Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
Ice maker does not make ice
Ice maker worked fine until we were without power for a week due to storm damage. After power (and water pressure-no power = no water due to being on a well) was restored, the ice maker did not make ice. Water is dispensed from the door, but there is no ice being made.
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Is the freezer freezing the contents good?
Posted on Nov 27, 2012
  • Allen Clark Nov 27, 2012
    Yes it is. Remember that this is separate ice maker in the upper refridgerator section. The freezer is in the bottom and is working correctly.
SOURCE: Maytag MSD 2432GR Water not feeding into Ice Maker
one possible solution is that the ice maker water valve has failed (solenoid). I would try switching the wires on the water valves and see if water goes into the ice maker when you push the water dispenser button, if it does the valve is ok. If you go this far go ahead and fill the ice maker with water ( about half to two thirds full) switch wiring back as first found and see if maker will freeze and dump ice, if it does ok, if not the problem is probably in the ice maker.
Posted on Sep 08, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Ice maker is not working anymore. Water doesn't fill the tub. Water dispenser out of the door is still working
I need you to double check the model number. Maytag has a service library at this link. http://www.servicematters.com/maytag_library/html/index.html
By placing the first 3 letters in the search feature it will take you to models like yours. Chose the correct model that you have and enter the number in the search. I believe that the water control valve on back of your refrigerator is the problem. Maytag is very good about helping their customers. Let me know if you have problems gettting the information you need, Thanks, Sea Breeze
Posted on May 26, 2009
  • 35 Answers
SOURCE: Ice maker sprays water...
sounds like the inlet part on the ice maker is froze over or not lined up in the opening of it right or a possibilty that the ice maker is leaking out the water if that is the case the ice maker needs replaced
Posted on Jun 07, 2009
woodchuck789
  • 4070 Answers
SOURCE: Maytag MSD2754GR - Ice Maker quit working.
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Posted on Aug 29, 2009
Testimonial: "Good trouble shooting tips...will give them a try and see how they go, THANKS!"
SOURCE: ice maker will not dispense water or ice.
sounds like maybe the switch that is press to release water not working so it doesnt sent the signel to let water out dispenser
Posted on Sep 29, 2009
Samsung Rs2530B frig had power outage, now cubed ice is blinking and water and ice dispensers are not working.
CONTROL BOARD ON REAR PANEL IS MOST LIKELY THE PROBLEM .THIS IS COMMON WITH STORM DAMAGE..
Apr 26, 2017 | Samsung Washing Machines
Top ice maker in Samsung RFG298AAPN does not make ice. No water cycles into icemaker. Icemaker has been reset, nothing after 2 days. Should I replace the icemaker or the water valve.
On these models I've noticed that the temperature in the ice maker area warms up due to a ball of ice forming inside the freezer compartment ice maker fan that has vent going to the ice maker. Until it is found whether or not that ball of ice is blocking the vent and fan you won't be able to go to the next step. The switch on the ice maker will test the ice maker by filling it with water and rotating the Forks that dump the ice into the ice bin Appliance 911 Sea Breeze
Aug 31, 2016 | Samsung Refrigerators
Westinghouse ice maker quit working
Is it your ice maker, or possible the blades that crush the ice or dispense the cubes? What can happen in the latter case is that during the storm the ice melted and pooled in the cutter mechanism. Then, when power was restored, the blades were frozen solid. To fix, investigate taking out the cutter mechanism and letting it thaw and drain. Then reinstall and use frequently for the first few days to prevent refereezimg.
Feb 26, 2014 | White-Westinghouse White Westinghouse...
LG LFX25976ST refrigerator water in door but no water to ice maker
Check for 120 V at valve when it is supposed to be filling
Apr 01, 2013 | U-Line Refrigerator Ice Maker
Ice machine isn't working
Two things come to mind.
First, the water valve at the bottom rear of the refrigerator may have failed. You didn't mention if there is a water dispenser and whether or not this is still working. This valve pumps water to the icemaker and water dispenser when the control unit of the icemaker calls for water. Also, there could be a blockage in the line which brings the water to the icemaker.
The other possibility is that the part of the icemaker controls which calls for water from the valve has failed. If this has happened, it would likely be more cost effective to replace the icemaker unit.
Oct 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker not working
Hi!!! your ice maker might have frozen over and gears are stuck..remove your ice maker and unplugg from the frig clean it and all is resolved..
Jan 04, 2009 | Refrigerators
Ice Maker Not Making Ice
There is no pump per say.. the water pressure is all that fills the ice maker and provides water to the drinking dispensor. The solenoids are also different, one activates for ice maker and the other for drinking water. The fastest way to check water flow is to swap the wires on the solenoids so the drinking water "power" will now power the ice fill solenoid. Once the plugs are swapped and you press the drinking water lever the ice maker should pour water out the fill tube. If that works then you know the solenoid, tube, etc. are all fine. I'd suspect then that the ice maker fill solenoid isn't getting power when it is suppose to fill. Let me know what this test result is.
Jan 23, 2007 | Samsung RS2534 Side by Side Refrigerator
RS2556SH Side by Side - Icemaker not filling; fill tube not iced over!?
press the reset button (black) on the bottom of the icemaker, the system will go through a cycle, and water will pour into the tray.
Oct 23, 2006 | Samsung RS2630SH Side by Side Refrigerator
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
168 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
