Question about RCA M4204 MP3 Player
How do I acces and Play a playlist
I can't seem to find the play list to play
  • crv957 Jan 14, 2009
    You say push down the arrow buttons and the that should do it. Hit the what?
  • 159 Answers
Turn the player on. HIt the power button again. Push the - or + button and scrool down to what you want. Pictures, music, video etc.
then push down the arrow buttons and hit the that should do it.
Posted on Jan 12, 2009
How do I get it to play Windows Media Playlists
Hi there
The ability to play a Windows Media Playlist, will depend upon the play software built into the mP3 player. If the software does not recognise the playlist file type then it will not play the list. Equally, the Windows Media Player list will remember the locations of the files on your computer, ie drive letter, folder, subfolder etc.In fact the whole file tree to each media file. This is unlikely to be the same on the mp3 player, and even if the player will recognise the playlist file format it probably won't be able to find the files as they won't be in the same location as the playlist is pointing to.
I suggest that you prepare separate playlists for the mp3 player.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Feb 27, 2015 | Audio Players & Recorders
Hii.. i recently buy lava a10 but i m unable to add songs from my memory card to the audio player's plat list. tell me how can i do that?
Menu-Audio player--Playlists-Create playlist--Now create playlist as you want-Now select same playlist which you have created-Options-Add-Now if you want to add single song, please click on song name and song will be added-if you want to add multiple song, then select "Multi" option from left side of the bottom-Mark the multi songs -Now press "Done" from left side of the bottom-Now select the first option of "Play" to play songs of playlist.
Mayank Purohit
Jul 25, 2011 | Cell Phones
Unable to play playlists on my Hitachi MP3
You can try dragging the playlist into the folder that you open up when you connect the player and then you want to drag and drop music. Then drag the folder and drop into the music folder which means you are copying from the player to another folder on the player. This manages to solve the problem of the player re-arranging files alphabetically and may help your playlist issues.
Jan 28, 2009 | Hitachi DMP-7 MP3 Player
Bose sound-dock portable remote doesn't seem to move between play-lists on the new ipod nano.
Make sure you don't have any empty playlist that was the issue that I had. I re-synced with the empty playlist removed and it worked perfectly.
Nov 12, 2008 | Audio Players & Recorders
Playlist Upload...
There is a well known problem with the sansa regarding playlist..I am sure sandisk is working on a firmware right now that will fix the issue you are having..
Oct 23, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Philips GoGear SA3245 - Playlists Not Showing Up on Player
Have solved this problem on GoGear syncing with WMP 11 by going to options on the device itself, then go to the "settings" option, scroll down to "PC Connection Preferences", from here you will select the check box saying "MTP" then back out of options and connect your device and go back to your WMP 11 and drag your playlists to the syncing area and resync your device. You should then be able to see your playlists under the playlist option in music along with the "playlist on the go" playlist.
Hope this will help!
- Jared
Determan Technology LLC
Aug 31, 2008 | Philips GoGear SA3245/37 Digital Media...
Making playlists
yes you can create playlist using WMP11...
To create playlist using WMP
  1. 1. Click the Library tab. If you need to clear the List pane before beginning to create your playlist, click the Clear List pane button playing_i_clearlistpanebtn.gif.
  2. Drag items from the Details pane to the List pane to add them to the new playlist.
    To select multiple adjacent items, press and hold the SHIFT key while selecting. To select nonadjacent items, press and hold the CTRL key while selecting.
  3. To rearrange items, drag them up or down in the List pane.
  4. To save the list, click Save Playlist at the bottom of the List pane, and then type a name for the playlist.
    By default, playlists are saved with a .wpl extension in the Playlists folder, which is usually located in the Music folder. You can also save playlists with the .m3u or .asx extension. To do so, click the List button at the top of the List pane, click Save Playlist As, and then change the extension in the Save As dialog box. Once you save the playlist, it's added to the Playlists category in the library.
    To play the playlist in the List pane, click the Play button playing_i_playbtn.gif.
  5. To access the playlist in the future, click the Playlists view in the Navigation pane.
I hope that helps
Please rate accordingly
Thank you
Computerrep
Jul 19, 2008 | SanDisk Sansa Connect MP3 Player
Play listing
open your music player.
select playlist
select new playlist
type name of list
select folder that you want to play(click mark)
now click more option
select add
n enjoy
Jul 08, 2008 | Sony Ericsson K790i Cellular Phone
Can't create or play 'playlists'
Create your playlist with winamp and then copy it over with the songs listed in the playlist. You can make as many playlists as you like and they will show up under "playlist" on the screen
Jan 20, 2007 | SanDisk Sansa m250 MP3 Player
RCA M4204  MP3 Player Logo
53 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
