Question about Microwave Ovens
Replace light in microwave kitchenaid superba model kemc378k
MicrowaveSvc
  • 9098 Answers
SOURCE: KitchenAid Superba Microwave/Oven, Microway Door message
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order one from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Sep 27, 2008
SOURCE: Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
Posted on Mar 26, 2009
SOURCE: I need to rplace the bulb in the interior of the microwave. It's loose in the top housing.
some of the front(vent) covers have a sliding hook I think you need to push it to the left. You should be able to access the bulb when you get that off.
Posted on Jun 01, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: I need to replace my kitchenaid superba over the
Your owner's manual should have the part numbers and instructions for replacing them.
You can download owner's manuals and installation instructions for several brands (including Amana, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
If the manual does not cover it, then it's not designed for the owner to do, you would need to remove the oven from the wall and remove the outer cover.
You can find links to helpful exploded view diagrams and part ordering help here. I'd recommend that your bookmark this link to your favorites.
Once you get new bulbs in, if they still won't come on, or if they're stuck on, or you have trouble with either fan, the surge of the failing bulb may have damaged the board.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or two.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Dec 13, 2009
localwonder
  • 6784 Answers
SOURCE: Kitchenaid superba combo. Microwave gives
HI, this is an indication of a failed door switch. When the switch fails, the control cannot recognize the closed door signal. Simply replacing the door latch mechanism will solve this issue.
Replace the door latch assembly, asap.
Posted on Dec 22, 2009
Kitchenaid superba microwave oven combo.. the microwave turntable will not turn only clicks
try to turn the coupling, either stripped broken coupling, or bad gear in drive motor. should not be able to turn by hand
Apr 08, 2018 | KitchenAid Microwave Ovens
Where can I find out the wattage of my Kitchenaid Superba 853879154001 Combination Microwave? It is not on the door sticker.
Sarah,
That model number is not coming up as a good number, but another model that I looked at said that particular model was a 900 watt microwave.
Aug 08, 2015 | KitchenAid Microwave Ovens
Kitchenaide Superba #4450786A unit turns on but will not heat at any setting. What can I do to fix?
Magnetron needs replaced.
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
Cheaper to buy a new Microwave oven.
Jul 11, 2014 | KitchenAid KCMS185J Microwave Oven
Kitchenaid Superba range oven will not ignite
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Apr 26, 2011 | KitchenAid Microwave Ovens
Dec 22, 2009 | KitchenAid Microwave Ovens
My Kitchenaid Superba kaw38avm726 microwave does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dhjjd
Nov 20, 2009 | KitchenAid KEMC377K Convection / Microwave...
Jun 01, 2009 | KitchenAid Microwave Ovens
Mar 26, 2009 | KitchenAid Microwave Ovens
LIght bulb burned out
I a Kitchen Aid Buit-in microwave (KEMC308KSS01) with the same problem - light went out. Can you send me the instructions on how to replace the bulb? Thank you! dlhamilton@comcast.net
Jan 23, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
