My 39" TCL screen needs to be replaced only 6wks old.any idea who or where i can get one from
Screen seems to have gotten lash.and there is fragmented light coming from that point only.
  • 933 Answers
A replacement screen will usually cost more than a new set!
Posted on Nov 28, 2012
My 39 inch tcl led TV power cord got abrubtly unplugged while watching TV. Plugged it back in and now the TCL logo on the start up screen stays there frozen. Many times already tried to unplug it, wai
Unplug the tv and hold the on/off switch on the tv (not remote) for 30 seconds. This should clear any power left in your electronic boards. Then plug it back in and try again.
Sep 14, 2014 | TCL LE39FHDF3300 39" LED TV 1920x1080, 60...
Tcl tv sound
New 48" TCL tv. Hooked into cable box via hdmi cable from hdmi 2 per instructions. Problem is no sound. Screen looks great volume bar shows volume etc. Any ideas before I take it back to SAMs.
Jan 05, 2014 | Televison & Video
TCL LED LCD 55" - Backlight issues
Repair or replace the backlight.
Nov 24, 2013 | Televison & Video
1992 Ford Thunderbird Sport 5.0 HO V8 Stock AOD transmission slipping when cold, gets better when hot.
check for a clogged cooler in your radiator. back flush it. if you had a weak pump the problem would be exactly opposite of what you are describing; as a matter of fact, the majority of transmission complaints are related to a warm trans, not a cold one. I am interested in what you find out; keep in touch. btw, your throttle to trans cable is adjusted to zero lash at idle.
Mar 07, 2013 | Cars & Trucks
2007 Mitsubishi Galant TCL Off light and service engine soon light
TCL is controlled by ABS system,could have an abs sensor going bad. There is alot of things that could cause a misfire,mass air flow sensor could be dirty or need replaced.Best bet is to take to someone with computer that can read what all sensors are doing in vehicle.
Nov 01, 2012 | 2007 Mitsubishi Galant SE Sedan
Tcl tv freez no sound/picture
are you using a cable box, tried to reset the box.
Oct 13, 2012 | TCL L32D20
Valve lash specs for a 900 ford tractor
If you want to do it messy. Alot of folks that use these trrractors don't mind. fire it up with the valve cover off and adjust them with it running, tighten them till the noise goes away and then loosen just till you can faintly hear it. you may need to make a caught oil so you don't run the risk of a fire as the oil ( if it's old may burn real easy) .020 exhaust .018 intake works on most lash engines cold. you haven't mentioned the year.
Oct 09, 2012 | 2004 Jeep Wrangler
Brother sewing machine model 732 (pretty old machine) compal star My machine was sewing forward up to today. I broke a needle changed that since when it wants to go backwards...any ideas what to do I have...
have you checked the reverse lever to see what position it's in?
if the needle broke at the tip end check in the bobbin area for needle fragments
it is possible that a broken needle can jam up or even get the machine out of time.
it may need to be serviced
Aug 03, 2011 | Brother Sewing Machines
My 2007 yzf250 has lost all coolant into the engine somewhere. won't start and when trying to start it, sprays water out exhaust. iv taken the exhaust off and was full of coolant. also removed...
hi.
coolant in the exhaust, fragments of metal in the filter.........
bye bye engine.
this is something serious. something has dropped and been smashed throught one of the walls of the cooling system. there is no other way to get coolant in the exhaust like that.
the only way to find out (if you really want to know) is to strip the engine down to find where the damage is.
i really do not think this will achieve anything though. you will almost certainly need a new engine.
it will probably be cheaper in the long run than having the old engine stripped down, finding the extent of the damage, and replacing any affected parts.
Jul 06, 2011 | 2008 Yamaha yZ250F
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
