Question about Dryers
How do you disassemble ge profile wizard gas dryer
Dryer squeaks
    Top Expert:
  • Dryers Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 27, 2012
Master_Tech
  • 770 Answers
SOURCE: My dryer is squeaking on the dryer spin cycle.
What is your model number ...sounds like the drum glides are going out or the support rollers
Posted on Jul 31, 2008
MNTECH
  • 1543 Answers
SOURCE: GE Profile Dryer Model # DPSR473EWOWW SQUEAKING
If the squeaking has been going on for only a short time, you may be able to get by with only replacing the rear drum bearing, but if it has been going on for some time you should replace the drum bearing kit part # WE25M40. Also be sure to check that the front drum slides are ok, especially the one on the left side of the front drum support, as this one wears out faster. Drum slides #
WE1M481 and
WE1M333 and if front support frame is worn so that there is nothing left to hook the slides into you would need a
WE3M26.
Posted on Sep 17, 2008
TheMobilian
  • 8220 Answers
SOURCE: squeaky dryer drum...felt thing came off how to replace it?
Squeaking is cause by the drum bearing worn out and telling the tale. As it get thinner and thinner it begins to rub against the metal outer casing it is embellished in. To inspect it you must rmove tyhe front and get the drum out. Start by opening the the door and removing the screws holding down the top. Then raise the top and get the screws out thathold the front on. Use the rear acces panel(if applicable) to get the idler loose or access that idler from the front.e24a4b7.jpg
Posted on Jan 13, 2009
SOURCE: dryer makes noise as drum rotates on ge profile gas dryer
Solution: the drum slides were worn out and needed replacement.
Posted on Jan 14, 2009
dragonsthatk
  • 547 Answers
SOURCE: GE profile dryer is making squeaking noise.
please replace felt around drum thank you for useing fixya RATE ME
Posted on May 17, 2009
Dryer Squeaking/ Squealing
Could be a worn belt or, if it occasionally sounds like metal on metal, the felt that the drum spins against is probably worn through and needs to be replaced...
May 04, 2013 | GE Profile Wizard DPSE592EAWW Electric...
The ge profile dryer #dpsr473ew is malfunctioning. it makes a very loud squeaking noise when it is on
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 31, 2011 | GE Profile DPSR473EW Dryer
The dryer is squeaking badly. how do i fix that?
heatman101
Jul 14, 2011 | GE Profile Wizard DPSE592EAWW Electric...
My ge profile dpsf495ew dryer is make a squeaking noise
It's the drum bearing . It's in the back of the drum but it can only be accessed from the front. It's regular wear and tear that causes this usually. It's a pretty tough job for someone that has not done it before.
Jul 01, 2010 | GE Profile DPSF495EW Dryer
The dryer is making a noise
heatman101
wrwtyt
Jan 26, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
Ge Adora Dryer, Worked great. Put load in, dryer 'hummed' drum did not spin. 'Clean Lint Trap' light was lit. Cleaned lint trap, still not working. Thought belt problem so unloaded dryer, drum did...
Sounds like your motor may be shot. Or possibly one of the pully's bearings are seized and is causing so much resistance the motor is unable to overcome it.
Oct 09, 2009 | GE Profile Wizard DPSE592EAWW Electric...
May 17, 2009 | GE Profile Harmony DPGT750EC Electric...
Dpsr475gw0ww GE Profile Gas Dryer noisy
The felt seal should be replaced if it is bunching up. The squeak could be due to worn drum rollers in the rear.
Jan 07, 2018 | GE Profile DPSR475GW Dryer
Dryer drum causing squeak
Most likely the front support bearing. If this is the problem you will likely have to replace the slides too. The wizards have a ten year warranty. The bearing is part number WE3M26 and the slides probably need 3 or 4 of them are we1m333. Hope this helps.
Dec 11, 2008 | GE Profile Wizard DPSE592EAWW Electric...
Dryers Logo
35 people viewed this question
Top Dryers Experts
