in it when you open the door
Mar 25, 2014 | Hotpoint Ultima WF860 Front Load Washer
The access door will not open, it is showing the locked symbol in the window
Your problem is either one of the 2 cases below.
1. Door Locked Indicator...'Keyhole' symbol
The 'Keyhole' symbol will illuminate 2 seconds after you have
pressed the 'START/CANCEL' button and will remain lit
throughout the wash programme.
The 'Keyhole' symbol will be flashing at the end of the
programme to indicate that the door is still locked. When the
symbol goes off you will hear a bleep and the door can then
be opened.
2. If the machine has been child locked, deactivate this feature by pressing and holding in the 'child lock' button for 2 seconds.You will hear a beep and the child lock symbol will go out,allowing you to use the machine normally.
Jun 05, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hi, my ultima machine door wont open and says error code f-05, can you help.
Link to the service website: http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
From the owner's manual under troubleshooting:
Error code: F05 - Pressure switch jammed on full
The door will not open...
● Has the programme finished? Is ‘End’ lit
in the display window and the ‘Keyhole
symbol deactivated?
The door will not open until the ‘Keyhole
symbol goes out shortly after the
programme has finished.
● There is still water in the machine.
Go through all the points in the next
section,‘The machine will not pump out
water...’
The machine will not pump out the
water...
● Make sure that there is no blockage in
the drain hose and that it is not kinked.
● Is the drain hose installed correctly?
● If you have connected your machine to a
sink waste system, make sure that you
have cut out the membrane from the
under sink drainage system.
(see section: INSTALLING YOUR
MACHINE).
● Ensure that the drainage system,
standpipe or under sink connection is
free from any blockage.
- If any of the above are found to be
the cause of your problem you will need
to run the machine through a spin only
programme.
● If you have chosen ‘Rinse Hold’, the light
will flash until you press the ‘Rinse Hold’
button to continue the programme.
Jan 16, 2010 | Hotpoint Ultima WF865 Front Load Washer
Door lock symbol showing on screen and door will
Assuming child lock is not on...Water not fully going away/ blockage @ filter.
Nov 02, 2009 | Hotpoint Ultima WDM73 Front Load Washer /...
Door stays looked on washing machine
you will need to remove the top cover and get a screwdriver to move the door latch over. it's a job for an engineer really as you have an electrical problem anyway.
Jan 27, 2009 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WMA61 loud knocking noise in spin cycle
Hello I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. Also another way to check is to move the inner durm up and down to see if there is any play in it..
If you need any further advice then dont hesistate to ask....
Jan 14, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Error code F-01
Press "end of cycle button" for over 5 seconds, it will unlock. Note: the door should be opened only on hearing a click, or wait for 2 minutes after the wash completes.
I need a rating please, dont forget(!)
Dec 27, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WD71(probably the wd72 except in white)
hi there what u can do is take your drain hose and place into a bucket water will come out the door will release now check the pump and make sure that it is not blocked up with anything if it isnt check the drain pipe that is under the washer in the middle of the drum there will be water in there but check inside if anything is inside there it will slow down the empty programme and will not let the door release do u live in malta then m8 as my dad is maltease and im half
Aug 23, 2007 | Hotpoint Ultima WD72 Front Load...
Washing Machine
Which symbol is illuminated? Red keyhole? Child safety? Red tap? End status?
Jun 27, 2007 | Hotpoint WMA76 Front Load Washer
Washing Machines Logo
229 people viewed this question
Top Washing Machines Experts
