Question about HP LaserJet 4350n Printer
Hp laserjet 4350 print problems
The left side of paper has tiny black circles on edge. What caused them and can they be fixed? Thanks!
  • HP Master
  • 1,121 Answers
Two reasons: 1. cartridge 2. Trflon sleeve.
A.Check with another cartridgeB.Remove fuser assembly, check teflon sleeve surface,if its dirty or toner deposited on it replace it if you can or replace entire fuser assembly. Replacing the fuser assembly is user friendly.How to remove fusser: browse this youtube video link:
http://www.youtube.com/watch?v=j0Pi-eHgoSA
Posted on Nov 28, 2012
SOURCE: hp laserjet 4350 printing slow down
Look on the left side of the tray. There should be 3 white fingers that stick out. Make sure they aren't broken or out of place. Also slide the paper size lever and make sure they work properly. There is also a custom and standard switch. Try to print out of the MP tray(fold down tray). If it prints normal speed, you probably have a problem with the tray.
Posted on Nov 16, 2006
SOURCE: HP LJ 4350 paper folding problem
It could be either the paper feed assembly, part # RM1-0012, or the registration assembly, part #RM1-1098. These parts can be bought at TSAworld, phone # 1-800-633-6626
Posted on Aug 20, 2008
  • 141 Answers
SOURCE: HP laserjet 4350 DTN Folding corners
teflon coating on heat roller in fuser is coming apart. replace the fuser. also check to make sure the paper tray is set to the correct size. this means pull the tray out, remove all paper, look inside to make sure the arrow is pointing directly at the correct media size you are using i.e. letter or legal or whatever you are using. Good Luck! please rate this carefully.
Posted on Oct 11, 2008
SOURCE: STREAK LEFT ON RIGHTHAND SIDE OF PRINTED PAGE
Fuser sleeve is contaminated and needs replacing - cheaper to replace the printer.
Posted on Apr 17, 2009
BaronVonNuke
  • 1915 Answers
SOURCE: HP color laserjet 2605dn: I have blue stripes on
You likey have a bad CYAN cartridge, that is the first thing you want to replace.
Posted on Apr 03, 2011
Left edge black on hp laserjet printer
Fuser teflon sleeve got damaged, replace it.. (only professionals can do this activity) if its not available go for new fuser assembly..
Jul 31, 2012 | HP "LaserJet P2035n Printer"
Tip
HP LaserJet LJ 4350 locks up when duplexing
Symptom: Your LaserJet 4350 prints just fine until you try to print a double-sided page. Then you see the page start to exit, pull back in, then stop. The Data light continues flashing green, and the display reads, "Processing..." There is no error indication, but the machine won't print the second side and continues to hold the half-printed paper in the duplexer. If you open the top cover and close it again, the printer will eject the page, then try to print the whole thing again, unless you're quick enough to cancel the job first.
Cause: The printer is expecting a different sized paper than what it's running. Often it's not the menu settings, but a little lever in the paper tray itself. Pull out the paper tray you're trying to print from and look for a little blue lever on top of its right-hand side. The lever is labeled "Standard/Custom." Flip it to Standard (parallel to the tray side) and your problem should go away.
on Mar 17, 2010 | HP LaserJet 4350dtn Printer
HP 2840 will not print on 3 inches of left side of page
Take the toner cartridge out, shake it back and forth, and turn it around in a circle a few time. Put it back in the priter, and print. Order a new toner cartridge.
If this is an inkjet printer, ignore this response.
Apr 21, 2010 | HP LaserJet 2840 All-In-One Printer
Ink smudges on the right side of the paper
Your problem is due to a worn fuser unit (upper fuser roller).
The teflon coating has worn again, alowing the toner to stick to the roller and then "repeat" about 3x down the paper (getting fainter each time).
You need to order a new fuser unit.
Click here to go to HP direct
RM1-1083-070CN Fuser assembly - 110 VAC - For LaserJet 4250/4350 series RM1-1083-070CN Fuser assembly - 220 VAC - For LaserJet 4250/4350 series
Make sure you order the currect voltage (US or UK)
Regards
Vince.
Mar 04, 2009 | HP LaserJet 4250n Printer
Oct 09, 2008 | HP LaserJet 4350dtn Printer
Aug 08, 2008 | HP LaserJet 4350 Printer
HP LaserJet 4000tn Printing a Black Line
Change the toner cartridge, refilling will not solve the problem.
May 29, 2008 | HP LaserJet 4000tn Printer
Colors faded on left side of paper black and blue
Is it possible for you to clean the printheads manually with cotton buds and cleaning solution on this unit. Clean all thoroughly and this might just correct issue.
Sep 01, 2007 | HP Color LaserJet 3500 Printer
Hp laserjet 4350 printing slow down
Nov 15, 2006 | HP LaserJet 4350 Printer
HP LaserJet 4350n Printer Logo
49 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
