Question about DISH Network Televison & Video
Dish Network box..How do I set the DVR to dual mode?
I need to set the TV to dual mode so I can set the default to record on TV1. It is not giving me the option and I dont know how to change the DRT to dual mode.
  • 84 Answers
Can't you call the customer support number for DISH Network in your area? They can trouble-shoot for you and tell you what to do to set it, since it's their equipment. The number is probably on your bill each month.
Posted on Nov 27, 2012
5 Suggested Answers
  • 374 Answers
SOURCE: adding tv to a dish network dvr
Your upstairs tv is connected via a coaxial cable and you can do a few things to get programming to the third room.
The first is to locate the wire that enters the upsairs room that currently has tv and insert a splitter by cutting the line to that room and running the out ports to the rooms and the in port to the other end of the wire that you cut. This will give you the same picture in both rooms.
If you have a system that does not use diplexers to backfeed the second TV you can backfeed the 3-4 cable going to the TV1 by cutting the line and adding a splitter with the inport running to the 3-4 port on the receiver and one of the out ports going to your tv1 and the other outport going into the UHF side of a diplexer. You will need to cut the Satellite feed into the back of the receiver on the back side of the seperator and connect the seperator to the SAT port of the diplexer. The IN/OUT port of the diplexer will connect to the end of the sat feed cable that goes to the wall plate. This will allow you to go into the attic of outside of the house and find the sat cable that feeds the TV one and break it there and put the IN/OUT port of that diplexer facing the TV1 room and the SAT port connecting to the other end of the cable you broke. The remaining UHF port will be the feed for the new room that you wish to connect. This set up will allow for viewing the same program as that at the TV1 location however you will need to change the channels at the TV1 location or buy an IR to UHF converter to allow you to be able to work the system independently from the receiver. Hope this answered your question. IF you need further assistance please contact me and thanks for using Fix Ya.
Posted on Dec 31, 2008
  • 374 Answers
SOURCE: tvs sync together
The receiver seems to be in single mode. On the right side of the receiver press the front panel. A small pop open door will open and inside there will be a MODE button. Press this button and ensure both the green and blue lights are lit on the receiver. If they are now but weren't earlier this should solve the issue however there may be another issue.
Take the TV2 remote to the TV1 location associated with that system. With the TV1 remote and TV on press menu menu on the TV1 remote this will bring you to the System Info Screen. Near the bottom of the screen there will be two remote addresses- primary=TV1 and Secondary=TV2. Using the TV2 remote press and hold the small clear SAT button until all light across the top light up. Now key in a two digit number that is different from the original secondary address at this location and also different than the address for TV1. Now press the pound key and the SAT button will flash thrice. Now press the record button a few times until the secondary address changes to the number you selected. Once this is done you can exit out of all screens on all receivers and go to the TV2 location that was having the issue and it should be resolved. I hope this resolved your issue and thanks for using Fix Ya.
Posted on Feb 11, 2009
XopenX
  • 108 Answers
SOURCE: Is it possible to record local channels using a DVR
Not with the 625. You need the Vip622/722
Posted on Apr 08, 2009
SOURCE: Dish 625 DVR recorder won't play recorded shows.
Hi I will be more than glad to assist you in this concern. First press the power button on the front panel of the receiver for 10secs. once you press it the receiver will turn off and it should turn on by itself, once it turns on by itself you will see attention 015, press the menu button on the upper left of the remote, once you see the menu button press 6, 1, 1 on the remote and it should show on the screen point dish, select on check switch, once u are on the installation summary screen, select on test and it should do a test of 1 of 3 or it depends on your sat orbital location that u have.. once its done, it will show the installation summary screen and you should see sat input 1 & 2 with port1 up to 2 or 3 depends on your sat orbital location, all the trans on the sat 119, 110 or 129 if you have should be ok and green. once you see that all ok, select done on the screen, and it will be back to point dish, select done again, and then cancel all the way out of the menu, it should show on the screen attention 015, let it finish until it download the programming guide, once its done it should show a tv pic. press the dvr button and access your recorded event, it should play the dvr event. if the problem still exist, unplug the power of the dvr from the power outlet for 1 minunte then plug it back again and it should acquire the sat signal and download the programming guide, once it shows a pic. press again the dvr button and access the recorded event. it should play the recorded event, just incase the problem still exist, check what will be the exact error msg, write it down in a piece of paper and please feel free to get in touch or you can call on 1-800-333-3474..in order to for the dish tech support replace the receiver, this is a dvr lost of function.
Posted on Sep 05, 2009
How do I record future programs using duel mode on tv2
To whom it may concern,
When you set an event to record you will be prompted as to whether or not you'd like it to record on tuner one or two. Simply select tuner two.
Best of luck
Dish guy
Feb 24, 2015 | DISH Network Televison & Video
How do i change tv 2 with reciever or remote 1, lost remote 2.
Hi this isMike Houston of DISH Network and I see you have lost your TV2 remote. Until youget your 2nd remote you can put the receiver in Single Mode and putTV1 on the channel you want to watch for TV2 and then put it back in Dual Mode.I can help you in getting your TV2 remote so you can watch TV on both setswithout having to change the Mode setting on TV1, I will send you my e-mail andyou can contact me through there; michael.houston@dishnetwork.com.
Aug 08, 2011 | DISH Network DVR-625 DTV Receiver /...
ONLY WORKS ONE TV
Hi juan2luis,I caught your post and seen where you're having a problem with your DVRrecording on only one TV. You will want to make sure the DVR is set to dualmode, if the DVR is in dual mode you want to unplug the receiver for 10 secondsand plug it back in and let it power up. When the receiver fully resets pressthe menu button on TV1 and then look to see what is on TV2. If you see programspress the Record button on the TV2 remote to see if it will record. If you haveany questions please e-mail me at michael.houston@dishnetwork.com
Mar 27, 2011 | DISH Network ViP722 DTV Receiver /...
I'm in the room and using tv 2 on dvr but I see tv1 and don't know how to go back to tv 2. So what I'm trying to say is I'm watching what tv 1 is watching.
Himarcos_and_s, my name is Mike Houston of DISH Network and I was going over yourpost and with TV2 showing what's on TV1 you want to make sure the receiver isin dual mode and if that is the case please unplug the receiver for 10 secondsto reset the receiver and you will have your TV1 and TV2 showing differentprograms. If you have any questions please e-mail me at Michael.houston@dishnetwork.com.
Mar 22, 2011 | DISH Network Televison & Video
We have 2 led/lcd vizio tv's. (TV1) is a 47"
first off, check the mode setting at tv 1, are you in dual mode, or single. you need to be in dual. Also sounds like the remotes address is not correct. rather then me typeing forever here, I would call dish, 1-800-894-9131, they can walk you rite through it.
Mar 20, 2011 | DISH Network ViP722 DTV Receiver /...
We have Dish Network VIP722 on only one HD tv at this time. When recordng HD PPV, we are unable to change channels without getting message that recording will stop. Menu>Preferences>Record...
This is a problem that many have. If you are recording on TV1, and the receiver is in dual mode, then you are only able to watch what you record. But you can set your recording to TV1, and then put the receiver into single mode, and switch from the recording to live TV.
Becki Barned
DISH Network Customer Service
Mar 05, 2011 | DISH Network ViP722 DTV Receiver /...
I want to record a program for later in the day. When I record on TV1 in Dual Mode, why does it record on TV2 in another room instead of TV1?
Hey there, Cheri Torres with DISH Network Customer Service here. I came across your post and wanted to see if I could help. It sounds like your DVR recordings may be interfering with another recording you already have set up. What you can do in order to fix this issue is change your Record Plus setting to TV1 instead of TV2. In order to do this you must first press the Menu button on your remote control then Select 8(Preferences) then 5(Record Plus). Once you have selected record plus you will need to enable the option as well as set your Record preference to TV1. Depending on the model of receiver you have the menu numbers may be different but the options (i.e. preferences and record plus) will be the same. I hope you find this information useful but if this does not work or you have any other questions or concerns feel free to email me at Cheri.Torres@Dishnetwork.com. Thanks and have a great day!
Feb 20, 2011 | DISH Network ViP722 DTV Receiver /...
With 2 tvs you set to record on 1 and it records on 2 instead?records on the opposite tv
Hello, Matthew Gonzales with DISH Network here. The default setting in our receivers are to automatically record everything onto TV2. You can change the setting by pressing menu-8- 5 (preferences-record plus), then you can either disable the feature, or set it to record onto TV1. If the feature is disabled, the show will record at whichever TV the timer is set up on. If it is set to TV1, all timers will attempt to record on TV1 (unless TV1 already has a recording going on it then it goes to TV2). Hope this helps.
Matt
Jan 04, 2011 | DISH Network DVR-625 DTV Receiver /...
Problem with DISH DVR 625
You can accomplish this by either going to the specific TV and selecting the record option at the time the program is about to come on or you can press menu-8-5 and change the record preferences. You can either set the DVR to record programs to the TV2 location by default or TV1 by enabling the record plus feature. In dual mode without record plus enabled all programs you select to record default to the tuner you are viewing e,g, if watching tv1 and selecting to record a program in the future it will record to the tv1 location.In single mode all recordings default to tv2 so you can continue to watch live tv from tv1. I hope this answers your question and thanks for using Fix Ya. Let me know if I can further assist you.
Dec 14, 2008 | DISH Network DVR-625 DTV Receiver /...
How do i choose tv1 or tv2 on my DVR?
Your recording will record onto your one DVR box, for playback on either tv. On many satelite boxes you have to search for the program you want by entering the name. Then select the program and select to record the future broadcast.
Dec 07, 2008 | DISH Network DVR-625 DTV Receiver /...
Televison & Video Logo
427 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
