Question about Young Living Aria Ultrasonic Diffuser
Young living aria diffuser not misting
I changed the membrane but the misting is still light
  • Diane May 11, 2013
    Are you still having this issue. I just received a brand new one today but it is not misting at all
I am having the same problem. I have no misting at all, only music and colors. I am going to try moving the glass spout so it's opposite the plastic spout--i read that somewhere. I'm also going to start over again with filtered water. I had gotten into the habit of just reflilling and adding more oils. hope this works and helps you too!!
Posted on Dec 07, 2012
  • 3 more comments
    Did you find a solution. I just received mine and am having the same issue.
  • niamo
    niamo May 13, 2013
    I'm sorry to hear you just received yours and its not misting. You have to make sure the glass opening is opposite (relatively) the inner plastic "spout". Beyond that, I had to call young living and order a part that cost $5. It worked. 800-371-3515. hope this helps. They said my whatever-its-called plate was run down from use. That's why i think you just have to toy with yours a bit more. I didn't ace it at first either. Now i love it!
  • imajwru
    imajwru Dec 08, 2013
    I am having the same problem with mine. Colors and music but no diffusing.
  • niamo
    niamo Dec 08, 2013
    call young living and get the part, it's only $5 or at least that's what it was last year. Now my Aria works perfectly.
  • Lori Peapenburg
    Lori Peapenburg Jan 24, 2014
    what part did you get? I'm having the same problem and they didn't have any parts available that would fix no mist/diffusing?
How do I clean the dual tank ultrasonic humidifier membrane
Air Innovations Clean Mist Ultrasonic Dual Tank Humidifier ...
www.qvc.com/Air-Innovations-Clean-Mist-Ultrasonic-Dual-Tank-H...
QVCAir Innovations Clean Mist Ultrasonic Dual Tank Humidifier. Air Innovations ..... I did not realize that you needed a special filter if you have hard water. If you do ...
Sharper Image Dual Tank Warm &Cool Mist Ultrasonic ...
www.qvc.com/Sharper-Image-Dual-Tank-Warm-&Cool-Mist-Ultras...
QVCSharper Image Dual Tank Warm &Cool Mist Ultrasonic Humidifier ..... I've only had toclean the membrane once since I purchased it, and that's really not a big ...
How to Repair an Ultrasonic Humidifer ' eBay
Dec 14, 2015 | Humidifiers
Du915 won't change cycles
most likely the control board is bad, but the buttons/touch membrane has known to go bad. The most likely fix is to replace membrane and board. The diagnostic skills needed to find the exact part is time consuming and not easily done.
Dec 29, 2014 | Dishwashers
Windows misting up
Check where the mist is forming.
Does it smell like anti-freeze?
A lite mist on passenger side with loss of coolant you should do a coolant pressure test.
Jan 11, 2014 | Cars & Trucks
My RO light has changed from red to green. What does that mean? Red was the normal color.
Green is the color it should be when producing GOOD (low TDS) water. A constant Red light indicates the TDS is high (relative to what the normal TDS rejection is on your water supply) and the membrane needs to be replaced. Frequently the TDS light will be RED when initially drawing water at the RO faucet because of a spike of TDS coming through membrane from static water in line.
I suggest taking a sample of pretreated water and RO water to a dealer for a TDS test to see if the Membrane needs replacing.
RJ
Jul 30, 2011 | Culligan Under Sink Water Filter
Air-o-swiss membrane coating coming off, is this a
no its not a problem if you dont mind how the system looks...otherwise just get some oil paint and re-coat it
Jan 31, 2010 | Swiss Air-O- 7135 Warm Mist Antimicrobial...
Sunbeam warm mist humidifier model SWM2142 Change Light is on
Press and hold the Mist button for three seconds, the change light will blink and shut off. This is for a demineralization cartridge that you can buy separately it will turn on again after 30 days of use
Jan 25, 2010 | Sunbeam Dehumidifiers
Two led water purity monitor problem
The LED monitor should light up as Green when the membrane is producing the proper water quality (80%+ TDS rejection). If the LED light stays Red this indicates the RO membrane is bad, all the filters (including membrane) should be changed and system sanitized. The batteries in the TDS monitor should be changed yearly also. Don't have a lot of faith in that indicator light. The best way to test for TDS rejection is with a digital TDS meter which indicates the amount of rejection. Compare the incoming water to the product water of the RO.
RJ
Jul 17, 2009 | Culligan Under Sink Water Filter
Air-o-swiss 7135 humidifier not misting
Ours has done the same thing after only 2 weeks. From article research, it appears that this occurs to everyone after cleaning it with the EZ Cal that is recommended. From looking at our unit and figuring out how it works, it appears as though the Ultrasonic Vibration membrane has stopped working. This particular piece is responsible for vibrating the water and making water mist particles which are blown out with the air. We will be calling the manufacturer on Monday to register a complaint and request a replacement unit.
Nov 23, 2008 | Air-O-Swiss 7133 Humidifier
Young Living Aria Ultrasonic Diffuser Logo
2,080 people viewed this question
Top Young Living Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Young Living Health and Beauty Expert? Answer questions, earn points and help others
