Question about General Electric WCVH6800J Front Load Washer
My GE washer model #WCVH6800J1MS occasionally leaks from the bottom. It sits on a pedestal so I can't see exactly where the water is coming from.
It doesn't always leak. Sometimes I can do one load and it will leak and other times 4 or 5 loads and no leaking. Today I did 2 small loads and it leaked quite a bit.
  • 4 more comments
  • Cindy Merva Nov 29, 2012
    Richard and Christopher, I removed the panel and found that water was leaking when the tub is filling. It is running down the left hand side of the manifold that surrounds the front of the tub. It appears to be dripping from the area under the soap/softener dispenser. Can I remove that front panel to find the problem? I loosed the two screws at the bottom but it doesn't seem to want to come free.
  • Richard Roth
    Richard Roth Nov 29, 2012
    Remove the top and run a load to see is it is coming from a dispenser line.
  • Cindy Merva Dec 04, 2012
    Richard, I reomoved the top and found that the leak is a slow drip from the tray that the soap/softener is dispensed into. The leak occurs a the lower part of the tray where it conncects with another plastic pipe which feeds the drum. The connection appears OK. Suggestions?
  • Richard Roth
    Richard Roth Dec 04, 2012
    I am not 100% sure which part it is that needs to be replaced so here is the parts diagram for the dispenser. You can scroll down to find the part you think needs to be replaced. Keep me posted! http://bit.ly/XmFqdF
    It is leaking at the junction of the tank (150) and the the water inlet pipe (136) where the seal (137) is located. I do not see any damaged parts and the connection appears secure. Thoughts?
  • Richard Roth
    Richard Roth Dec 05, 2012
    I would replace the seal then if it is leaking there.
    Top Expert:
  • General Master
  • 9,472 Answers
Remove the 3 screws from the lower kick-plate and run a load to see if you can find where the leak is coming from.
Posted on Nov 28, 2012
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
  • 57 Answers
Contact some of the service provider to make to clear the problem.....
Posted on Jan 10, 2013
  • staurt Jan 10, 2013
3 Suggested Answers
  • 44 Answers
SOURCE: My Ge front load wcvh6800j1ms
Sounds like you could have a pump problem or a loose hose. First, go ahead and clean the drain pump filter (as per instructions in the Use & Care Manual). Screw it back in tightly to see if that resolves the issue.
If not, check this posting for how to run a diagnostic test: http://www.fixya.com/support/t9576766-found_small_part
Test T02 will show you the most recently encountered codes. At the bottom of that posting is a link to the code definitions with problem resolutions: http://www.fixya.com/support/t9556917-ge_model_wcvh6800j_error_code_04
If you don't get any error codes and all tests run correctly, open the front access panel and see if you can figure out where the leak is originating from (To remove the panel: undo three screws and lift from the bottom).
Good Luck.
Posted on Jul 28, 2011
  • 44 Answers
SOURCE: my GE model wcvh6800j1ms front
Front right would most likely be the discharge pump. Here's a diagram:
Please post back once you either have codes or have located the leak source...then we can troubleshoot more.
We have the Kokols Wallmount Bathroom Pedestal Glass Sink Vanity Combo but the p-trap keeps leaking. How do we fix it?
Remove it, (Don't forget water will come out when you uncscrew it!!!) clean it thoroughly, especially the ends, clean and check seating of any rubber washers to make sure they are fitted correctly and not being distorted when the rings are tightened, reseat it with no force (it should sit naturally without having to force it in) and tighten rings. There are lots of videos on youtube showing how. If you cant stop it leaking buy a new trap. It's worth while looking very carefully for exactly where the leak is before you remove the trap, it might be coming from higher up. Repair Leaky Sink Drain Pipe
Jun 21, 2014 | Kokols Clear Vessel Sink Pedestal Bathroom...
Leaking into wash tub
The water inlet valve needs to be replaced. It is not sealing.
Here is a link to the part you need.
Aug 13, 2012 | GE Profile WPRE6100G Top Load Washer
Model # GSH22VGPC CC water leak
Evaporator condensate should go to pan for evaporation. If the amount exceeds pan capacity during defrost cycle it could overflow to the floor.
Sep 03, 2017 | GE Refrigerators
Ge washer whdvh660hww drain plugged
THE GE WASHERS HAVE A PUMP FILTER BEHIND THE LOWEST PANEL ON THE FRONT. ON THE FRONT OF THE MACHINE AT THE VERY BOTTOM, REMOVE THE THREE SCREWS TO REMOVE THE BOTTOM PANEL AND YOU WILL SEE THE ROUND PUMP FILTER HOUSING. IF ON A PEDESTAL, PLACE A BUCKET IN THE DRAWER AS WATER WILL COME OUT WHEN YOU UNSCREW THE FILTER. IF ON THE FLOOR, TILT MACHINE BACK A WAYS TO GET THE WATER INTO THE BACK OF THE TUB, NOT TOO FAR OR IT WILL COME OUT OF THE REAR VENTS. REMOVE FILTER AND CLEAN OUT. THIS IS THE PROBLEM MANY TIMES.
Dec 08, 2011 | Washing Machines
My Ge front load wcvh6800j1ms leaks from the bottom, water continues to run, and won't wash
Good Luck.
Jun 10, 2011 | General Electric WCVH6800J Front Load...
My GE model wcvh6800j1ms front load washer leaks water a bit from the front right side, any thoughts?
Apr 18, 2011 | General Electric WCVH6800J Front Load...
MAJOR leak in new JUST installed WCVH6800 front load washer
If you hear of a solution, let everyone know. Our machine did the same thing. From the research I have seen, GE makes **** machines and I will NEVER buy a GE product again.
Feb 07, 2010 | General Electric WCVH6800J Front Load...
G e energy star
Jan 26, 2009 | GE Energy Star WCVH6260F Front Load Washer
Kenmore HE3 will not HOLD water, drips out into the pedestal
check to see if there are any rips in the door seal,then take the bottom of the washer off you will see 3 screws holding it on. see if the water is coming out of the pump that is right behind the panel that you took off.
Dec 30, 2008 | Kenmore Elite 45986 Front Load Washer
Drops of water inside pedestal of washer.
Sounds like you have a leak around the door bellow somewhere, or your drain pump. The bellow is the rubber gray boot the seals around the wash tub and door. You will need to remove the bottom panel under the door to be sure. Remove the screws under the bottom edge of the panel. Once removed, the panel will drop down, then off. Inspect the washer with a load running. If the bellow leaks, a tell tale sign will be moisture showing up on the concrete counter weight in the front of the washer. Double check your drain pump and hoses as well. The pump is located directly under the wash tub in the front of the washer. The water tends to pool in the cabinet before it leaks out and drops into the pedestal drawer. If the bellow is leaking, make sure inspect it for rips and tears. You may just have a banding clamp that is loose. If the pump is leaking, make sure the clean out trap is on correctly and snug.
PS If you just purchased this washer and are experiencing problems already, this repair is covered under the one year limited warranty. Inspecting for a leak is not going to void the warranty. However, removing any major parts may. Just do an inspection to see if it is something obvious. If you suspect a part failure, get in touch with the retailer. If this was purchased from S**rs, they usually have a 30 day satisfaction guarantee. If you are not happy with the appliance, they should take it back.
Please let me know if you need further assistance.
Jun 01, 2008 | Whirlpool Washing Machines
General Electric WCVH6800J Front Load Washer Logo
380 people viewed this question
Top General Washing Machines Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a General Washing Machine Expert? Answer questions, earn points and help others
