Question about Mitutoyo Dial Calipers
How do you reset the zero on 505-677 mitutoyo dial calipers
2 Suggested Answers
  • 583 Answers
SOURCE: how to reset zero position reading on a mitutoyo
unless they have changed them there is asrew like a watch winder on the dial it self ,undo it slightly and turn the dial to the desired position then retighten the screw
Posted on Nov 09, 2009
I have a mitutoyo digital caliper model 500-230. i replaced the battery but when i pressed the on/zero button the display keeps running like its counting down and will not stop. The in/mm button seems to...
Sounds like the new battery you installed is no good. Is the display also dim? When the battery is low that is one of the results on the Mitutoyo. Do you have another battery to try in it?
Jan 08, 2011 | Mitutoyo 500 506 10 Electronic Digital...
I HAVE A MITUTOYO 6 INCH ELECTRONIC CALIPERS,MODEL # CD-6 CS. IT NO LONGER CAN SET ITSELF TO ZERO WHEN THE JAWS ARE CLOSED AND IN THE ZERO POSITION. PRESSING THE ZERO ABS CODE FOR 2 SECONDS AND THE...
The answers above by Kerry Littleton have nothing to do with our calipers. The answer above by Bob Pulver is well-intentioned but doesn't address the real issue.
The real issue is the ORIGIN button is little-used and a bit reluctant to "make". The solution is to use a blunt plastic probe to REALLY PUSH down the button and hold it. The caliper will reset to zero.
Dec 24, 2010 | Mitutoyo Dial Calipers
The face on my dial calipers is turned 90 degrees to match up to 0. How do I adjust it to be correct and readabel?
There should be a small set screw you can loosen by hand and adjust the face of the dial to zero with the jaws closed....this is typical of most calipers...it allows you to zero the dial on a given thickness of material and only read variations based on that thickness.
Take care.
Dec 09, 2010 | Mitutoyo Dial Calipers
How do you rezero a 505-637 mitutoyo dial caliper
Fully close the caliper. The pointer should be pointing about straight up or close to it. Losen the knurled screw which is located on the circumference near the bottom. Now grab the dial and turn until the zero lines up with the needle. Re-tighten the knurled screw.
Dec 03, 2010 | Mitutoyo 0 150mm X .02mm Dial Caliper
My caliper is .030 off of zero I don't know how this happened . How can I fix this problem
Just loosen the screw that clamps the dial in place, close the jaws, and turn the dial to zero. Then tighten the screw clamp
Sep 18, 2010 | Mitutoyo Dial Calipers
I zero my caliper and go out an inch and then close and it is rea
The dial and needle are not aligned properly. I have several calipers (all vernier) which were past down to me from my father. Some are almost 75 years old and still measure +/- 1000th! I'd go out and get a good old fashioned caliper.
Feb 17, 2010 | Mitutoyo 505 677: Test & Measurement...
How to reset zero position reading on a mitutoyo 505 629 dial caliper?
Nov 08, 2009 | Mitutoyo 505 677: Test & Measurement...
How to adjust Mitutoyo 505-101 caliber
You don't. What you did to adjust zero is what you do to adjust zero. Do not "go inside to adjust the dial". If the dial reads zero when the jaws are shut there is no problem.
Mar 18, 2009 | Measuring Tools & Sensors
Mitutoyo Dial Calipers Logo
60 people viewed this question
Top Mitutoyo Measuring Tools & Sensors Experts
Doug Adams
Doug Adams
Glenn
Glenn
Are you a Mitutoyo Measuring Tool and Sensor Expert? Answer questions, earn points and help others
