Question about Bosch Washing Machines
How do i get rid of the fault code f21 - Bosch Washing Machines
    Top Expert:
  • Bosch Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 27, 2012
Frigidaire washer fafs4272la0 fault code f21
1. Check the drain hose for restrictions. Restriction, correct problem. No restriction, go to step (2). 2. Start the washer and check for 120VAC at the drain pump. Zero, replace the Main Control Board. 120VAC, remove the pump and check it for blockage. If blocked, remove the restriction, if not, replace the pump.
Aug 28, 2012 | AEG Washing Machines
F21 code
F21
or
F22 CCU / Touchpad / LED assembly error This error occurs if the touchpad/LED assembly is not able to transmit/receive data to/from the central control unit (CCU).
Possible Causes / Procedure
1. Check the touchpad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touchpad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the touchpad/LED assembly and Central Control Unit (CCU).
Replace failed component.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Sears / Kenmore Fault Codes#ixzz1STOj0WuT
Jul 18, 2011 | Kenmore Dryer Lint Screen Filter Trap...
The washer isn't spinning all the water out. A code of F21 appears.
This usually indicates a clogged drain filter or pump. Try this link it should help F21 Fault Code Repair
Feb 07, 2011 | Kenmore HE3T Washer
Error code F21 - thanks for your help
The F21 error code is an indication that the unit has too long of a drain out condition. If the control calls for the unit to drain & the water does not drain out in 8 minutes or less the unit will stop & flash the F21 error code. I would recommend checking the drain pump & pressure switch circuit.
Clear pump of debris. Tilt machine. Take off front panel. Unscrew large white drain plug. Remove debris.
Unplug from power source...remove front lower panel (3 sheet metal screw wirh 1/4" drive head located on the lower lop of the panel)...open pump strainer (looks like a large stove knob, Turn it counter clokwise, lookout! lots of water will gush out... back flush the pump by filling the outet of the drain hose ( this may dislodge debris that may jam your pump)...re-assemble, plug to power, and turn-on. That will help get rid off the debris.
It can be done if you are patient and able to figure out how the plastic thing comes apart. Good luck!
May 09, 2009 | Washing Machines
Washing Machines Logo
326 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
