Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
We have a Hotpoint Aquarius Extra which has started banging lik crazy at he starts the final spin cycle. It makes no difference what the load consists of. It has been fine for a couple of years and has just started ding this.
  • Neil Weatherspoon Nov 27, 2012
    The drum is smooth when spun by hand. I'll have a look at the drum weights etc to see if anything is obviously loose. My Dad was a service engineer for Hotpoint so it is one of the few things I haven't bothered to get acquainted with. Sadly he died a year ago and in response the vacuum, dishwasher, oven nd now washing machine have all had a wobbler.
    Just for your info, the machine is level and stable.
barkencoa
  • 3463 Answers
SOURCE: Hotpoint aquarius 1100 bangs while spinning
Several possible reasons for this. M/C not level, causing it to move about.
Overloading of m/c.
Loose concrete balance weight, there is one at top and one at bottom.
Suspension spring broken or unhooked.
Suspension leg loose or broken.
Main drum bearings worn, to check this, turn drum by hand and if it feels noisy or rough , then bearings have gone (expensive repair).
There are other possible causes, but these are the main reasons.
Plz rate my solution.
Thanks.
Posted on Dec 29, 2008
barkencoa
  • 3463 Answers
SOURCE: Started having a noisy rinse & spin cycle, then stopped.
Open the washer door and spin the drum by hand, if it feels rough or noisy and rumbling, then the main drum bearings have failed. There should be little or no noise when you spin drum
This is a major repair, and I would not recommend a D.I.Y solution.
Other possibility is there is something in the pump, but you would only hear this when the pump is working.
Plz rate my comments.
Thanks.
Posted on Jan 07, 2009
SOURCE: hotpoint aquarius banging about when spinning
hi take the top of the machine and check the brick at top or bottom of the machine they sometimes come lose .
Posted on Sep 30, 2009
SOURCE: hotpoint washer
hotpoint wma22 will not spin
Posted on Jan 01, 2010
beltronic205
  • 1461 Answers
SOURCE: My hotpoint aquarius wd62 has
Check both springs on top /remove lid you may find one spring is broken......
Posted on Feb 18, 2011
Hotpoint aquarius wml760 noisey when spinning with stuff in but ok empty
more than likely the rear bearing has gone bad and when a load is applied the difference in weight distribution causes the knocking.
Jun 15, 2012 | Hotpoint Washing Machines
Hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Thankyou.
Jan 31, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint washer
common problems with timer which work like a clock and goes though the cycle, bad timer will cause it not to go through its cycle. it very cheap and easy to replace everything is all plug in.
Nov 14, 2009 | Hotpoint WMA40 Front Load Washer
Hotpoint aquarius banging about when spinning
Sep 30, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Thanks.
Jan 07, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Machine bangs and jumps all over as soon as the drum starts moves
It is the pulley shaft that has worn out more than likely. Remove the back cover and give the belt a tug or two if there is ANY play at all the shaft has gotten worn on the pulley assy. If it were the bearings I would be surprised as they don't go out nearly as often as the pulley. New pulley and belt should lengthen the life of the appliance considerably. Good Luck
Nov 28, 2008 | Hotpoint Aquarius WD640 Front Load...
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Loud banging during spin cycle
please balance your washer and use smaller loads
Mar 18, 2008 | Kenmore 43052 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
60 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
