Question about Hitachi 50UX26B/27K 50" Rear Projection Television
Blue/Yellow in upper left corner
Our set is showing Yellow and Blue in the upper left corner. I guess it's a shadow effect, almost like a color is missing, which I think would be the Red. Any thoughts on this. thanks, Ken
  • Ken Ostromek Jun 12, 2007
    Follow Up: Performed Static Convergence Adjustement and the problem is now corrected. If you have the service manual, this booklet is a lifesaver.
I have the same problem and now there is convergence problem with the entire screen, double images and ghosting ...i was told that some IC's are burned our ...etc..i'm waiting to see if they sell the entire board since the TV's are 10 years old... will let U know what i get as a response.
Posted on Sep 08, 2007
DARK SHADOW EFFECT UPPER CORNERS OF SCREEN
I would check for dust particles before I attempted any type of repair on the unit.
Dust particles will appear as dark spots that are larger than the size of an individual pixel. It must first be determined if the particle(s) are on the LCD panels or the screen.
May 27, 2009 | Sony KDF-E42A10 42 in. LCD Television
Color convergence on our Phillips 46999302/17F
If you are not able to adjust the convergence using the remote you need to replace the convergence chips.
Typical Symptoms
1) Convergence menu does not work for one or more colors.
Example: RED moves up,down, but left or right fails.
2) Screen is bowed looking.
If you have one or more of the problems above you need to replace the convergence chips. You can get a kit and instructions from www.TvRepairKits.com
Jan 01, 2009 | Philips 43PP9202 43" Rear Projection...
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Philips Blue Shadowing
If you have not already done so go into the picture menu and set the convergence. The convergence is the angle at which the three picture tubes meat at a given distance. The tv will have at least 3 and up to 64 convergence points, and those 64 can be set for all three colors. This can be tiresome but I'll be it will solve your problem. What your trying to do is get the color in the cross-hair so you cannot see the color behind the target. On top of the fine setting for each point and color you will probably have 3 gross adujustments for blue and green and maybe red. These adjustments will affect positioning, like what you are discribing. You should do this at least every month, the thermal cycleing of the lamps is what will cause this to creep out of adjustment.
Sep 25, 2008 | Philips Magnavox 9P6034C 60" Rear...
Shadow issues
You need to replace both convergence ICs they are both STK392-110 you can get replacement ICs at the following link with free instalation Instructions with pictures. Here is the link.
http://servicemanuals.vstore.ca/
Jul 09, 2008 | Philips 50P8341 50" Rear Projection...
Blue dots and blue color
my sony is 4yrs also it has blue dots on the left side from top to bottom and a blue blob on rt. bottom corner no longer under warr. please send repair solution.
Jan 12, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Yellow and Blue shadow on left side of screen
Blue convergence off = needs convergence IC's replaced =
Would you like step - by - step how to ??????
Nov 07, 2007 | Toshiba 51H84 51" Rear Projection...
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
Open Questions:
Televison & Video Logo
258 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
