Question about Maytag Dryers
I have a maytag dryer we changed the belt some wires become disconnected and now its not heating up and we dont know how to hook them back up and whats the right spot
    Top Expert:
  • Maytag Master
  • 9,472 Answers
What is the model number?
Posted on Nov 28, 2012
Tech007
  • 63 Answers
SOURCE: whirlpool clean touch dryer
Sounds like the wire that goes to the flame sensor switch if it is gas there is a black wire and a white wire that goes to it its on the left side of the gas valve on the flame housing tube / pipe
Posted on Aug 29, 2007
SOURCE: MAYTAG DRYER LDE4914ACE BELT CHANGE
Dryer just stopped working, if you push the dial button in to start nothing happens at all. Dryer just stopped after runnig for about fifteen minutes.
Posted on Feb 14, 2008
  • 117 Answers
SOURCE: My Kenmore dryer 70 series
You can go to this website and put in your model # to see if your wiring schematic comes up. http://www.servicematters.com/docs/wiring/wiring_main.htm
http://tclaundryrepair.com/home
Posted on Feb 19, 2009
goofduck
  • 490 Answers
SOURCE: need to change the belt on the dryer..how do i get to it?
you have to remove the front of the machine
Posted on Apr 16, 2009
aborcass
  • 2651 Answers
SOURCE: Maytag De4000 Electric Dryer Wire Hookup
black and red wire, will hook to either end of terminal posts, as long as the white wire connects to the center post. the green wirewill then atach to the cabinet of the unit,( usually a green ground screw just outside the termoal box anyhow!
Posted on Apr 22, 2009
I have a Maytag Neptune dryer, Were do i find the element.
In the back, Remove the back panel and you will see on the right a long rectangular metal housing around it it's testable from the bottom connection where the wires hook on, you will have to disconnect the wires if your checking continuity.
May 16, 2011 | Maytag Neptune MDE5500AY Electric Dryer
My maytag neptune dryer doesn't blow any hot air
on top of the heating element on the left side there is a white 2connector part, that is the heater thermal fuse. disconnect the dryer power cord and one wire of the thermal fuse and use a meter to find out if you have continuity to it. if not replace it. also check for burn wires at heating element. also test heating element by disconnecting one wire and using an ohm meter test it at 2 therminals. it shoul measure 10-12 ohms.
Feb 14, 2011 | Maytag Neptune MDE5500AY Electric Dryer
How do i change the belt on a model No. DE308 maytag dryer
Hi
To change the belt you'll need to remove the top paenl and then remove the drum and you would be able to see the belt. You can disassemble it by the following procedure--
Drum Removal / Roller / Glide Access--
  • Disconnect power supply to unit.
  • Remove Top Cover and Front Panel,
Top Cover / Door Switch / Front Panel /Gasket Removal-
1. Disconnect power supply to unit.
2. Use a plastic putty knife to depress the locking clip between the Top Cover and Front Panel.
3. Disconnect wiring from the Door Switch.
4. Depress the locking tabs on switch side and remove through the front.
5. Remove two screws, 1 each side, from the back flange of the Front Panel.
6. Tip Front Panel back and remove. Rotate Front Panel to the back side and remove gasket.
Hope this helps...
Daniel
Sep 20, 2010 | Maytag Dryers
How do I replace the heating element in Maytag Dryer SDE2606AYW Serial# 12508837EN
1.Unplug the Maytag dryer from the dryer electrical outlet and pull the dryer away from the back wall.Use a putty knife to press in the locking clip between the front and top panels.While pressing the clip in with the putty knife,lift the top panel up to unlock it from the clip.Raise the top panel into the service position allowing it to rest on the back hinges.
2.Locate the door switch connection on the inside front right corner of the Maytag dryer.Press the locking tabs in with your fingers and pull the wiring harness away from the door
switch.With a Phillips-head screwdriver,remove the screw on both inside corners that secure the front panel to the sides. Lift the front panel up and away from the dryer.
3.Use a Phillips-head screwdriver to remove the four retaining screws that secure the drum bulkhead to the front of the side panels. Remove the bulkhead from the dryer.Reach under the drum and pull the idler pulley to the left to release the belt tension.Remove the belt from the motor and idler pulley. Lift the drum up and out of the dryer unit bringing the belt with it.
4.Remove the two screws that secure the heating element to the rear bulkhead with a Phillips-head screwdriver.Disconnect the heating element terminal wires by grabbing them with needle-nose pliers at the wire leads and pulling them off of the terminals.
5.Place the new Maytag dryer heating element into the dryer and slip the wire leads over the terminals.Secure the heating element to the rear bulkhead with the retaining screws.Lift the drum and belt and place the drum back inside the dryer cabinet.Route the belt around the motor and idler pulley.Shift the idler pulley back to the right to apply belt tension.
6.Reattach the front bulkhead to the dryer using the four retaining screws.Position the front panel into place and secure it to the sides with the retaining screws.
7.Bring the top panel back down and push the front corners in to engage the locking clips.Push the Maytag dryer back into its working position and plug the power cord back into the dryer electrical outlet.
Aug 28, 2010 | Maytag SDE2606 Electric Dryer
Dryer works but no heat. We just moved...
most likely there is something wrong with the way the cord is wired to the machine or the outlet is dead. Dryers dont usually get damaged just by moving them. did u change the power cord. red on one end white in the middle black on the other end and green to cabinet ground.
Jun 12, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Apr 22, 2009 | Maytag Neptune MDE4000 Electric Dryer
Heating problem
Unplug the dryer.
Take a putty knife and insert it at the top of the front panel just below the lid and push the 2 clips in.They are about 2 inches in from the right and left sides.
Raise the top lid towards the rear of the machine.
Remove 2 screws on the inside top corners of the front panel. Remove the front panel.
Remove the belt. Remove the drum.
The heater will be on your bottom left.
Apr 12, 2009 | Maytag 7.0 Cu. Ft. Electric Dryer
Remove front panel of maytag MDG7400Aww gas dryer
You have to remove the front panel first to access the clip that holds the front of the top down. Instructions:
crosstip medium screwdriver
1/4 inch socket
5/15 inch socket
  1. UNPLUG DRYER
  2. TURN OFF GAS
  3. Disassemble by taking apart the FRONT of the dryer:
    a. Remove the door and opposite side door plugs (crosstip screws)
    b. Remove the front panel - this exposes sheet metal bolts (5/16 inch) some with crosstip on left and right of unit. Set panel aside (right side) WITHOUT unplugging wires
    c. Unscrew all the exposed bolts.
    d. Top bolts left and right secure the unpainted metal hooks which secures the top of dryer. Unscrew these bolts and wiggle the metal retainer hooks off. Lift top and support to create 6 inch gap in the front (top unit hinges in back and has electrical connections - do NOT disconnect wires)
    e. Release belt from pulley by reaching left and under drum (this is out of sight)
    f. gently lift out drum and belt and set aside
  4. This has exposed the interior.
Aug 31, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
