Question about Sony VAIO VGN-N110G/W Notebook
Pc voice service
This does usually happen every time i try to make a phone call using my modem
    New Friend:
Yes
Posted on Nov 27, 2012
Help, my voice call in Yahoo messenger suddenly will not connect to the server. I have been making calls from PC to PC for many months and lastnight it just stopped letting me connect to my friend. I get a...
As you said you were able to call or using the voice call from yahoo messenger for 2 months I understand that your IP( Internet Protocol) address is banned from yahoo voice server.
To fix this issue, If you are connected through a personal modem restart your modem in order to change the IP.
Or if you using Fix (static)IP address from your ISP/Network vendor ...contact them to change the IP or try use VPN(Virtual Private Network) connection to authenticate/connect with different address.
Hope that will help you.
Thanks for joining us.
Good luck
Nov 21, 2009 | Yahoo Messenger
Can't send or recive Faxes
Try resetting the machine to it's defualt settings.
Jun 18, 2008 | HP Photosmart C6100 All-In-One Printer
Tip
Troubleshooting for modem.
Problem:-
User's modem does not dial or does not connect.
Tip:-
Prove that computer is connected with phone line and check that phone line contains dial tone.Therefor check that connection is connect or not.
  • Connection may not be less than six feet (1.8 meter).
  • Check dial tone by plug in the phone in phone jack.
  • If user has many more services (such as call waiting,call messaging OR voice mail) then check that these all are cleared or not and check call waiting is disabled while using modem.
  • Disconnect any answering machine,fax machine or printer which are on line with modem.
  • Check that are you not using digital,rollover or PBX line?These type of lines not works with modem.
  • Try with another phone line. (For this, you have another phone number or another phone line).If user connected with another line then you need to complain in phone company.
  • Try to connect modem with low connection speed.
on Apr 13, 2010 | Computers & Internet
I want my pc to connect with internet via bluetooth of mobile phone but a dialogue box appears with the message that "modem is removed"
Hello, Not knowing the brands or models of your pc and mobile phone, for that you nedde that your pc recognizes the modem that your phone has inside of it. Usually, first install the software on the pc, then connect the phone and watch what happens. Should load/recognize the modem in your phone. You can always perform a software update for your phone and try it again. Regards.
Jun 08, 2009 | Compaq Presario Notebook
DHG535-2 and LAN switch issue
It sounds like the LInksys that they replaced was also a router. A router will route packets to multiple pc's that are connected to it. The cable modem just sees the router as 1 pc. When you use a switch, the cable modem will see all of your PC's. and Comcast just allows 1 pc. You will need to buy a router to use more than 1 PC which will be cheaper than using Comcasts Home Networking service which will network up to 4 pcs
May 29, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
Allows your PC / modem to serve as your fax & voicemail machine.
No, this is a fax/data modem. It can be used for internet access and for fax services. You need a voice modem for voicemail services
Apr 15, 2009 | Hiro H23534 (649258235347) Modem
I can;t received faxes on my computer
Are you using DSL connection or Dial-up?
What OS are you using?
The fax line and voice line are using the same frequency so you should be able to fax directly from your pc fax modem when using Dial up connection but in DSL the data and voice are using different frequency. So in normal situations you wont be able to fax using DSL modem unless you use a separate fax machine.
However, if specified during the set-up of the DSL line, the signal can be separated so that some of the bandwidth is used to transmit an analog signal (for voice and fax) while the remaining bandwidth is used to transmit digital data. This allows for the use of the telephone or fax, and computer on the same line and at the same time. When inquiring about DSL with the service provider, specify the desire to use the phone line for voice or fax calls while connected through the computer to the Internet.
Reference the following setup options for using a DSL line with HP all-in-one or fax products.
Please refer to my solutions to your issue at http://www.fixya.com/support/t1440518-want_able_fax_from_computer_even_though
PLEASE RATE MY SOLUTION.
Jan 17, 2009 | Computers & Internet
Cannot send faxes when using cable company's digital voice modem
Fax machines must have a standard analog phone line. They won't work on a digital line and can actually be damaged if hooked up to one.
Nov 09, 2008 | HP LaserJet 3050 All-In-One Printer
Modem and router
If there is no network or internet activities it means either network is down from ISP, or there is a phone line cable or broadband filter problem, or broadband settings on modem are lost and must be reinstalled.
Usuall you fix this kind of problems by calling your Internet Service Provider toll free customer tech service number.
They will follow you step by step in fixing the problem.
Aug 11, 2008 | Computers & Internet
Firmware Upgrade?
i have pap2 phone adapter it has some problem. i says This is the voice massage i have got it from my phone.
Connected in the incorrect phone port. Please try other port. If you believe
your correct port. Please log on to your web account to check your states of
your service O108.
This is the voice massage i have got it when you pickup the phone
immediately the voice massage will comes.
please help me anyone
Thanks
partheeban
Jun 08, 2008 | Linksys SPA-2102 NA Analog VoIP Adapter...
Sony VAIO VGN-N110G/W Notebook Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
