Question about Ovens
Ignition not working on new world chorus 2 cooker
2 Suggested Answers
AndrexT
  • 14818 Answers
SOURCE: how do i get new world we5241 gas cooker to work
You need to light the pilot light. As my learned friend says, "consult the manual". Usually involves, holding a button in, pressing a spark ignition button, continuing to hold the button in until the thermocouple glows red and then slowly releasing the button and confirm that the pilot light remains lit.
I presume the gas hobs work OK?
Posted on Feb 16, 2016
The ignition continues after gas lights on new world elegance/cooker and grill
The igniter will glow orange while the oven is on. This is NORMAL. If it went out the burner would not come back on when the thermostat calls for heat .
Aug 18, 2014 | New World G90m Gas Double Oven
My newworld newhome cooker's ignition does not work. Please could you tell me where the battery goes as I cannot find it.
The battery is in a case (plastic holder) left hand side right near the floor in the plinth, opening the oven door will make it easier to see. (Assuming I have the correct model)
Dec 09, 2013 | New World Ovens
How long should an igniter last on a gas cooker
depends if its a batteie or mains if battrie change when it stop working if its mains any time its light a light bulb and they cant be fixed you have to replace it 4-5 years some times but new cookers dont last long at all 2 years some times ok
Oct 17, 2012 | Zanussi Ovens
Ignition not working although there is power to the cooker (oven fan working)
we turned it off at the plug left it for a 5 minutes it then worked again
Jul 27, 2011 | New World G70m Gas Double Oven
Gas wont stay lit after ignition
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 19, 2011 | New World G60m Gas Single Oven
Gas mark nob not having any effect on gas levels in the oven seems like it is on its highest setting all the time? Also the ignition keeps clicking away all the time could this be a s/c on the wire from...
Time to change the thermostat. the cap tube sounds like it has been broken. If it has a temp control board, change the temp probe. The clicking sound, if unit is equiped with an ignition control modual, is bad, (not shutting off after sensing pilot) or sensor rod is dirty.
Dec 23, 2009 | New World G60m Gas Single Oven
Melted knobs
New world engineer called out and fitted cooling fan there was no charge done as a gesture of good will as cooker was just out of warranty.
Sep 15, 2009 | New World G70m Gas Double Oven
Lost the manual for a new world cooker
To get a new (pdf) manual ask at http://manualfox.com - they find you every manual.
Jul 31, 2009 | Ovens
How to light our gas cooker
Modern gas cookers use an electronic ignition switch rather than a pilot light to light the gas for cooking. This means you can light your gas cooker with the touch of one button instead of using several matches or a flint lighter. Of course, you still have the option to light the gas cooker by hand with matches or a flint lighter if the ignition switch does not work the first time.
1.Open the gas regulator valve by pushing it in and turning it to a low setting.
2.Push the ignition switch once.
3.If the gas cooker does not light on the first try, close the gas regulation valve for one minute by pushing in on it and turning it back to the "Off" position.
4.Open the gas regulation valve, set it a bit higher than you did on the first lighting attempt, and push the ignition switch again.
5.Light the gas with a match or a flint lighter if the gas cooker does not light when you push the ignition switch again.
Feb 23, 2008 | Ovens
Ovens Logo
54 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
