Question about General Electric Hot Point Washer Wh13x81 Wh13x62 Water Inlet Valve Assembly
Overloaded washer now it starts and then just stops and shut off after while will start but shuts off again
    Top Expert:
  • GE Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 27, 2012
Testimonial: "Thank you for the response. The washer started working again after I unplugged it for 1 minute. But, if I have anymore trouble i will definately use this site again."
Starts to spin then stops and sounds like it shuts off
You are probably overloading it. When it stops just open it, take some clothes out and rearrange the clothes in the washer so that they are as evenly spread as possible. Close the lid back. It should cycle on again. If it does not, repeat the same procedure. When the weight/ bulk of the clothes is small enough for the machine to handle it should then complete the cycle/wash.
Apr 04, 2014 | Kenmore 24032\24036 Top Load Washer
Front load washer stopped working
What is the model number listed on the washer?
Oct 13, 2012 | Washing Machines
9yr old model Maytag window a/c - just blows cold for 30 seconds - then blows warm. Was perfect until this happened. Is it worth fixing? What would be the usual fix for this?
The compressor is shutting off on overload after running for a few seconds. The overload cools down and starts the compressor running again until the overload heats up and shuts the unit off again.
Aug 02, 2011 | Heating & Cooling
The Washer stops after its full if I shut it hard it starts again?
May be the door lock is lose contact kindly change the door lock
May 18, 2010 | Washing Machines
Top loading Kenmore washer runs for a few seconds then shuts off
It's quite possible, however,
If you're mechanically inclined, I'd check the motor, transmission and pump first.
See the following Whirlpool / Kenmore Service manual for top load, direct drive washers and it's trouble-shooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
See the following for how to pull the cabinet, pump, motor and transmission to check them all.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
YOU DON'T HAVE TO PULL THE TUB.
Mar 15, 2010 | Kenmore 43142 Front Load Washer
Washer stops during spin cycle
I have the same problem with my washer. If I can figure it out I will let you know.
Oct 03, 2009 | Maytag Dependable Care LAT9706
Pfaff Creative Vision embroidery/sewing machine says motor overload then shuts down
I had the same problem and it was my power supply. I've had more than my share of problems with this machine and it's only 3.5 years old. Good luck.
Nov 08, 2008 | PfaFF Sewing Machines
E40 error code
The E40 error code indicates a loss of electrical power usually but not always due to the door not shutting properly or not locking. But, since you smelled burning it could be any electrical short that blew a fuse and shut the machine down. It could also be the motor windings with the internal overload protector shutting it down.
Dec 16, 2007 | Zanussi ZWF1440 Front Load Washer
Overload
Dont worry by the time you read this it will probably already start working again. There is a Auto Reset Thermal Overload Switch on the motor that shuts it down when its pulling too much amperage. Its not good for them but they are usually fine. Just advise your wife its hard on your particiular design washer to be overloaded.
Nov 25, 2007 | Maytag MAV7600 Top Load Washer
Begins to agitate but stops
The motor could be drawing too much current and causing the overload relay to trip. You will need to get an authorised techinician to test the motor.
Nov 01, 2007 | Kenmore 93702 Top Load Stacked Washer /...
General Electric Hot Point Washer Wh13x81 Wh13x62 Water Inlet Valve Assembly Logo
240 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
