Question about Toro "Toro" Super Blower/Vac
Toto model 51587 making loud grating noise
Loud noise sounding as if something is caught in the impeller, but impeller is clear. noise does not recur when impeller is removed,.
3 Suggested Answers
2strokeguy
  • 183 Answers
SOURCE: i need a toro impeller
The impeller for your Toro blower is part #98-3150 and is available from www.partstree.com for about $20 plus shipping. To avoid shipping charges, find your local Toro dealer. Go to www.toro.com to find your nearest dealer.
An exploded parts view is also provided on partstree.com's website. This should make it easier to see what has to come apart for the impeller to be replaced.
Posted on Nov 12, 2010
rwvanlue
  • 486 Answers
SOURCE: Toro leaf blower Model 51591 from 2003 has started
Sounds like a piece of wood is caught under/between the impellor and the case/housing. When removing the impellor, you may find it has a left hand threaded nut.
Posted on Nov 13, 2009
Why is it making a very LOUD noise when it first starts filling and doesn't stop. The lights come on but the hum/grateing stays
Check for something stuck in the bottom of the machine where it is not supposed too be. Chicken bones, small items etc can get caught in the pump impeller which is generally protected somewhat by a filter of some sort, but in my own $1500.00 machine, I've had stuff sneak in past the guards. Check your owners manual for instructions on your particular make model number. You didn't post that info, so I could not do a "Google" search for you.
Oct 03, 2015 | Dishwashers
My fan is too loud
Is it a grating sound? The bearing is dry. Spray some lubricant on the shaft as close to the fan body as you can. Make sure the fan is not hitting on something else or has something caught in the blade
Apr 21, 2012 | Frigidaire FRS26H5AS Side by Side...
Dishwash is making a very loud noise - what to do
Most noises come from debris caught in the sump/ impeller area. Don't know your brand but if you can remove your lower spray arm there are probably some screws you can see and remove. Just keep removing parts till you get into the impeller area. Or it could be the motor itself making the noise.
Oct 20, 2011 | KitchenAid Dishwashers
Noise at pump
Your problem is just a little vague. Noise could be several things including.... vibration can cause noise especially if the pump is not sitting solid on the ground. Cavitation around the impeller can cause the pump to be noisy. something stuck in the impeller can not only cause a number of irregular noises, but also affect performance. If the bearings are going bad they can make a number of bad sounds; anything from just sounding a little noisier than normal or a loud grumble to a loud high pitched squeal the can make a banshee turn and run.
Sep 18, 2010 | Jandy PHP High Head Pump 2 HP Up rated
Loud buzzing sound began on start up
It could be several things but the most likely are: Something is spinning around with the motor shaft. Unplug the motor and "blast" water through the vent holes to clear debris. Let it dry completely before returning to service. Something could be caught in the impeller. Remove the front end and check. Squeals, loud hums, heat and vibration are indications of bad bearings.
Apr 17, 2010 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Makes loud noises
Although there may not be any gas parts involve you should have gas technician work on the unit. Depending on the noise your hearing it could be a number of things, if its making a scraping noise it could be that your front drum glides are gone allowing the drum to ride on the frame of the door. glide part numbers are 306508. if the noise you hear sounds like a grating sound it could be that your blower wheel has something caught in it and is now rubbing on all of the fan blades on the blower.blower part number is 33002797. if you hear a loud banging noise you could have a rear bearing issue. both roller bearing part numbers are y303373.hope this helps
Thanks
Oct 12, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Dishwasher Making Loud High Pitched Noise.
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Dec 25, 2007 | Whirlpool 24 in. DU900PCD Built-in...
Loud noise
Hard to say for sure without more info. Sounds like something caught in pump though. Give us the brand and a model number.
Nov 15, 2007 | Washing Machines
Toro "Toro" Super Blower/Vac Logo
73 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
