Question about Samsung Microwave Ovens
Samsung microwave ovens model mo1650ca turntable stopped turning
Samsung microwave model # mo1650ca still heating but turntable will not move.
  • Samsung Master
  • 9,047 Answers
Are the internal cooling fan and stirrer (in the ceiling of the oven) running when you cook?
The turntable gets its 21VAC power from a tap on the cooling fan motor, and it's controlled by a relay on the circuit board.
So it's important to know if those other two motors are running, too.
You will have to temporarily remove the stirrer cover from the ceiling to see if the stirrer is turning when you cook.
For some weird reason, this model's service manual is not in all one piece. So you have to download all the sections separately:
http://www.microwavedisplay.com/MO1650WA_XAA.0000051600.E.01.pdf
http://www.microwavedisplay.com/MO1650WA_XAA.0000051600.E.02.pdf
http://www.microwavedisplay.com/MO1650WA_XAA.0000051600.E.04.pdf
http://www.microwavedisplay.com/MO1650WA_XAA.0000051600.E.05.pdf
http://www.microwavedisplay.com/MO1650WA_XAA.0000051600.E.06.pdf
http://www.microwavedisplay.com/MO1650WA_XAA.0000051600.E.07.pdf
http://www.microwavedisplay.com/MO1650WA_XAA.0000051600.E.09.pdf
http://www.microwavedisplay.com/MO1650WA_XAA.0000051600.E.10.pdf
http://www.microwavedisplay.com/MO1650WA_XAA.0000051600.E.14.pdf
http://www.microwavedisplay.com/MO1650WA_XAA.0000051600.E.16.pdf
You can find handy exploded views and order parts by model number here.
If you need circuit board repair, we do that for $39.95 in most cases.
Posted on Nov 28, 2012
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave turntable won't stop running
This is usually caused by either a bad door switch, but may instead be a loose door switch mount or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 19, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: the microwave does not heat
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
For Kenmore models, you can usually find an exploded view by entering your model number here: http://www3.sears.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 28, 2007
SOURCE: Microwave oven does not heat anything
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Posted on Aug 14, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp Carousel R-1481 Turntable
It may very well have have damaged the turntable motor.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
On many Sharp models, you have to cut the motor cover off with snips, then use a screw when reassembling it.
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
You will need the
free Acrobat Reader to view or print it in case you don't have it already.
The best place to order parts for this brand is Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Be sure if you cook an egg that you puncture the shell first so it can breathe.
Posted on Mar 02, 2009
buddymcl777
  • 67 Answers
SOURCE: Samsung microwave oven turntable doesn't turn
Yes it just will not cook or defrost very evenly. It is not dangerous however.
Probably the motor or gears that make the turntable go are worn or burnt out.
Posted on May 01, 2009
How to fix a Samsung microwave turntable
The drive motor underneath probably has failed.
Nov 17, 2016 | Samsung Microwave Ovens
Manual for a whirlpool microwave oven model wmh31017aw-1
There is no turntable control. It is always on. The turntable should change direction each time the unit is used. If the turntable is not operating, it has malfunctioned. Newer microwaves for the most part all have full-time turntables to promote even heating, thus reducing customer complaints about ovens that don't heat right.
Dec 30, 2015 | Whirlpool Microwave Ovens
Microwave won't stop running
there's a ghost in your microwave, call ghost buster. Seriously, the problem is the control panel. (((((the microwave oven can store thousands of volts of electricity in its high voltage capacitor, even after the microwave oven has been unplugged. That's more than 30 wall outlets combined.
Replacing electronic parts in a microwave oven can be extremely dangerous.))))))) tank you
Samsung Model SMH1816S XAC Parts
Mar 30, 2014 | Samsung Microwave Ovens
No heating action
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
hjdhdg
Apr 15, 2009 | Samsung MW4593G Microwave Oven
MICROWAVE, NO HEAT, TURNTABLE WORKS, COULD THIS BE A FUSE
Please reply back with your brand and model number so we can help you.
Jan 07, 2009 | Maytag MMV5156AAS Microwave Oven
Turntable jams repeatedly
probably the turntable motor .. this link will get you hooked up with a parts supplier... and details of your micro.. http://www.pcappliancerepair.com/model-display.php Hope this helps..
Apr 29, 2008 | GE JES1384SF Microwave Oven
Microwave Ovens Logo
51 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
