Cannot open my HP Folio Laptop
Upon opening the laptop it says "for more information pleas visit: www.hp.com\go\techcenter\startup
  • 7,627 Answers
Unplug from AC, remove battery, plug into AC, boot normally. I assume when you say "cannot open" you mean will not boot?
Posted on Nov 28, 2012
2 Suggested Answers
romsky79
  • 822 Answers
SOURCE: Boot device not found Please instal l an operating
please go to the bios setup by pressing F2. then check your sata hardisk if detected. if not, remove the sata hardisk and use it as external by using external sata case adapter. then plug to the other pc and check if spinning or detected by another pc. once not detected or spinning change your sata hardisk. but if detected, there is a problem on your dv6000Z notebook.
Posted on Feb 01, 2011
My laptop is showing the smart hdd error at startup. how can i disable that message? I am using hp pavilion 2000 laptop.
The SMART hard disk check has detected an imminent failure. To ensure not data loss, please backup the content immediately and run the Hard Disk Test in System Diagnostics.
Hard Disk 1 (301)
F2 System Diagnostics
ENTER - Continue Startup
For more information, please visit: www.hp.com\go\techcenter\startup
Sep 02, 2013 | HP 2000-2B89WM Intel Core i3-2328M...
Automatic repair
hi Andrew.
"Upon the 'Preparing automatic repair' window, press-and-hold Power button 3 times to forcefully shut down the machine. The system will enter boot repair page after 2-3 times of reboot, choose Troubleshoot, then go on to Refresh PC or Reset PC."
Get Rid of Infinite Preparing Automatic Repair Loop - EaseUS
https://www.easeus.com/resource/fix-preparing-automatic-repair-loop.html
How do I bypass startup repair?Fix #1: Boot into Safe ModeInsert the disc and reboot the system.Press any key to boot from the DVD.Choose your keyboard layout.Click Repair your computer at the Install now screen.Click Troubleshoot.Click Advanced options.Click Startup Settings.Click Restart.More items...Startup Repair Infinite Loop: Fix for Windows Vista, 7, 8, 8.1https://neosmart.net/wiki/startup-repair-infinite-loop/Search for: How do I bypass startup repair?
How do I boot my laptop up in Safe Mode?Open Windows in safe mode using Command Prompt.Turn on your computer and repeatedly press the esc key until the Startup Menu opens.Begin a System Recovery by pressing F11. ...The Choose an option screen displays. ...Click Advanced options. ...Select Command Prompt to open the Command Prompt window.More items...HP PCs - Windows Safe Mode (Windows 10, 8) ' HP® Customer Supporthttps://support.hp.com/bg-en/document/c03439317Search for: How do I boot my laptop up in Safe Mode?
or go to this link if you need more help.
laptop preparing automatic repair Google Search
Nov 28, 2017 | Computers & Internet
I get this message when I turn on my laptop. It's almost a year old. "The system has detected that a cooling fan is not operating correctly. Continued operation is not recommended and may...
More that likely the fan is going out. Check the fan exhaust to see how much air it is moving if any. A laptop cooling pad will probably help out and possible prolong failure. If its under a year old, the maufacturer may fix it for you. You'll just have to contact HP and see if they will, or if they can get you a new fan to replace yourself if they wont do it for you.
Sep 11, 2011 | Computers & Internet
My brother laptop Compaq Presario CQ-42 after 3 month used , now appears " Boot Device not found Please install an operating system on your hard disk Hardisk - (3F0) " F2 System...
Fundamentally, it means that the hard drive or hard drive controller has malfunctioned. I'm assuming this is running Vista or Wndows 7 and that the hard drive is indeed a Sata drive?
(If it were running XP, the failure to deterct the hard drive could be caused by there not being a Sata driver installed, however, on Vista or 7, this should not be the case, UNLESS you changed the OS from what was installed originally?)
I would try to prove this by testing the laptop with another working sata hard drive and if that one is recognised in the Bios, then it comes back to your original hard drive being faulty. If this IS the case, then as its 3 months old and still under warranty, I'd take it back without tampering with it any further
Apr 18, 2011 | HP Pavilion dv5-1000us Notebook PC
Boot device not found Please instal l an operating sistem on your hard disk. Hard Disk - (3FO) F2 Sistem Diagnostics Foe more information, please visit: www.hp.com/go/techcenter/startup
Feb 01, 2011 | HP Pavilion dv6000z Notebook
I NEED TO OPEN THE CASE TO GET INSIDE
please visit following website to get ideas to open up you laptop.
http://www.insidemylaptop.com/take-apart-hp-pavilion-dv6000-laptop/
http://www.refurbished-laptop-guide.com/how-to-replace-laptop-keyboard.html
thank you,
Mar 24, 2010 | HP G60-235DX Notebook
Every time I turn on my new PC I get a black screen with writting on - it says Boot Device Not Found Please install an operating system on your hard drive Hard Disk (3F0) F2 System Diagnostics for more...
I have the exact same problem with my HP HDX 16. I would suggest calling the HP techcenter and exlaining the problem to them. Chances are they will want to take a look at it and will possibly replace your laptop. I haven't yet done this, but have allowed my computer to rest for a while. Leave it shut down for maybe 30-60mins and then try rebooting. Hopefully you will atleast be able to start it in safe mode with command promt. Open the command promt as the administrator and type CHKDSK which will perform a check for bad sectors in the hard drive. Hope this helps. otherwise give HP a call :)
Dec 14, 2009 | HP Pavilion dv6000z Notebook
HP Laptop Battery Problem
I had a similar problems and I had my batter replace by Hp free of charge. Most like your batter could be damage internally or it could be a motherboard problem.
I suggest you visit this HP link http://h20239.www2.hp.com/techcenter/battery/Battery_max.htm
Jul 03, 2009 | HP Pavilion dv6000z Notebook
Problems with startup
you have a problem with your memory cards.(simms)
first of swap them around ...this solves 2 probs first to see which if any maybe faulty and to make sure that theyre properly seated.
Dec 21, 2008 | HP Pavilion zd8000 Notebook
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
