Question about Refrigerators
Water in bottom of freezer
Model kfrf 19mpal00
    Problem Solver:
  • 16 Answers
Water in bottom of freezer means freezer not freezing. ice in bottom of freezer means condensate drain clogged
Posted on Nov 28, 2012
  • carmon dilworth Dec 05, 2012
    yes there is ice in the bottom of the freezer. Where is the drain?
Why does water freeze on bottom of freezer
Short answer: Because it's cold. It's what freezers do.
The long answer requires you to describe a bit more about what you've got and what is happening. What model freezer do you have? Is it a frost-free, or manual defrost? How old is it? Does it have a built-in icemaker?
Possibilities:
1) Your freezer is leaking some water from the ice maker or possibly the through-the-door water connections.
2) Your door gasket is no longer sealing, and humid air is getting in to the freezer, where the water condenses out and falls to the bottom of the freezer, creating ice. Make sure the door closes completely, that nothing stops it from closing, and that the gasket is tight; put a crisp dollar bill between the unit and the door gasket, and see if you can easily slide it around. If so, you need a new gasket.
3) Or, you may have a frost-free model and the hole where the water from the defrost cycle is supposed to drain is clogged. Pull things out of the bottom of the freezer, melt the ice, and see if there's a small hole. If so, make sure it's clear and clean; use a small brush, not anything sharp or abrasive.
Sep 07, 2014 | Refrigerators
Can I get the upper left hand door hinge for my KitchenAid fridge/freezer model KFRF 19M
I believe they are available through Sears Parts Direct and that site address is:
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Refrigerator-Parts/Model-KFRF19MTWH00/0593/0161000/O2009565/00002?blt=06&prst=&shdMod=
Sears will hose you for shipping but they normally have the parts you require.
Jul 20, 2012 | KitchenAid Refrigerators
Model No.ERF415M 13CT. I have ice forming underneath the bottom freezer draw, when I open the door it melts and runs out as water under the appliance.
drain is plugged up were it is normally drain to defrost the freezer completely find a place to store food in freezer for a few ours leave door of freezer open pull out all shelfs and lay a few tools down at bottom of freezer were you seen the ice build up after you have done that pull ref away from wall take back of bottom look fro drain pan with a turkey baster send water thru back of freezer inside if water still flows back out into freezer drain tube is still clogged use warm water when doing this if you see drain pan full of water use a shop vac that can deal with water suck out water send water again water should go strait to drain pan if still flows out may have to remove drain tube
Aug 23, 2011 | Daewoo Freezers
Water leaks out of freezer bottom same time every day model rsd22
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 13, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water on the bottom inside the Freezer
the water usually comes from the evaporator defrosting and the drain being plugged with ice or frozen water. try a hair dryer and defrost the frozen water and clean the drain plug and hose
Mar 18, 2010 | Frigidaire Model: PHSC39EHSS
Kenmore elite side by side has water that pools in the freezer.
you need to clean out the freezer drain at the back of the freezer,use a hair dryer and a hanger or maybe a shop vac can **** it out-mike
Mar 16, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water freezing up in the bottom of the freezer
your defrost drain is stopped up then when it defrosts in steed og going down the drain its running in the freezer floor remove the back panel in the bottom of the freezer and clear the drain hole under the evaporator
Mar 12, 2009 | Kenmore 53642 / 53644 Side by Side...
Bottom freezer door dripping water on kitchen floor
you can take a ook into the freezer sect its possible that the line has frozen, nad no longer is defrost water going into the drain but rather falling on to the floor of freezer and evnetually out the door
Jan 11, 2009 | Freezers
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
