Question about DISH Network ViP622 DVR DTV Receiver / 180-Hours Video Recorder
Dish Box turns itself off every night and not back on.
Box turns off and stays off till I turn it on or a timer comes on.
  • Official Brand Answer
  • 263 Answers
C Dunn,
I can definitely provide assistance with this. Whenever our receivers do their nightly update, the receivers do enter standby mode. There is no way to disable this, but you can definitely setup an Auto Tune timer. This will cause the receiver to exit standby mode and tune to a channel.
To set this up, find a channel you want the TV to go to, and choose the time you want the receiver to turn on. Press record from the guide. Select 'Auto Tune' from the list, and select 'Daily'. This will set it up to happen every day.
If you have any other questions, just let me know!
Tommy Faust
DISH Social Media Representative
Posted on Nov 29, 2012
2 Suggested Answers
SOURCE:
  • 374 Answers
SOURCE: Timers & recorded events erased
Ocassionally these receivers have been known to do this. It is not an issue that normally repeats itself however it is very frustrating. The upside is it ussuaaly will result in 150 hrs of record time. If you did not receive the150 hrs delete all timers and recording and reboot the system. You should have the 150 hrs once it comes back online. Thanks for using Fix Ya.
Posted on Aug 15, 2009
AIWA model # CXNHMA56U powers on by itself in middle of night
It it turning on or just going into demo mode? There could also be a timer function that is set to turn it on at a certain time.
Mar 07, 2013 | Audio Players & Recorders
Once the TV is turned on, the sound and picture disappears and replaced by a blank screen. If one turns it off again and on imediately the picture and sound returns. This may happen several times in a row,...
Could be ethier one the dish box or the tv itself have cold solders joints on the FBT-Flyback transformer.That the big black block of plastic with a red wire with a black cap hook to the CRT-(tv tube).Call ur tv Dish box customer service,get a replacement box.See, if this will solved ur tv problems.If not,than the tv must be taken aparts and must have tools like a soldering iron,a roll of solders,also must know basic soldering.Resolders all the coldsolders joints on the FBT for a better High voltages contact to the CRT-(tv tube).This problems,will be solved.
Dec 03, 2010 | Philips Magnavox 27MS343S 27" TV
FRS20121WAL preivously it has turned its self
Your defrost timer may be malfunctioning and staying in defrost mode too long. It is mechanical and the timer can be sticking or slipping. I think your timer is behind the kick panel on the front bottom of the freezer/fridge. You can turn the timer till everything cut off and watch to see if it runs. Everything should come back on in approx 20 minutes. You can test it with a ohm meter. See how here> How to check stuff> http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 21, 2009 | Refrigerators
Our refrigerator is no longer staying cool and now the freezer isn't keeping things frozen.
How to check everything
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 11, 2009 | Refrigerators
Aug 02, 2009 | DISH Network DVR-625 DTV Receiver /...
Sound but no picture - won't stay on
you may check your lamp first. other than that i would say a faulty mains board.
Apr 16, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
TV turns on at night.
check your TV's timer setting. typically you'll notice something different about the standby light - for example, it might be a different color, or might be blinking, etc to indicate that the timer feature is activated.
Mar 19, 2009 | Hitachi Televison & Video
Jvc digibox
hi try turning the sky box on wilst holding the back up button in, wait till the on screen message comes up on the tv then let go of the button, wait till the message goes off the screen then try turning the sky box on if it dont then you will need a new box.
Jul 27, 2008 | JVC Audio Players & Recorders
JVC TV crisis.....HELP
yes... i actually work at verizon the tv is to old for fios because fios is so advanced we run off ot 720 to 1080 depending on areas. what kind of box is it? is it the hd box or stb>
Feb 13, 2008 | JVC AV-32230 32" TV
DISH Network ViP622 DVR  DTV Receiver / 180-Hours Video Recorder Logo
506 people viewed this question
Top DISH Network Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
matt martin
matt martin
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
