Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
How do i open this unit?
I can see the counter balance in front of the washer has come off and i have to get the front open to repair it. what is the procedure to reach this? thanks dmm
  • 20 Answers
Remove control panel to gain access to screws and remove door boot and tilt forward this should give access
Posted on Feb 10, 2009
How do I fix the last few seconds of spin that vibrates off balanced and aloud noise.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
By the way my advice is free cuz God is good!
Sep 23, 2014 | Samsung WF419AAW 4.3 cu. ft. Front Load...
I have a Samsung washer model number wf338aab/xaa my tub is off balance
Sep 17, 2014 | Samsung WF328AAW Front Load Washer
The tub is making loud noise as if off balance. My husband is ckg the bearings & counter balance out, but I also found some plastic mesh like residue with solid ribs in the washer. This was not...
Unfortunately this unit has a bad tub bearing. The only way to fix it is replace the rear half of the tub because the bearing is not available separately.If it has worn into the front tub half as i suspect it did by you finding plastic in the tub the front half will need replacement as well. At that point it is not advisable to repair the unit because what you will spend to fix this will be as much as a new machine.By the way this is not uncommon over the years I spent working on these we would see three or four a week, the only ones we repaired though where the one's that had an extended warranty. I do feel for you though I have the exact model with the exact same problem and even though I can fix it myself and not have to pay any labor its still more than 500.00 in parts so I will just replace it
Dec 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I am having issues with my washing machine. At it's final spin it seems to be off balance and makes loud noises
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 05, 2010 | Frigidaire Washing Machines
My washing machine door says that it is locked when the door is open how can I fix this?
Replace the door switch, but,..... if you order the switch, they may send the switch in a rather large and heavy (and somewhat expensive) box which also contains the lower counter balance for the front of the drum. The reason is that on some machines, the counter balance is shapped in such a way that on certain off balance loads, the counter balance is able to strike the door switch and break it. The new counter balance weight has been re-designed to prevent this from occuring.
Apr 10, 2010 | GE WSXH208A Front Load Washer
How to balance a front load GE washer. I bought this from a friend. It does fine when it has nothing in it, but when I put a load in, it nearly jumps off the ground. I know now that there are some type of...
I'm not aware of any "balance things that go in the back" as you put it. if by chance you are refering to the transportation/shipping bolts, they need to be removed when the unit is in use and only neccessary for moving the washer.
Try this first **UNPLUG the unit from the wall** before calling a tech.
# 1...make sure you use "HE" detergent in any front load washer, including this one.
You can pull off the bottom service panel (2 screws) on the front of the washer and look to see the shock absorber's or the concrete counter weights aren't broken. while you're at it, pull off the top and inspect the suspension springs are intact to the cabinet/chassis.
start there
good luck
Sep 29, 2009 | GE WSXH208A Front Load Washer
Balancing problem Frigidaire stackable front load washer/dryer
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 21, 2009 | Kenmore 98702 Stacked Washer/Dryer
HE4t kenmore washer rubber drum gasket not attatched.
Removed the top and Front reinstalled the counter balance. the rubber gasket has a 1" tear in it which I patched with a rubber tire patch for now. Two of the locking nuts for the leveling of the machine were loose it went out of level causing the machine to rock and probably caused the counter balance to loosen up. My daughters come in from collage and over load it on weekends which adds to the machines demise. All have been warned.
Jan 17, 2009 | Kenmore Elite 45986 Front Load Washer
Our clothes washer has a bad screeching sound & loud spin cycle
screeching sound generally form a bad pump, which if didnt pump out correct amoun tof water would probalby send off balance more. unplug unit, ddrain out asmuch wateras possible and tip unit back, you will see the pump in the front right corner, there is a small plastic reles tab, after releasing it the pump simply twists out counter clockwise, perhaps ther is something in the pump/sump. you will see tis when oyou remove the pump, simply reinstalls the same way
Jan 02, 2009 | Fisher and Paykel GWL11 Top Load Washer
Kenmore mdl 10022622100 goes out of balance
to cause unit to go off balance taking in fact that you put clothes in washer even...check your counter balance spring it hold the tub to base at rear of unit,,,and check your balance ring at the top of your wash basket its fill with water if cracked will cause this problem,,
Dec 24, 2008 | Kenmore 22422 Top Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
206 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
