Samsung Model HL-85086W Turning itself off and Lamp Light Blinkin
My Samsung rear projection DLP TV just started turning itself off and the lamp light is blinking.
This worked
Posted on Sep 08, 2012
It keeps blinking turns on then off
Posted on May 23, 2011
  • Monicalove May 23, 2011
    Yes it does
  • krimi Aug 11, 2011
    It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Samsung DLP not turning on
usually the colorwheel will prevent the set from powering up when all three lights blink. Diagnosis assistance is available for free from www.tvrepairworld.com
Jun 15, 2012 | Samsung HL-S5086W 50" HDTV
Test the lamp
Lamps can't be tested. All you can do is replace it or try your old lamp in the exact same TV model. in most cases though your TV will have a lamp indicator light on the front panel that will come on when the lamp needs replacing.
Mar 08, 2012 | Samsung DLP HL-P4663W 46" Rear Projection...
I can hear the movie but do not get a picture but the lamp light is blinking
Ur tv Projection lamp is dead.Ur tv Projection lamp,require replacing.The "LAMP"LED light indication blinking flashes or stay on.The projection lamp must be replaced,tries websites like Tvrepairworld.com,Partstore.com,Ebay.com to buy a new projection lamp.
Aug 04, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Sound but no picture - won't stay on
you may check your lamp first. other than that i would say a faulty mains board.
Apr 16, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung 46" DLP
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Nov 08, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Samsung DLP HL-P5063W
you have the same problem I have. The problem is fixed by changing the new light bulb. The problem appears again after 1500 hours of use. You can keep buying new light bulbs or avoid it by not buying another Samsung TV.
Sep 23, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Televison & Video Logo
1,385 people viewed this question
Top Televison & Video Experts
Electro Med Services...
