Question about Samsung Televison & Video
Samsung model PN50C550G1FXZC shut off and won't come back on - no standby light
TV just shut off and will not turn back on. have tried new cord in different outlet - same issue. ther is no red standby light in bottom corne. took unit in to repair shop and they said it needs a dc flash vss module. Very expensive and hard to replace - is this true or can I just order the part and replace it if is plug and play
  • 85 Answers
Check you tube
Posted on Nov 30, 2012
  • 2318 Answers
SOURCE: AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Posted on Nov 27, 2008
  • 3 Answers
SOURCE: flashing red light
Your power supply is faulty I'm afraid. Unless you have soldering skills, I am afraid you will need to contact a professional TV repair person. If you feel confident to try the repair, contact me with the model number, and I will let you know what components you need to change
Posted on Mar 06, 2009
tvservice306
  • 458 Answers
SOURCE: ln40a530 samsung lcd tv wont turn on
MAY BE PANEL LAMP BAD
Posted on Oct 21, 2009
dave1645
  • 834 Answers
SOURCE: Samsung 26" LCD TV will not turn on
you have one or two bad caps in the power supply these can like devices will be puffed on the top from venting the value is wrtten on the sides replace them and you will be good to go
Posted on Nov 06, 2009
  • 1039 Answers
SOURCE: My tv won't turn on. There is a red light
Replaced any capacitors on the power board that have domed tops.
Posted on Sep 01, 2011
My Samsung Tv will not turn on and I have blinking red standby light. Model code: PS43D450A2WXXU. I have take the back of it but unable to locate the issue. Any ideas? Thanks in advance
If you are getting a red blinking light, this usually means that you need a new power PCB. The circuit board that the power cord connects to is probably gone bad.
Aug 26, 2016 | Samsung Televison & Video
Sound doesn't work in HDMI mode, just picture. I tried buying a new HDMI cord but that didn't work either. Then one night the TV just turned off and now it won't turn back on.
Likely not related but HDMI does not like being connected if either unit is plugged in or powered up.
As to the TV let me know the brand and model number and what if any lights at all come on when you plug it in etc.
SD TECH
Dec 11, 2012 | LG 62SX4D 62" Television
My guess is the power supply has failed, especially if the standby light is off
Nov 27, 2012 | Samsung Used Original PN50C550G1FXZC...
My Sony wega tv won't turn on goes into standby red light blinks 10 times then shuts off?
Look at the owner manual as the 10 blinks is a error code or Google the model number to locate that information--Sony error codes are general and often misleading.
I would if looking at the set inspect the lamp first.
Aug 28, 2012 | Sony Grand WEGA KDF-42WE655 42" Rear...
My LG 32LD320 won't turn on. I have no standby light and have even tried changing the fuse. Help please!
If total dead best way is to follow the AC voltage from power cord inside the set to see where voltage is lost.
Also , were you having any problems having to turn set on several times to get it on?
Mar 20, 2012 | LG 32LD320 32 HDTVReady LCD TV
Samsung T220hd won't turn back on from standby
Power up issues on the T220HD monitor are caused by a failure of the capacitors on the IP-49135b power supply board that this unit uses. The repair is easy, you just need to replace the 7 failed capacitors and the unit should be as good as new. Here is a link to some information showing what needs to be replaced to repair the power supply board.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_33_68&products_id=217
I hope this helps.
Nov 21, 2011 | Samsung T220HD LCD Monitor
Samsung le32b450cw wont go from standby to on
Hi.
Unfortunately I won't bring good news.
Your TV is in forced standby. The state is also called "protection" and indicates a special mode tat kicks in when an internal fault such as a short (big power draw) or a wrong voltage is detected. When that happens the protection circuit to force TV PSU to shut down all voltages apart the +5VDC line that keeps TV in standby.
All you can do is disconnecting the power cord, checking if there is a fuse built in the power cord, replacing fuse and connecting back after about 30 minutes (that allows power drain). If the TV does not work there are faulty internal parts that need replacement.
If now the TV does not start at all, and not even the standby light is on, then the problem is usually the PSU. The part must be tested and eventually replaced.
Here broad description of how to test some parts that fail quite commonly in LCD TVs: Before proceeding...
Here replacement parts for most flat panel TV models:ShopJimmy.
See also:
PartStore
Regards.
Ginko.
Sep 20, 2011 | Samsung Televison & Video
Good morning, I have the Hyundai hp4200 which will not turn on, when you switch on it clicks then 2 minutes later clicks again to onto I guess standbye. However, if you turn it on and off by the socket...
Yep, I can help but I am afraid that I won't be able to bring totally good news.
The TV is in forced standby also called "protection". Protection kicks in when an internal fault such as a short (big power draw) or a wrong voltage is detected. The click comes from a relay activated by the protection circuit to force TV to shut down.
See also:
PartStore
Regards.
Ginko.
Sep 15, 2011 | Hyundai Televison & Video
It won't turn on
hi; try to check the power cord ,
if power cord has no problem it has standby light coming from the TV
when no light or dead set. there a fuse blown on the power supply section.
if there's standby light wont start , even if you press the power button , it has a power supply failure, maybe some capacitor ha bloated or change the value, try to watch this http://www.youtube.com if you know how to solder, or even disassemble the back of LCD TV. if not try to call a repair technician. thanks ,, hope this help.........
Sep 05, 2011 | Mitsubishi LT-55265 55 in. HDTV LCD TV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Televison & Video Logo
99 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
