Question about Kicker Comp 05C88 8" Car Subwoofer
How do I build a shallow box for my 8 inch Kicker Comp to fit on my motorcycle
I want to install my new Kicker Comp 8 inch subwoofer on my motorcycle - mount it below my luggage rack, but only have about 8 inches in total height to work with. How do I build a box that will work and can I use steel or does it have to be wood?
    Sergeant:
  • 344 Answers
It should be built out of mdf ,That it sounds decent, As for the size of the box figgure that out your self,
Posted on Nov 28, 2012
Speaker blown?
disconnect the amp and do a "pop" test with a 9v battery, it should be clear and no rattle... if it rattles sub is blown
Jan 29, 2014 | Kicker Comp CVT 12 Car Subwoofer
Need speaker box Measurements for a 10 inch 8 ohm kicker comp
Look in the manual that comes with your subwoofer. For most 10" subwoofers, you need to make sure there is at least 1" to 2" around the subwoofer for the front plate. And the figure out how you want it to sound for the depth of the box. Slimmer box equal higher bass, wider box equals deeper boom. You always want to account for the thickness of the wood. If it's thinner wood you won't have that deep of bass. If you have thicker wood it will give a richer sound. Mainly if you building a single box you need at least 12"X12"X12" would be just fine. It gives plenty of room for everything to fit and you can just fill it with foam to make the bass sound deeper.
Sep 20, 2012 | Car Audio & Video
I have a 2011 gmc sierra and im putting a kicker comp vr 12 in there and i was wondering how much airspace i would need the box im looking @ is .98 i hope its enough airspace and its ported box
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. If it is a 12 inch sub the box size will be 13 inches x 13 inches x 13 inches. Hope this helps
Dec 04, 2010 | Kicker CompVR 05CVR84 Car Subwoofer
Kicker 8 inch l5 problem!
Possibly. Actually there are sub rings you can buy to convert a regular box over to one that will accept a square sub without cutting the whole out in your box to make it square. The airspace may be lacking a little bit.
May 20, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
How do i wire a 8 ohm kicker comp 10" sub inside the box? and what is the best way to get more bump with a 600 w mtx amp and kicker comp 10" sub?
Ok, for an 8 Ohm sub, it is advisable to get another 8 Ohm sub. wire them in parallel down to a 4 Ohm load. You would wire both + wires together, and both - wires together to yield a 4 Ohm load at the amp. Majority of the amplifiers on the market are designed to give more power at a lower impedence, or Ohm load. You just have to make sure that your amp will take a 4 Ohm load. Without knowing the model of the MTX amp, I can't give more advise. However, this should be able to give you and idea of where to start. The main problem is that you have a single 8 Ohm sub in the Kicker Comp.
Apr 30, 2010 | Kicker CompVX CVX104 Subwoofer - 10" Dual...
What are the specs on a kicker sub box for a challenger srt8
On a 8 inch subwoofer ranging between 80Hz and 120Hz, the box size required should be around 11 liters, meaning that you will end up with a box of 9 inches high, x 9 inches wide, x 9 inches deep. Or 225mm high, x 225mm wide, x 225mm deep. Seal the box on the inside with silicone for better bass.
Oct 19, 2009 | Kicker Car Audio & Video
I have a 2002 Yukon XL and the subwoofer is blown. How do you remove the trim panels to access the speaker and is the amp intergrated into the radio or separate? Also does it have to be a factory...
Well, see your issue will be taking the trim out. The most of it has brackets that snap together and the amp that powers that subwoofer is very small. it will also be a single voice coil subwoofer and either an 8 or a 10. Need to find a very small rms subwoofer like a kicker comp. also a shallow enough subwoofer to fit in the space. the lower the rms of the new sub the more likely it will be shallower. you're probly gonna be wanting to look for a sub that is like 150 rms and no more to be powered adequately.
May 03, 2009 | Car Audio & Video
Kicker Comp 05C88 8" Car Subwoofer Logo
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
