Question about Car Audio & Video
Need installation video for Simaran entry phone system
    Sergeant:
  • 344 Answers
Try manuals online.com
Posted on Nov 28, 2012
I am trying to use an app on my phone as my keyless entry remote and it asks me foe my cars sim id. what is that? And where can i find it?
For the keyless entry app to work, your car must already have a keyless entry unit installed. You don't say if this is so. I'm guessing the "SIM ID" you are referring to would be the individual electronic code the key fob transmits so every keyless entry fob won't unlock every car in the lot. I've not heard it referred ti as that. If you don't have a keyless entry unit installed, it won't work. If you do and it's a factory unit, you may be able to find it in your owner's manual but I doubt it. At least Ford didn't supply it in mine. If it's an afrter-market "Walmart" special, it may be impossible to obtain You may need to get ahold of your car's manufacturer. If your "SIM ID" actually referrs to something like General Motor's, (cell phone based), On Star system, you're out of luck as Dodge, to my knowledge, has no equivalent. I have only heard of a SIM ID as being associated with cellular phones.
Good luck.
Jeff
Feb 07, 2011 | 2000 Dodge Intrepid
My 2006 Dodge Ram 1500 has electric door locks. I bought it used and just had one key. How can I tell if it has keyless remote entry or what do I have to do to add it
In order to determine if you have a factory installed remote keyless entry (RKE) system, you need to remove the instrument panel and check if the RKE module has been installed. It is located practically in the center of the back of the instrument panel. It may be more economical to have an aftermarket system installed that to get two factory replacement remotes.
The doorlock system utilizes a single wire setup. You will need to use resistors and two relays to interface the doorlocks. The resistor values you need are 820 ohms to ground through a relay for lock and 330 ohms to ground through the other relay for unlock.
Jan 24, 2011 | Alarm & Keyless Entry System Dodge...
Need to make entry time longer . I am able to delete option 10 but can't add option 10. Entry is only 5 sec.
Here is instructions from Installation Manual. I am also attaching links to full Installation as well as User Manuals for your reference at the bottom of page. Make certain to input as 3 digit time - example 45 seconds as 045. Good luck!
Option 10: Entry Delay (Default = 030 sec.)
Determines how much time the user has to disarm the system
after entering the armed premises through a designated delay
door, before an alarm occurs. Beeps sound during the entire
delay time to remind the user to disarm the system.
When turned on, the Entry Delay can be set from 005-254
seconds (030-254 if SIA Limits Option 69 is on). All entries
must be 3 digits. When turned off, the Entry Delay is set to
005 seconds.
Note
For UL listed systems, the entry delay must not exceed 45 seconds.
 To set Entry Delay, press:
1. Add
2. Option #
3. 10
4. Use the numbered keys to enter the 3-digit delay
time.
5. DONE
 To turn off Entry Delay, press:
1. Delete
2. Option #
3. 10
4. DONE
Installation - http://www.homesecuritystore.com/downloadmanual.aspx?mnl_id=334&prod_id=171
Users: http://www.safemart.com/manuals/simon3.pdf
Oct 02, 2010 | GE Security Simon 3 Wireless Home Security...
Desktop will not fill the background of the lcd
Go to the video properties on the control panel and increase your screen resolution. If you just had a new install of Windows your video driver may not be installed. Go to the control panel and chose System-Hardware-Devices and see if there is an exclamation point or question mark under the video entry. If there is you need to get the driver for your video chip. Need more info on Make, Model, S/N to get you to the right web page for the driver. My email pmgibs1@verizon.net Phil
May 27, 2010 | Acer Aspire 5536-5224 Notebook
Iwant to delet my windows live call
After installing Windows Live Messenger, Windows Live Call, part of Microsoft’s Windows Live services which integrates into Windows Live Messenger is been installed too. Windows Live Call allows users to make PC-to-PC computer call, PC-to-Phone voice call and video calls. Windows Live Call also adds an entry into New menu (ShellNew) that appears when user right clicks on desktop or Windows Explorer.
new-windows-live-call.jpg The New -> Windows Live Call menu command allows user to directly initiate Windows Live Call to place a phone call or video call with another contact. Most users may prefer to use Windows Live Messenger to call friends, buddies, family members or colleagues. User who wants to tidy up and keep only a minimum of frequently used New menu’s entries, it’s possible to delete and remove Windows Live Call from New menu entry.
To clean and clear ShellNew (New menu) off Windows Live Call entry, run Registry Editor (RegEdit.exe), and browse to the following registry key:
HKEY_CLASSES_ROOT\LiveCall
Delete the LiveCall registry key to remove the Windows Live Call entry in the New menu.
Mar 30, 2010 | Microsoft Windows Vista Ultimate Edition
I had a remote start keyless entry hooked up and when you lock the doors inside lights go off but the cargo stays on for 1 min with aftermarket remote the factory turns it off can you help me
it sounds like this is a feature on your vehicle. even if you didnt have the keyless entry system, it would happen. it's a common feature on most newer vehicles. but the way you're describing it, it seems like it's a feature on the aftermarket system you had installed. if the light goes off after a minute or two, i dont see any problem. but if you dont want this, i'd go back to the place where you had the system installed and talk with them about it.
Feb 17, 2010 | Car Audio & Video
Mitel Superset 4025
Phonebook is for internal extensions. As soon as you add a ext. and name in phone system it is added to the phonebook.
Jun 11, 2009 | Mitel Superset 4025 Corded Phone...
Jensen car dvd player locked up after car battery died
their should be a little reset button on it some where pop a pin in it for a minute it sould work
Mar 16, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Cannot find stray entries indicating Intel Video Phone installed
Go to control panel, add/remove programs, uninstall Intel software.
Get the new software/drivers from
Intel® PC Camera Pack
Intel® Deluxe PC Camera
Regards
Mar 10, 2009 | Intel Deluxe PC Camera CS330 Webcam
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
