Question about Whirlpool Refrigerators
Whirlpool refrigerator has an awful smell coming from the bottom. We cleaned the drip pan the smell went away, the next day the motor turned on and the smell came back. Can it be the motor?
  • Whirlpool Master
  • 3,287 Answers
If the fridge is failing to keep the freezer as cold as it was, it is only a matter of time (hours or maybe a day) before it stops cooling completely.
If you smell sulfur or rotten eggs, and cooling inside is diminished, it is very likely that the refrigerant has escaped due to line chafing, rupture or compressor failure. This is not the type of failure your want. Many times, this repair costs many hundreds of dollars to repair and isn't worth the expense. Other times, a line can be repaired after cleaning & evacuation. A service port is installed to allow a new refrigerant charge to be introduced to the fridge.
The only way to know for sure is to have it checked by a licensed refrigeration mechanic or fridge repair technician.
Posted on Nov 27, 2012
There is a bad smell that I get a wiff of when I walk by. The smell is on the right hand side of the frig. Sometimes it can be smelled for a short distance. The smell is not coming from inside the frig,...
Some of them do have a drip pan under them ,at the bottom of the frig there is a cover that will come off may be screwed on may snap off when you pull on it.Take a flashlight and shine under it after you get plate off you should see it .You can put a cap full of bleach in it should take care of your problem.
Sep 20, 2017 | Whirlpool GX5FHTXT Bottom Freezer French...
Foul smell coming from behind the refrigerator. I smell it coming through the fan on the back of the refrigerator. I believe it could be the drip pan, but I don't know where it is located. Also, my...
the drip pan is usually on top of the compressor or has a draw underneath with a coil to create heat for evaporation of water from the drip pan. Some time a rodent can drown in this location.
Jul 17, 2017 | Whirlpool GB2SHDXP Bottom Freezer...
I have a Whirlpool refrigerator 21TFA that may have a drain problem or a clog. It drains in the evening, but this morning when I woke up, it smelled bad from the bottom of the refrigerator. Any advice?
Hi and Welcome to FixYa I am Kelly,
A bad smell from under the refrigerator is a result of either a dead rodent or.. dirt and lint accumulation in the plastic drip pan / catch basin and then the defrost cycle water wets it 2 to 3 times a day intensifying the smell.
Unplug the unit
Remove the rear fiberboard cover that covers the compressor area
Use a shop vac and rags to clean out the drip pan / catch basin. (These can be VERY foul if they have never been cleaned!) Make sure to clean the condenser coils and condenser fan area also. Inspect for varmits / rodents (deceased) with a flashlight. You can wash the drip pan using a rag with vinegar and water then soap and water.
Lastly... make sure the END of the drain tube that terminates in the drip pan is clean. If there was lint build up that caused a muck pool in your drip pan the muck often clogs the end of the drain line.
You never know what your going to find under a refrigerator! I could expound but it is not pleasant and only you will be able to discover the secrets of your refrigerators' "underside life." All I will say is.. it is always a... revealing experience.
Thanks for choosing FixYa,
Kelly
Mar 21, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Funky smell coming from bottom of frig when running
Is it a musty smell or that of something / (rodent) decomposing? If you only smell it when it is running then look for BLACK gunk that will probably appear almost like a paste. Even things like cat or dog hair will collect in damp areas. There should be a white plastic drip pan under your unit. Look for the freezer white plastic drain hose on the rear bottom of your unit on the freezer side and follow that hose to the drip pan. It catches water every time the unit defrosts which is 3 - 4 times a day depending on which defrost timer your unit has.
Usually there is a build up in the drip pan that gets mucky and then stinks like mold. It will of course need cleaned.
Also look at the fan area for the coils. Sometimes there are unwanterd home critters that attempt to get through the running fan blades and end dead up inside the cooling coil metal radiator area.
Feb 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Smell fish odor when fan comes on.
Tim, Clean the refrigerator completely with clorox and water. Unplug and remove the rear panel in the back of refrigerator and wash the evaporator coil with this solution. Check the amount of flow to the condensate pan below. The drain line has the gel and this contaminated smell from top to bottom and you will need to insure that all the smell remaining in the drain is draining freely and decontaminated with the clorox. Do these things and wash the remaining pan below the best you can and you will be set to go.
Jun 20, 2009 | Whirlpool GD2SHGX Refrigerator
Terrible smell coming from bottom of unit
There Should Be A Grill On The Front Bottom Below The Door. Remove That And It Should Come Out Of The Right Side.
Jan 05, 2009 | Maytag MSD2656G Side by Side Refrigerator
Fridge smells
The drain leads to a pan under the fridge that sits on coils and evaporates the condensate that drained out. you should be able to access the pan and remove it and clean. or you can just wait for it to evaporate and go away. (better off to clean) some warm water in a baster will help rinse out the line. Let me know if that worked or if you need help accessing the pan.
Oct 19, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
How do I clean my drain pan on my side by side refrigerator it smells
Hi. Thanks For The Question. Pull Fridge Away From THe Wall. Remove Back Panel Clean All Coils. Remove Drip Pan. Clean. Thanks The Appliance Doc
Aug 07, 2008 | Maytag MSD2656G Side by Side Refrigerator
Refrigerators Logo
345 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
