Question about Philips HTS3371D Theater System
I have Philips HTS3371D Theater System but it said no disc
I put a DVD but it said no disc it look like reading but is not
ThaMp3Doctor
  • 8596 Answers
SOURCE: Reads NO DISC Philips HTS3400 Home system
Run a dvd cleaner through system, and try again. If that fails, unplug the HTS from the wall outlet for 10-15 seconds, and replug it. If that fails, it will need to be repaired.
-Tha Mp3 Doctor
Posted on Feb 18, 2008
rongxin
  • 57 Answers
SOURCE: dvd player won't stay on
your unit sir or maam, it has a deffective parts you need to replace the parts the two channel of the power output ,because this parts is shorted,you need a good technician to fix it. and buy the parts to replace it
kira_ryuk99@yahoo.com
Posted on Jan 11, 2009
  • 349 Answers
SOURCE: ''WRONG REGION'' MESSAGE ON PHILIPS HOME THEATRE SYSTEM
Ensure both TV & player are on , no disc in player
on the remote press: disc menu, then open/close then stop
enter the following numbers:
7,3,4,4,6,6,0
you should see region 0 in the bottom left hand corner
the player should now play, if not and your in Australia ring Philips on
1300 363 391
good luck
Terry
Posted on Jan 12, 2009
  • 15 Answers
SOURCE: How to extend speaker cables of Philips MX6050D DVD Home Theater
Go down to your local RadioShack or any place that sells wire of any sorts (heck, even Walmart might carry it now) and ask them for speaker wire. I'm not sure what the impedance of this particular model is, but you should be able to find it printed on the back of the speakers, or in your user's manual. This guide will help you to identify what size speaker wires you need, that way when you go in looking for speaker wire, you'll at least sound like you know what you're doing.
Posted on Jun 02, 2009
AJIN G
  • 6694 Answers
SOURCE: i have a philips hts6510
hi,
Normally a dvd player shows the message NO DISC when,
1. The disc inserted is bad.
2 The lase pickup unit inside the dvd lost its reading intensity, dirty lens or the spindle motor damaged .
In your case the second one happened. the intensity of the laser pickup unit has lost or the spindle motor faulty or there is some dust on its lens. just insert a cleaning cd in it for two or three times. then check again is the DVD is reading or not
if the problem remains then you have to check the motor and the laser pickup unit. the lase pickup unit have two laser emitter and receiver in its inside . one for reading and playing DVDs and the other for CD and MP3. also the spindle motor runs in different speed when u insert dvd and cd.
Open the cover of your dvd player and power it on insert an audio cd and watch is it reading or not also notice the speed of the spindling of the cd. if the audio cd reads and play. then the possible problem is the spindle motor
To conform it remove the audio cd and insert a dvd. watch the rotation of the dvd. if it feel very hard to rotate it then, the spindle motor is damaged. if so replace the spindle motor if it runs more the the speed of than audio cd then the laser pickup unit is faulty. Then u have to replace the laser pickup unit.
if you need any further assistance from me , feel free to contact me through fixya.
ok
Posted on Jan 16, 2011
DVD player
Check its mechanism and laser pickup unit.
Apr 16, 2012 | Audio Players & Recorders
My philips hts3371d burnt because of wrong voltage
This is quite serious as unless the fault is checked the depth of the damage cannot be assesed. It can vary from a shorted capacitor , rectifier or driver regulator to a serious issues where the mother board and processor is affected. So take a consensus and estimate before we can proceed.
Oct 05, 2011 | Philips HTS3371D Theater System
Philips Home Theater System (HTS3371D) will not turn on. Approximately 2 years old, never had a problem. I woke up today and the red indicator light is off and the system is completely unresponsive. It...
Have you contact Philips customer service and described your problem? I would suggest you start with them. If your outlet is supplying voltage and the unit is not turning on chances are there is a fuse inside the unit that is blown. The unit would not be hot because a small amount current is no longer flowing into the unit which is indicated by the led light no longer being lit.
Aug 10, 2011 | Philips HTS3371D Theater System
Got a philips hts3357 some discs play some come up no disc
unfortunately Philips DVD players are more precious/ selective on DVDs than the other brands..it is true especially with "Copied DVD"..normally an original DVD should not cause such problem..however if your DVD disc itself is not clean ( i.e.finger prints ) the reading LASER sometimes has problem to read it..
I recommend to buy a "wet DVD laser cleaner system" and clean your laser on DVD and your DVD discs as well..it is available any HI-FI store..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 22, 2011 | Philips HTS3357/05 Theater System
I have a Philips HTS 3371 DVD home theatre and can not play many DVD's as it give wrong region error. Can you please provide the unlock code and how/where to enter it to get it fixed?
Hi -
Please follow the instructions below for unlocking your Philips HTS 3371
Please note: Unlocking a DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
1. Switch the DVD player ON
2. OPEN the disc tray
3. Key 9 9 9 9 0 using the Philips remote control supplied with the player
4. Press PLAY. The disc tray will close.
5. Switch the player OFF then switch ON again.
6. To test, play a disc from a region which was previously locked.
If it does not work the first time, switch the player off and back on, then try again.
This is a verified unlock method, but I was unable to confirm whether it works for players sold locked to Region 1 (North America). If you have a Region 1 player and the method above does not work, you will not be able to unlock your player.
Regards,
BElectric
Mar 26, 2011 | Philips HTS3371D Theater System
Latest software update
The latest firmware update for this model would be located here:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=HTS3371D/F7&scy=ca&slg=en
Jan 21, 2011 | Philips HTS3371D Theater System
-Tha Mp3 Doctor
Jan 27, 2008 | Philips HTS3400/37B System
Philips HTS3371D Theater System Logo
46 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
