Question about LG LFX25978ST 24.9 Cu. Ft. French Door Refrigerator with Ice/Water Dis
Lfx25978st ice tray stuck
Ice maker tray will not dump into ice collection bin.
    Top Expert:
  • LG Master
  • 9,472 Answers
This sounds like a thermostat in the ice maker has failed. Unfortunately, LG provides no replacement parts for the ice maker. They say to just replace the assembly, so there is no alternative other than ice maker replacement. Here is the ice maker to order.
Posted on Nov 27, 2012
  • 489 Answers
SOURCE: Ice tray sometimes stuck when dumping off ice
Your icemaker tray has an update for the water flowing over the tray.  You will need to call a qualified LG technician to get it replaced.  Also, the tray is twisted because it binds itself against the hinge pin on the left side.  To stop this, spray some cooking spray oil in the left hinge pin and it should unbind itself and return to normal.
Posted on May 11, 2008
BIKER T
  • 909 Answers
SOURCE: the ice maker fills the
If you look underneath the icemaker module, you should see a reset or test button. Press it once and it should do a complete cycle. Once activated, the icemake normally continues on from there. If no action takes place when you have pressed the test button then replace the module.(a little complex to repair at component level as there are many variables ie. sensors: drive motors:limit forward and back etc.).
Posted on Aug 20, 2010
I am an attorney near Philadelphia who is considering initiating a class action against LG related to the defective design of their ice maker. I have clients in different states who have had problems that LG fixed, but the problems re-occurred after the warranty expired. I've been advised by mechanics that leaks are inevitable based on the design. Apparently this is a design that LG had used years ago but had discontinued for a while because of leak problems. I'm usually on the defense side of product liability cases, but this seems to be a common defect. If you are interesed in such a suit, feel free to contact me at corrlaw@verizon.net. Law Office of John A. Corr, (610) 482-4237.
Posted on May 15, 2009
HVACRH20
  • 237 Answers
SOURCE: Ice Maker Dumping Water into Collection Tray.
Not to plug any company but... if you get Sears to fix it ask them for a Master Protection Agreement on it, that "Warranty" will cover most everything like that where the typical warranties don't. Just a thought if you don't want to "eat getting it fixed" ever again. Thanks for the post to others, it really helps if people know not to wait on such issues.
Posted on Feb 27, 2007
dasphyzie
  • 148 Answers
SOURCE: Ice maker won't work
my mum use the same kind of freezer, when it had the problem on the ice maker, we both took it to a lg service center to renew the ice maker engine
Posted on May 31, 2010
Ice maker not dumping ice into bin. bin empty and ice in tray
check the operator manual for a switch or lever that is stuck or in the off position.
Aug 21, 2015 | Refrigerators
Why doesn't my ice maker dump the ice out into the ice bin?
several reasons. 1) the ice level sensor bar is pushed up. 2) the motor may have accumulated ice inside it causing it to stop turning. 3) Ice tray thermostat may be bad not heating the tray just prior to dumping.
Aug 18, 2014 | Kenmore Refrigerators
Does dump valve shut off after making ice
is your bin line and dump line tied together if so it could be just ice melting. If not can you here water filling up constantly while machine is off? if so is it running over sump tray into ice bin. if dump valve was stuck open then machine will not make ice.
Jun 25, 2013 | Scotsman Kitchen Appliances - Others
Why does water not shut off after making ice
Is the bin drain line and dump drain line tied together. If so then it is melting ice from the bin. now when ice machine starts up it will dump the old water in sump tray so it will be fresh water during new freeze cycle.
Jun 25, 2013 | Scotsman CSW45 15" Ice Maker with 26 lb....
Ice maker problem
Clear the Ice tray by pressing the button under the ice maker. The problem is that the ice is in the first couple of slots is not dumping and the tray tries to fill again and over flows. I pressed the button and cleared the tray of ice (This will tilt the tray and twist it to empty it) that was re-frozen several times without dumping. My ice maker works perfectly after I did the above. I think the problem arises if the door did not close completely. I stopped hanging the dish cloth on the door and on my LG Dish wisher. I hope this helps
Oct 03, 2008 | LG LRSC26940ST 36" Side-by-Side...
Mar 24, 2008 | LG LSC26905TT Side by Side Refrigerator
Kithcenaid Superba KSRS25QDWH01
If you pop the front cover off the ice maker you will find a screw with a plus and minus on it. Adjust it and that will cut the water fill down and should solve the overfill problem.If the ice is not dumping spray the tray with Pam and that should solve the dump problem.
May 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
I had the same problem. I did the following and it now works great. The ice tray has a square tab on the rear leftside. As the tray rotates to dump the ice, the tab runs on a curved section of the the ice maker frame. The curved section becomes rough with use and causes the tray to stick when it is returning to the fill position. I carefully sanded the curved section of the frame to smooth it out. No problems since.
One does have to dismantle the ice maker to effect this repair.
Mar 09, 2007 | LG LRSC26980 Refrigerator
LG has a new ice cube tray that will solve this problem. The part number is 3390JA1150A The wall will stop the overflow.
Sgt 48
Feb 19, 2007 | LG LRSC26944 Side by Side Refrigerator
LG LFX25978ST 24.9 Cu. Ft. French Door Refrigerator with Ice/Water Dis Logo
2,177 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
