Question about Dryers
My wires came diconnected and now it wont get heat and im not sure how to hook the wires back up
  • shannon Nov 28, 2012
    nomdet446ayw
    Top Expert:
  • Dryers Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 28, 2012
Have a frigidaire oven, model# PLES389ECE. Broiler heating heats up but lower (bake) element does not. Element need replacing?
mos likely yes... but to confirm is very easy... unplug unit or turn circuit breaker off... in the oven with door open you will see the back of bake element where it goes into oven wall a couple of screws remove them and you should be able to gently pull element out...there are 2 terminals connected to element with a wire attached to each of them... first we are making sure the wire hasn't burnt off or cam edisconnected and second we can remove wires and use a volt meter and test power... set it up so you don't get electricuted and tuen oven on bake 350 do you have power coming to the wires with element diconnected from wires...if so then you have a bad element if not then a bad thermal cutooff usually located in back of unit ... good luck to you...
Jan 11, 2011 | Frigidaire Ovens
Horn
pull your steering wheel horn pad and check the spring wire to make sure it's not grounded anywhere.
Mar 29, 2010 | 1989 Toyota Camry
I have a hunter programmable thermostat model #44155c and Im trying to wire it to my goodman furnace. Its a 7 wire system with a white,yellow,red,green,brown,blue, and orange wire. The ac works fine but...
Make sure you do not have a jumper between the red and the white. Also make sure the wire is not hanging out from behind the screws. If the heat stayes on no matter what you do. The red wire has to be touching the white somewhere.
The red is your 24v supply to the thermostat
The white is what sends the 24v to the heat side of unit.
Just a thought. If the thermostat has a O/B pin or switch on the back. Make sure it's on O. It should only be ob B if it's a Trane, American Standard or Payne.
Oct 16, 2009 | LG LSC183VMA Split System Air Conditioner
Just hooked up outlet. Dryer tumbles, wont heat. Have I wired the outlet wrong?
Hi, Did you put red and black wire to the outer posts? White wire ti center and green to ground screw on cabinet? Dry will run on 120V but needs 240V for heat. Make sure there is 240V to the outlet as well.
Hope this helps. If so, please feel free to rate my answer so that I know how I am doing.
Vic
May 10, 2009 | Dryers
1997 eclipse wont start after alarm is triped/ diconnected
pull the fuse/ power supply on the main alarm module. it should startt. hook it back up and it should re set.
Mar 09, 2009 | 2001 Mitsubishi Eclipse Spyder
I am replacingh my thermostat. it's a honeywell xt302c. im replacing it with a hunter 44660. the wires are different letters. here's what's hooked up on the honeywell and available on the hunter: Honeywell...
Thanks for your Question,
B- is your common leg,
RH- is your hot to heating
RC1- you will not need
RC- you can use if you remove the jumper for cooling
Y1- you will not need
G- is your fan
O is not needed, wires should be hooked in as follows,
RH- red wire, heating
RC- Yellow wire, Cooling
G- Green wire, Fan
B- Blue wire, for common leg, this one might be a different color so make sure at the furnace which T-Stat wire is connected to Common, you should check all the wiring at the furnace to make sure this pattern of wiring is followed, it should be standard practice to hook them up this way, but not all installers do it, thanks again, please rate this,
mr.grzz
Jan 25, 2009 | Heating & Cooling
Locks wont stop
hi again kids
i actually resolved this problem the long and silly way round??? because my alarm and immob are linked (separates but connectable) i believed that alarm unit was ok as still functioning, so marked and snipped immob wiring. wrong wrong wrong. i re joined each wire one by one to see if any thing changed with fault. it didnt have any effect, so back to wiring on alarm module, and after removing security screws, i emptied the water that had seeped into alarm wiring after washing car the week before, and a good hour drying out on raditor and it now works like a dream again, but i still have the problem of doors not locking automatically when alarm armed, though to be honest this fault started before the one i wrote to you about?
in essence im a big baffoon and have resealed alarm wire entry point as silicone had gone south a long time ago, allowing water to enter.
thanks anyway
regards
harrie the hose man
Oct 12, 2008 | 1992 Ford Escort 4 Door
Legaxy LA2098 2400 watt 2 channel amp
Humm.. Have you check your remote wire? If you know the amp is getting power for sure, diconnect your subs from the amp leave only the + - and remote hooked up. Check again if still same thing nothing, try taking a jumper wire to the batt terminal over to the remote terminal. This should let your amp kick on, IF SO your remote wire has a short some where. IF NO i would check your ground wire again and make sure its good and along with all your fuses. IF NO still might have internal damage. BUT if it did work dont leave it hooked up like that, it WILL stay on untill u remove the jumper wire. I just use this lil trick to help save time with trouble shooting. Hope this was helpful i had the same prob with my amp remote wire was bad
Nov 17, 2006 | Legacy LA2098 Car Audio Amplifier
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
