Question about Hotpoint HSS25GFP Side by Side Refrigerator
Water leaking inside freezer ice maker
I have a Hotpoint side by side refrigerator with filtered water/ice maker. About 4 months ago, the auger arm broke in the ice bin, we replaced that, but in the mean-time we turned off the icemaker (water still worked in the door). Once the auger was in and ice bucket back, we turned on the icemaker again. All parts in the icemaker seemed to work, but no water came out. All the information I could find seemed to suggest that the water line was frozen. I defrosted the freezer and used a hairdryer on the water line (behind the fridge) and inside the freezer (careful not to melt anything, as suggested). No luck. I just threw my hands in the air and gave up, figuring that I'd be making my own ice from now on. But, today, water came pouring out of the freezer.(From the water tube that fills the ice tray).The water would not stop even when the ice tray was full. The icemaker was not turned on. I turned the water line off (shut off seems to be working, water stopped leaking) to the fridge and defrosted the freezer again. I haven't changed the water filter in about one year but I have not had any problems with the water flow from the door. What can I do?
  • 5 more comments
  • Anonymous Dec 31, 2007
    where do i fill the water in a hotpoint refridgerater icemaker?
  • Anonymous Mar 09, 2008
    not cooling properly and inside of freezer side freezing up
  • 1bizymama Mar 18, 2008
    The water line to the fridge was severed, I had it fixed. This morining gallons or water came rushing out of my freezer when I opened it. Help!!!
  • jennie1942 Sep 01, 2008
    We replaced the valve on the back of the fridge and since then it makes ice but there is a leak as the water freezes intoi a big clump in the ice maker. Also since we replaced the valve all we get is crushed ice on the door if you want cubes you have to take them from the bin. Thanks in advance for your help. Jennie
  • Anonymous Mar 15, 2014
    Arm turns when door is shut and won't stop. Take tray out but then after a few minutes starts again?
  • Anonymous Mar 28, 2014
    icemaker and water
    stopped working.
  • Anonymous Mar 30, 2014
    Ice maker not making ice. Light is flashing 2x. Water works. Defrosted freezer to make sure lines not frozen
Just fix it.
Posted on Apr 26, 2008
Sounds like the line was frozen but the water fill indicator is faulty.
Posted on Jul 07, 2007
5 Suggested Answers
rickzilla
  • 706 Answers
SOURCE: icemaker auger jams , GE side by side
Water expands when it freezes and you probably have too much of it when the mold tray fills... Readjust the level to a bit less and you won't have triplet or quadruplet ice cubes..
Hope that helps...
Posted on Aug 20, 2008
Sea Breeze
  • 4655 Answers
SOURCE: water is going to dispenser in door but not to icemaker.
The first thing I would look at is the two solenoids on back of refrigerator. Each of the two have 2 wires. Switch the two sets of the two and then try the water dispenser. If the dispenser then don't work the ice maker should begin filling. If this happens you will need to purchase a new duel solenoid for that fridge. Hope this helps, Sea Breeze
Posted on Oct 28, 2007
  • 62 Answers
To see how the auger goes back together, go the the Sears parts web site and put in your model number. It will show the parts list and a diagram. You may be able to print it out, Don't remember if there is a print option or not but if you have a screen capture program you could also.
Posted on Sep 01, 2008
woodchuck789
  • 4070 Answers
SOURCE: There seems to be too much water pouring into the
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Posted on Aug 15, 2009
Ice maker drips water into freezer.Makes ice but doesn't shut off when full.
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
Aug 6, 2015 - If the ice maker doesn't make ice but you can see the arm swing intomotion and you hear a ... 4Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, ... If your ice maker keeps making ice, even when it is full:.
Refrigerator's Ice Maker Leaking Water ' ThriftyFun
www.thriftyfun.com/tf37813274.tip.html
If your refrigerator ice maker is leaking water, the first step is to locate the source. ... Its not the ice maker - in the floor of the freezer is a small drain that lets the ... I shutthe water supply off but water dispenser still leaks even though no ... My side by side refrigerator leaks water into the ice bin when filling the ice tray with water .
Dec 26, 2015 | Refrigerators
I have no manual and I want to make ice cubes and be able to drink filtered water. I do not get any ice cubes when I switch the button on in the left rear. I am not getting water. I have removed, to...
1. Keep freezer temp setting @ 5 degree.2. Check water supply with full pressure (Back of regrigerator) 3. Confirm shut off arm is not struck due to huge cubes stored in bucket. If so, please remove ice cubes.4. Check solenoid valve which allows water flow whenever required to ice maker is working.
Please follow the steps also given hereunder.
Close the freezer door completely. The dispenser will not work while thedoor is open. Place the ice bin in the proper position. Avoid placing ice inthe bin that was not made by the ice maker. The cubes may jam in the deliverychute. If ice is jammed in the delivery chute, remove it with a plastic utensil.Discard the ice in the bin and wash it if ice has melted around the auger. Drythoroughly before replacing it. Wait three minutes if the dispenser stopsdispensing ice after the arm has been held in for a long time. The dispensermotor will reset and will begin to dispense ice again.
Thanks
Jan 29, 2011 | GE GSH25JSTSS Stainless Steel Side by Side...
I have a side by side with ice/water dispenser on the freezer side of the door. a couple of months ago the ice maker stopped working and just today the water stopped coming out the dispenser and none of...
1light not work , may lightbuld loose in the socket , or door switch
2 ice maker not work? may the ice maker arm shut-off. sut-off arm to be on(sure be down position)
3 is the ice maker switch in the off positio ( on some models)
4 is the freezer door not closed completely ? if it will not shut all the way,push the door firmly shut for the water dispenser poblem
5 check water filter. or water valve clogged or bad? replace them if necessary
good uck
Jan 11, 2011 | Whirlpool Refrigerators
No water or ice
The water pump is US. Or timer faulty
Apr 16, 2010 | Hotpoint HSS25GFP Side by Side...
Inside my side by side freezer side (hss25gfta ww)
The ice maker water inlet valve has failed allowing water to pass when it is not supposed to pass. The water valve is item 800 of this link. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5203104&diagram_id=24933031#d24933031
Changing the water valve most always returns the ice maker operation back to normal.
Kelly
Mar 04, 2010 | Hotpoint HSS25GFP Side by Side...
Water icing in ice maker tubing
Replace the water inlet valve . Water is seeping thru the valve when closed . Drops of water seeping thru and freezing inside the fill tube . After replaceing valve , be sure to remove the ice from the fill tube .
Aug 12, 2009 | Amana ASD2526VES Stainless Steel Side by...
The auger arm doesn't turn. The ice maker still makes ice, it just can't dispense.
Take the ice container with auger inside it and defrost it. Withe the door open to the freezer push the switch that turns light on in freezer to turn it off. Have someone push the ice dispenser switch while you hold the light button in. Tell me if there is any movement in the auger motor in rear and let me know what you find. Thanks, Sea Breeze
Jun 01, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
Water leaks
I have the same problem- had service man out & he replaced the ice maker- not a cheap fix, especially since the ice continues to accumulate at the bottom, then melt onto the floor.  no good answer yet---
Apr 20, 2008 | Jenn-Air JCD2389G Side by Side...
Replacing Auger in ice maker
Kim There are two Screws Holding the Complete Ice unit in Place,After Removing it it unpluggs inside the freezer,It would be advised to Replace the whole Unit ttech
Jul 20, 2007 | Hotpoint HSS25GFP Side by Side...
Several problems with ice maker
i suspect he real problem is that the freezer is not defrosting. its difficult but take off thge back panel in the freezer and see if there is ice build-up on the pipework behind.if so melt it off with a hair-dryer and check also that the drain is clear. the water you have had on the floor could be due to intermittant defrosting
Mar 14, 2007 | Hotpoint HSS25GFP Side by Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
1,551 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
