Question about LG 42LC7D-UB Television
Problems turning on takes long time to go on
Have to turn off then on then off then on again and then it stays on
  • 1,238 Answers
You have bulged/leak capacitors on the power supply board that need to be replace in order to worked fine..
Thank you and don't forget to rate..
Posted on Nov 27, 2012
Car will not stay turned ON when cold
Try this. When you first try to turn your engine on, keep your foot on the gas pedal. The car should turn over but not start. (don't worry, its not supposed to). Take your foot off the gas and turn the ignition on again, but Don't touch the throttle this time. That should set your choke correctly. To summarise: Turn key with foot on Gas. Take foot off Gas, and turn key again.
Oct 16, 2012 | 1993 Toyota Corolla
My ABS light stays on VSC OFF stays on & VSC Trac light stays on!! Had it at friends garage he turned off with computer, as soon as I drove away all the same lights came on Please help!!! local Toyota...
check the abs sensor rings on each wheel i suspect that one of the metal rings is turning on the drive shaft if so a couple of spot welds will do the trick
Jun 27, 2010 | 2003 Toyota Sequoia
When i turn on the TV...it runs for 5-10 min...then shuts off... this turn it back on...it runs again for short time and turns off...repeats several times till it stays on...will stay on indefinitly till...
Hi Friend,
Please folliow the below steps one by one,try by resetting the TV
Step 1: Turn on the TV
Step 2: Hold the ON/OFF Button for 10 to 20 Secs
Step 3:Without taking the hand from the ON/OFF button unplug the power cable connected to the wall outlet from the TV
Step 4:Without taking the hand from the ON/OFF button put the power cable back to the outlet
Step 5:Now take the hand from the ON/OFF Button and try to turn it ON again and check
Even after that you are facing the same issue please check with the Display Card whether its has got any problem in the TV,
If you have any Clarification please feel free to contact us
Regards,
Ayyasam
Apr 02, 2010 | Panasonic PT-50LCX64 50" Rear Projection...
Has problems starting. Has problems staying lit
clean or replace the thermocouple. to clean, remove the thermocouple and take off any corrosion with a peice of emery cloth or sand paper. reinstall thermocouple. it looks like a very short pencil with 1 wire going to it. this should be of help.
Nov 07, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Yamaha HTR-6130 Receiver will not stay on! Shuts
One last try with everything disconnected!
Other than that I suspect internal surge damage.
Aug 04, 2009 | Yamaha HTR-6130 Receiver
Hitachi Ultravision 60" rear projection
Time for a new TV. I have searched for manuals and parts. What is available is expensive and may not fix the problem.
Apr 27, 2017 | Hitachi 60SBX72B 60" Rear Projection...
Sylvania (proview) cl2072b flat panel monitor
Well the first and second paragraphs make me say the Inverter/power board must be replaced.
A white display typically means either your display cable (in your monitor) is loose or logic board is dead.
Either one of these things typically mean take it in for an estimate to repair, and if it's too much, buy a new one.
With your luck I think I might switch to big cheap CRT.
Mar 12, 2008 | Proview PL926WBi 19" LCD Monitor
What do I do?
The problem with your camera can be in optical (lens) unit. Part number is: 884875701 If you need more info please advice.
Apr 02, 2007 | Sony Cyber-Shot DSC-P41 Digital Camera
LG 42LC7D-UB Television Logo
Computer Repairing
Computer Repairing
