Question about iBuyPower Gamer Computers & Internet
IBuyPower NE615FX nothing appears on screen
I am not sure what to do, the screen just says "HDMI 2 No Signal". I powered the computer on and it seems to run fine but theres just no picture displaying. I plugged the HDMI cable into my TV's "HDMI 2" outlet.
    Guru:
  • 571 Answers
Try resetting the HDMI 2 Connection. It's not communicating with the TV.
Posted on Nov 28, 2012
3 Suggested Answers
parrotheadpc
  • 2600 Answers
SOURCE: cant use hdmi with a hp probook 4510 and a polaroid 42' tv.
Did you try "Cycling" through the video out presets? Hold down the "Fn" key and tap the F4 key, do it slowly to give the computer time to react to the input. You should see it cycle through the available presets. If not, you may have to get into the display settings and "Add" the tv as an external monitor.
Posted on Aug 01, 2010
buzzpuppy
  • 36 Answers
SOURCE: How do I conect my Acer aspire 5750 lap top to my
"Out of range" means that the picture displayed by the laptop cannot be displayed by the TV, either because the resolution is not supported or the refresh rate is not supported.
Sometimes, I've had to set the refresh rate (from the laptop Display settings) to 59Hz to get it to work as opposed to the default 60Hz.
What resolution does your TV support? What resolution does the laptop support?
Matching these as closely as possible and you'll get the picture on the TV screen.
Good Luck and let us know how it goes,
-BuzzPuppy
Posted on May 01, 2011
Just got it.powers on but no signal to monitors.have tried both the hdmi and d-sub ports.help!
If this is a new PC, verify that the monitor works with another computer with the same VGA cable,leave HDMI out for now,if you don't have PC try it at a friends house,etc...Once you've verified the monitor work with the good cable then plug it back in to the iBuyPower and once you've powered it up there should be a beep from the PC signifying that it's booting up. If still no video then the separate video card might have been unseated and needs to be reseated by taking it out and putting back in ( only open the tower if warranty allows you cause you don't want to void it,in that case call the customer service) If still no video then it could be the video card,another peripheral or the motherboard could be bad.
From the specs on line if you have a DVI port then you will need a monitor that's HDCP (Protection) compliant,if that's the case I'm betting the HDMI is also and will only work that way.
Dec 25, 2015 | iBuyPower Power NE612FX AMD FX-Series 4GB...
Reset motherboard video card ibuypower
Assuming you don't have another video card installed (if you do, it will disable the on-board video, so either remove it or use the connection on the card). Do you get a black screen or no signal message on the monitor? Does the PC have more than one video output of the same type (VGA, DVI, HDMI, DisplayPort, etc.)? If so, try one of the other ones and see if they work. If you're not using a separate card and have either tested the other on-board ports or only have one, it could be that it has failed.
Jan 01, 2014 | iBuyPower Gamer Computers & Internet
Can't connect Panasonic Viera TV to PC with HDMI
Check your owners manual. Some TV's will not except PC resolutions.
Mar 20, 2013 | Televison & Video
How do i connect my hdmi cable from my ibuypower desktop to my sansung led tv?
Make sure the input on the TV is set to hdmi port 2. If it doesn't automatically view on the TV, you have to go into the graphics card adapter settings to set the view to an alternate monitor (your TV). Normally there's also a hotkey command as well (normally one of the F# keys) to switch between displays
Dec 20, 2012 | iBuyPower Gamer Computers & Internet
HDMI port not sending signal to TV from laptop
check with different hdmi monitor or check the tv with another hdmi device
Jul 16, 2017 | Acer Computers & Internet
This RCA L26HD31 TV has always worked fine in other respects... but when I try to connect my pc's hdmi cable to it for use as a monitor, I just get "unusable signal". When this TV was made, hdmi...
Make sure you have set the laptop's display properties to as low a resolution as possible (also make sure the screen refresh rate is 60 hertz) and turned it off before connecting it to the television. Turn the television on first and set to the correct input either hdmi 1 or 2. Then turn on the laptop. When it has booted up hold down the function key and the dual monitor key (either F5 or F8) for 15 seconds for an image to appear on the screen. When you have an image you can play around with increasing the laptop's resolution.
Apr 27, 2011 | RCA L26HD31 26 in. LCD HDTV
Hi. I got an LED "LG LE5500"
You wil need to connect using a DVI to HDMI cable. You can get one for about 5$
http://www.amazon.com/DVI-HDMI-Cable-6ft-Male-Male/dp/B0002CZHN6
Just connect it and choose the HDMI input its plugged into(1/2/3). If there is nothing on the screen adjust the display resolution on your computer. If you are using 1080i then the resolution should 1920x1080
Apr 08, 2011 | Video Game Consoles & Games
When I start my computer, I'll get a black screen with a bunch of text with "American Megatrends" as the header. The screen is unusual, and on the bottom it says "CPU fan error!, press F1 to...
You need to plug in your CPU fan. The CPU fan is VERY important in that it constantly cools your processor, making sure your computer doesn't over heat. If the computer runs and the fan isn't running, the CPU will over heat and cost you hundreds of dollars.
Turn off the power Unplug your computer Open up the case of your computer Find your CPU fan Find the cord coming from it Find the plug on your motherboard labeled CPU fan Plug it in there Plug your computer back in Turn it on
Mar 17, 2011 | iBuyPower Gamer Extreme 573D3 Phenom II X4...
Through Sky+ HD when selecting the HDMI connection I get the following statement through Sky "This diplay does not support HDCP....." Any help please Rob
hi,
try to connect the set top box in any other HDMI input of ur tv. reason is bellow read it carefully.
p { margin-bottom: 0.21cm; } HDCP stands for High-Bandwidth Digital Content Protection and was developed by ----------. It's nothing more than a security feature requiring compatibility between the sender and receiver, like HD cable set-top box and the TV. By compatibility, mean HDCP technology built into both devices.
Think of HDCP as a security license key like you would input when installing a computer program. Only this security key is invisible to you and me but not your TV.
It works by encrypting a digital signal with a key that requires authentication from the transmitting and receiving product. If authentication fails then the signal fails, which means no picture on the TV screen.
Buy a HDTV that has HDCP capabilities. Most will have this in at least one HDMI input but be sure to verify this before buying the TV.
Notice that "in at least one port." Not every HDMI port on the TV will be HDCP compliant so be sure to read your TV user manual if you plan on connecting a HDMI cable to your TV.
ok
Jan 13, 2011 | Toshiba 32WL56 32 in. HDTV-Ready LCD...
I just bought an "iBUYPOWER
call ibuypower technical support. if you brought it from them
if it's under warranty call the company you brought it from.
if you try to fix it yourself, the may not take it back. and keep your money.
that being said make sure your monitor is plug in the right port from the picture I saw on newegg, they have two ports that it can plug into a blue vga port or a white dvi. you want to plug into the one on video card.
May 24, 2017 | iBuyPower Gamer Power 918I Desktop...
Computers & Internet Logo
156 people viewed this question
Top iBuyPower Computers & Internet Experts
General Systems...
NOEL
NOEL
Robin Hill
Robin Hill
Are you an iBuyPower Computer and Internet Expert? Answer questions, earn points and help others
